#21
Chris,
Specifically, where does the clearance begin, and end. ATC is going to want a starting point and an exit point. Going back to my earlier note, how do you get up and down? The cloud layer closes in below you while your going x country IFR in a pure glider, how do you legally get down. You are coming down somewhere, I don't have an argument there, but ATC has a big manual called the TERPS Manual that they have to operate by. It is their ball and chain that they operate by, and if they've issued us a clearance, they have some pretty tight parameters that they want us to fly by in their airspace. Let's say that your here at my club in Texas. My specific question here would be how would you file the route portion. Let's say you use a fix near TSA to start. Now, how do I file the altitude? A block is probably the best way, as you mentioned, but how do you guarantee your local controllers that your going to remain in that block, especially if the bottom fills in below you while your cruising. This is why I'm a bit suspect that there are some loose ends to flying gliders IFR, from a totally legal standpoint. I beg to differ that it is nothing like flying an airplane IFR. Thanks for the input Fox Two wrote: snoop wrote: Good find. That's what I saw, in the same vein, with 61.57, how to stay current, but the requirements for an instrument rating still leave us hanging out there, as mentioned earlier. Now we need the operational or part 91 end of it. How to do it. Hang in there guys, Shawn, c'mon buddy we need you to help here. Snoop- What are you talking about?! Ask a specific question! Flying a glider under IFR is EXACTLY THE SAME as flying an airplane under IFR. That is why an instrument rating in airplanes is required to fly a glider under IFR. Here's how you do it: 1. File the flight plan. 2. Receive the ATC clearance. 3. Fly the glider! If your flight is intended to be local in nature, you request a block clearance both laterally and vertically, and remain within your clearance limits. If you are flying cross country, you receive a route clearance with authorization to deviate up to x miles left and right of course within a block altitude limit. If you already have your instument-airplane rating, and a few hundered hours of instrument experinece, you should already know all of this. If you don't, then you shouldn't consider flying a glider IFR. Chris Fleming, F2 |
Snoop,
That's more like it: specific questions. It appears to me that you are making this way too difficult. Here we go: snoop wrote: Chris, Specifically, where does the clearance begin, and end. ATC is going to want a starting point and an exit point. What is your intended task? If you're going from A to B and landing at B, then file from A to B. Most glider cross-countries start and end at the same place, so file from A to A via B and C. You can amend your clearance at any time. If you don't think you can make B, just tell ATC and request clearance to C, or back to A or to a new destination D. In short, just tell them what you want to do! Going back to my earlier note, how do you get up and down? The cloud layer closes in below you while your going x country IFR in a pure glider, how do you legally get down. I'm not sure I understand your question. Your initial clearance is going to have an altitude block. Throughout your flight, you will amend this clearance both up and down. I've had clearances which had 8,000 foot deep altitude blocks! You are coming down somewhere, I don't have an argument there, but ATC has a big manual called the TERPS Manual that they have to operate by. It is their ball and chain that they operate by, and if they've issued us a clearance, they have some pretty tight parameters that they want us to fly by in their airspace. TERPS means Terminal Instrument Procedures. Do you seriously intend to fly an ILS in a glider? I didn't think so. Likewise, DP's STAR's and all other IAP's are irrelevant to IFR gliders. Gliders need to depart and arrive under VFR. TERPS doesn't apply. Let's say that your here at my club in Texas. My specific question here would be how would you file the route portion. Let's say you use a fix near TSA to start. Now, how do I file the altitude? A block is probably the best way, as you mentioned, but how do you guarantee your local controllers that your going to remain in that block, especially if the bottom fills in below you while your cruising. This is why I'm a bit suspect that there are some loose ends to flying gliders IFR, from a totally legal standpoint. As for filing your route, just file direct. For altitude, file for your estimated max altitude. In the remarks section, write: Glider flight. Will require course deviations and block altitudes from ATC. Yes, you must remain within the parameters of the clearance. So, you shouldn't accept a clearance that you can't comply with. If you're at 5,170 feet and scratching in weak lift, do not accept an altitude clearance that requires you to remain above 5,000 feet! Likewise, if you've encountered unexpected sink, advise ATC that you will need a new altitude clearance. It all comes down to COMMUNICATION! I beg to differ that it is nothing like flying an airplane IFR. 90% of flying an airplane IFR includes VMC departures and arrivals, with only a few moments in IMC conditions. Just like a glider. Thanks for the input You're welcome. Now let me add this: to safely fly a glider in IFR conditions, the pilot must be able to walk and chew gum at the same time. Flying a glider effectively on a cross-country is challenging. Flying single-pilot IFR is challenging. Flying a glider on a single-pilot IFR cross-country is extremely challenging. Prerequisites should include many recent hours in both glider cross-countries and IFR procedures. At the risk of speaking for others, glider