Look at Van's Blather here.
Old August 17th 06, 03:19 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Jim Logajan
Default Look at Van's Blather here.
"Kyle Boatright" wrote:
In talking with Van's, they really thought they would have quite a few
customers for the RV-9 who would use the 0-235 or 0-290. Sure, there
are a few, but there are far more guys bolting on the 0-360 @ 180 hp,
which is 20 hp more than what Van had in mind when he designed the
airplane.
I had contemplated an O-235 powered RV-9A. Here's the chain of reasoning
that I (and probably others inclined to lower horsepower) went through
before realizing it may be a less than optimum choice, even if one seeks to
lower operational expenses like avgas:
When I bought the RV info pack, I finally discovered why the specs on Van's
web site lists the gross weight (GW) range for the RV-9A from 1600 to 1750
pounds: the recommended gross weight increased with horsepower (a
dependency I could not find anywhere on Van's web site). At 118 HP,
recommended GW is 1600 lbs, at 135 HP it is 1675 lbs, and at 160 HP it is
1750 lbs. Now what is the actual structural limit?? Beats me - looks like
the GW goes as the cube root of the HP, so at 200 HP could I safely
increase the maximum GW to 1900 lbs? The designer recommended GW on _none_
of the other RV models changes with HP selection - only the 9 and 9A models
indicate a GW dependent on HP. If the lower max GWs are due to center-of-
gravity (CG) issues, or a takeoff performance issue, then it would be nice
to see that specifically stated somewhere.
Now with an 118 HP O-235 RV-9A @ 1600 lbs GW, Van's typical empty weight is
listed at 1028 lbs, leaving 572 lbs useful, or a miserly 356 lbs useful
with full fuel (36 gallons). So a couple who wish to travel cross-country
and wish to take any baggage at all immediately begins to cut into the fuel
- provided CG issues with that lighter engine up front doesn't limit their
baggage first. Lastly, the install cost difference between a Lycoming O-235
and a Lycoming O-320 does not appear to be terribly great. And if you want
to increase the still air MPG on the larger engine, you can just throttle
back and still get close to the same still air MPG at the same airspeed as
that provided by a smaller engine.
Given all the above, it doesn't seem hard to justify installing something
larger than an O-235 in an RV-9A.
Old August 17th 06, 03:25 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Kyle Boatright
"Jim Logajan" wrote in message
snip
Another way to look at it is that you can always throttle the 180 hp engine
back to get roughly the same fuel burn as the 118 hp engine, but no matter
how hard you firewall the 118 hp engine, it is still only 118 hp...
In addition, I think you'll get a far better resale with a 150 hp or better
engine in the -9. I think there are plenty of people who wouldn't even
consider buying a 118 hp version.
KB
Old August 16th 06, 11:11 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Newps
Casey Wilson wrote:
"Newps" wrote in message
Any chance there's a point to this drivel?
Herr Ludwig didn't make it clear that he is ranting AGAINST the choice
of the Lycoming for all RVs. Akshully, Herr Ludwig makes no cogent remarks
as he stepped on his..., well let it go at that.
So you could have answered my question with one word then.
Old August 16th 06, 10:11 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
.Blueskies.
I think someone lost their meds today...
"Newps" wrote in message . ..
: Any chance there's a point to this drivel?
: Bret Ludwig wrote:
: Introduction - Powerplant Choices
: RV aircraft are designed to use Lycoming aircraft engines.
: The RV-4 and RV-6/6A use 150/160 hp 0-320 or 180 hp 0-360 engines.
: The RV-7/7A and RV-8/8A can accommodate O-320, O-360 or angle valve
: IO-360 (200 hp) engines. The RV-9/9A is suitable for Lycoming engines
: in the 118 hp to 160 hp range. The engine used in the 4-place RV-10 is
: the Lycoming IO-540D4A5 rated at 260 hp. Van's recommendation for the 4
: place includes any of the parallel valve 540's which are available from
: 235hp on up to the 260hp version. These engines are the most readily
: available, affordable, and reliable of the possible choices. Other
: aircraft engines of similar configuration, weight and power might
: possibly be used, but only the Lycoming will fit the mounts and cowls
: supplied with our kits.
: Van's volume allows us to buy appropriate models of new engines at
: O.E.M. (Original Equipment Manufacturer) prices direct from Lycoming.
: We market these engines to our customers at far less than list price.
: This makes them an affordable alternative, even when compared to the
: traditional used engine. Van's has similar arrangements with Hartzell
: Propeller, Sensenich Propeller and other manufacturers.
: Other Engines
: We are often asked about using non-aircraft engine conversions. We'd
: like to pass along a quote from a colleague in the homebuilt airplane
: business:
: "the best conversion I know is to take $8000 and convert it into a
: good used Lycoming." This may sound a bit narrow-minded, but it
: reflects the basic truth: no non-aircraft engine has yet proven to be
: as reliable, available, and inexpensive (everything considered) as a
: traditional aircraft engine.
: It seems that magazines are always printing stories about automobile
: engines bought for junkyard prices, mated to inexpensive reduction
: drives and flown off into the sunset. It simply doesn't work like
: that in the real world. The reliability we have come to expect from
: aircraft engines is the result of years of development and refinement
: of engines designed specifically for the task. Automobile engines
: function well in their intended application: delivering low cruising
: power in vehicles with well designed transmissions and power trains.
: Using them successfully in an airplane requires continuous high power
: outputs and reduction systems coupled to the propeller. This is
: completely foreign to their design intent. (You can imagine the car
: engine designer banging his head slowly against his desk..."no, no, no.
: If I'd known you wanted to do that with it, I would have designed
: something different....)
: (Why are Lycomings never found in boats, fire pumps, gensets or other
: high output and often life-critical applications? They are less
: reliable intrinsically than commodity powerplants, and secondarily
: ridiculously priced.)
: With enough research and development effort, auto engines may be made
: to work acceptably or even well in an airplane. We are not opposed, in
: principle, to RV builders using alternate engines, but we would hope
: that this choice is made on facts, not hopes or dreams. Do you want to
: spend your time and effort on engine development or do you want to fly
: confidently behind an engine that has already been developed?
: (Using that logic why should I spend more money to build your
: noncertified, and presumably intrinsically uncertificatable by design,
: airframe when less will buy me a PROVEN, certificated aircraft? )
: We, too, would like to see "something better" in available powerplants.
: We are carefully watching some alternatives. Meanwhile, the proven
: Lycomings do the job very well and are the best "available now" option.
: Despite the many claims and promises made by promoters, we feel that if
: you will look closely at what is actually available, how many are
: really flying, and how well they really perform, you will agree with
: our conclusions.
: (Not "you may" agree, "YOU WILL". Ja wohl Mein Führer! With all due
: disrespect, Dick, I don't think you really would like to see any other
: powerplant succeed because one, you have a sweetheart deal with
: Lycoming, and two, you want your RVs to be alike as production aircraft
: to fluff resale and insurability without the bother of type
: certification and production. This is called "the tragedy of the
: commons" or "why buy the cow if all those heifers will come to you for
: you to milk the living daylights out of and they will buy you breakfast
: too".)
: While we are not opposed to RV builders installing alternate engines,
: we simply cannot recommend or encourage the installation of any other
: engine - we don't feel it would best serve the interest or safety of
: the builder.
: (It wouldn't serve OUR interest.)
Zodiac XL vs Rans S-19 vs Van's RV-12 Jim Logajan Home Built 12 July 2nd 06 10:31 PM
Very Nice Van's RV-6A For Sale Don Aviation Marketplace 3 January 14th 06 12:13 AM
Very Nice Van's RV-6A For Sale Don General Aviation 1 December 21st 05 01:52 AM
Vans RV-11 Scott Correa Soaring 27 January 5th 04 07:56 AM
bulding a kitplane maybe Van's RV9A --- a good idea ????? Flightdeck Home Built 10 September 9th 03 07:20 PM