pilots that fly IFR have huge personal weather minimums. They won't consider flying IFR unless they are certain that they will be able to cancel IFR and continue to their destination under VFR with a significant safety margin. Most pilots will file IFR with no intention of ever flying into a cloud. Instead, they want to be able to fly closer to the cloud than the minimum distances required for VFR. Most IFR cross-countries are in mountain waves, and the risk of going from clear and a million to suddenly being engulfed in a thick cloud is real. Being on an IFR flight plan is a safety measure. Finally, nothing can substitute for good judgment. IFR in gliders can be a valuable tool, but it can easily kill you. Don't even think of doing it unless you are certain that there is no risk from doing it. Actually, your criteria should be the opposite: do it only if you think it is the safer option. Chris Fleming, F2 ATP B-767, CFI-G |
snoop wrote:
Sorry Jack but your dead wrong. There are flesh and bone reasons why we should teach people why we don't penetrate clouds, in US gliders/airspace. Let's deal with what I wrote: "It can be done safely, under limited circumstances, and our effort ought to be to show people how to do it safely and legally, not to scare them away." When you tell folks, "Don't do it," and just walk away, you've lost your best chance to influence their behavior in the long run. As a matter of fact, I suspect you and I would arrive at the same point after beating around this bush for awhile. I won't get "called in by the FAA for IFR [sic] glider flying here in the USA," because I won't be doing any. With regard to wave flying, yes we get a window, and stay out of the clouds and ahead of the weather. I've flown the wave window at Marfa, where we had a window, a chunk of airspace, but still not a clearance into IFR [sic] conditions. The topic here is getting a clearance and going into solid IFR [sic]. The topic can be anything you want it to be, Snoop, but the thread is titled "Cloud Flying". Your statement " it can be done safely under limited circumstances" won't hold up when your dancin' for the FAA. "It can be done safely under limited circumstances" is a statement for a NG discussion on the topic of "Cloud Flying". Legality is a different question and one on which it is clear you are confidant you know the answer. The FAA might even agree with you, but if they didn't they'd never tell anyone -- you know how they are. So maybe you can point out to us those FAR's that actually prohibit gliders from flying in clouds in the USA under any circumstances. And then we can watch advocates from the other side of the issue show us where their FAR's can beat up your FAR's. This ought to be fun.... Jack |
Chris,
I don't want to make it difficult. What I do want is for those of us, who want to protect our sport of soaring from, the intense scrutiny of the public eye, and the heavy hand of big brother, to think through this difficult subject. As seen in this thread there is a lot to this thing we call IFR flying. I fly IFR everyday at work, all around the world. Its wonderful, and like flying gliders, gives a lot of satisfaction to the pilot side of the brain. Your input has been very helpful, but to me there are still a lot of loose ends. When I flew cargo in twin cessnas, back in the late seventies, we filed our own flight plans with the FSS desk at DPA, under the watchful eye of Theo Moore, the king of the local FSDO. Theo would collect our flight plans and go over each box on that little flight plan card to see that we met the letter of the law. For instance if it was a day when it was lifr, he would check the validity of our alternate, our fuel. The guy was not bashful about doing this while standing behind the counter as we filled them in. All our pilots received a first hand lesson in what goes in each of those little boxes, and why. Lessons that still apply today whether filing into MKE, or VIDP. My point here is I'm still fuzzy on the official guys (FSS, ATC) accepting something as simple as the flight plan for our glider as you described. From an operational viewpoint, it's clear as a bell to me, it's simple. I've received untold numbers of pop up clearances in the past. There are still MEAs, MOCAs, MVAs, things, that the contollers have to govern who they turn loose in the clouds. How does the local guy work around these. Again it appears quite simple from the operational end, but....... Then, there is local knowledge, which I'm thinking goes a long way with glider IFR. That is what we need clarification of. And use conservative common sense. But that term is not in the FAAs handbook. As you well know most of these FAA regs have blood written on them. I would have to have the controller himself tell me the TERPs are out the window when it comes to my glider flying IFR. What I'm hoping Shawn will do before publishing anything about IFR glider flying is to take all of our points, sit down with his local FSS, ATC guys, the guys who give him his clearance, and hash it out. Maybe get Shawn, or anyone else who knows how to, no, wait, there are a lot of people who think they know how it's done, let's get those who do file, and fly their glider IFR, to get their local ATC/FSS people to present a paper, or talk to the local groups, about the procedures and responsibilities of flying our gliders IFR. With all due respect to Shawn and his paper, these things, he has probably done! Your exactly right about doing it as a "safe option". We might have to dance with the feds, after the help ATC gives us, to get us back to VFR conditions, but we sure don't want a 340 knot mustard colored suppositorie up the backside. snoop Fox Two wrote: Snoop, That's more like it: specific questions. It appears to me that you are making this way too difficult. Here we go: snoop wrote: Chris, Specifically, where does the clearance begin, and end. ATC is going to want a starting point and an exit point. What is your intended task? If you're going from A to B and landing at B, then file from A to B. Most glider cross-countries start and end at the same place, so file from A to A via B and C. You can amend your clearance at any time. If you don't think you can make B, just tell ATC and request clearance to C, or back to A or to a new destination D. In short, just tell them what you want to do! Going back to my earlier note, how do you get up and down? The cloud layer closes in below you while your going x country IFR in a pure glider, how do you legally get down. I'm not sure I understand your question. Your initial clearance is going to have an altitude block. Throughout your flight, you will amend this clearance both up and down. I've had clearances which had 8,000 foot deep altitude blocks! You are coming down somewhere, I don't have an argument there, but ATC has a big manual called the TERPS Manual that they have to operate by. It is their ball and chain that they operate by, and if they've issued us a clearance, they have some pretty tight parameters that they want us to fly by in their airspace. TERPS means Terminal Instrument Procedures. Do you seriously intend to fly an ILS in a glider? I didn't think so. Likewise, DP's STAR's and all other IAP's are irrelevant to IFR gliders. Gliders need to depart and arrive under VFR. TERPS doesn't apply. Let's say that your here at my club in Texas. My specific question here would be how would you file the route portion. Let's say you use a fix near TSA to start. Now, how do I file the altitude? A block is probably the best way, as you mentioned, but how do you guarantee your local controllers that your going to remain in that block, especially if the bottom fills in below you while your cruising. This is why I'm a bit suspect that there are some loose ends to flying gliders IFR, from a totally legal standpoint. As for filing your route, just file direct. For altitude, file for your estimated max altitude. In the remarks section, write: Glider flight. Will require course deviations and block altitudes from ATC. Yes, you must remain within the parameters of the clearance. So, you shouldn't accept a clearance that you can't comply with. If you're at 5,170 feet and scratching in weak lift, do not accept an altitude clearance that requires you to remain above 5,000 feet! Likewise, if you've encountered unexpected sink, advise ATC that you will need a new altitude clearance. It all comes down to COMMUNICATION! I beg to differ that it is nothing like flying an airplane IFR. 90% of flying an airplane IFR includes VMC departures and arrivals, with only a few moments in IMC conditions. Just like a glider. Thanks for the input You're welcome. Now let me add this: to safely fly a glider in IFR conditions, the pilot must be able to walk and chew gum at the same time. Flying a glider effectively on a cross-country is challenging. Flying single-pilot IFR is challenging. Flying a glider on a single-pilot IFR cross-country is extremely challenging. Prerequisites should include many recent hours in both glider cross-countries and IFR procedures. At the risk of speaking for others, glider pilots that fly IFR have huge personal weather minimums. They won't consider flying IFR unless they are certain that they will be able to cancel IFR and continue to their destination under VFR with a significant safety margin. Most pilots will file IFR with no intention of ever flying into a cloud. Instead, they want to be able to fly closer to the cloud than the minimum distances required for VFR. Most IFR cross-countries are in mountain waves, and the risk of going from clear and a million to suddenly being engulfed in a thick cloud is real. Being on an IFR flight plan is a safety measure. Finally, nothing can substitute for good judgment. IFR in gliders can be a valuable tool, but it can easily kill you. Don't even think of doing it unless you are certain that there is no risk from doing it. Actually, your criteria should be the opposite: do it only if you think it is the safer option. Chris Fleming, F2 ATP B-767, CFI-G |
I've done a bit of cloud flying in your neck of the woods in single engine
airplanes but this story could apply to gliders as well. I had departed White Sands Regional under a IFR flight plan to Houston Hobby. Favorable tailwinds were available above 17,000 and there was a towering CU sited just at Pinion VOR suggesting that those tailwinds might be available to me. The WX forecast clearly stated that there was strong capping at 400MB so I didn't expect towering CU's to develop into thunderstorms. I contacted Albuquerque Center with this request, "9238J requests climb to FL180 while holding at Pinion VOR". ABQ center approved the request so I put on oxygen and centered the lift below the 12,000' cloud base in a standard rate turn and started the climb. Even a slow turn of 2 minutes per 360 can affect the inner ear if continued long enough so I was careful to set trim and power to make the airplane as stable as possible. (Note to instrument rated pilots: holding doesn't actually require that you fly a "racetrack" pattern as long as you stay within your clearance limits.) The rate of climb increased to 1500 FPM at cloud base and the little Piper soared to the flight levels allowing me to cruise to east Texas with a 50 knot tailwind. I got a cruise clearance FL180 to FL 240 so I could do a little porpoise flying. There were many other towering CU's along the route so I did a few "diversions for weather" to traverse them. I kept a constant watch on weather advisories lest thunderstorms develop. I figure that utilizing lift saved about 20 gallons of avgas on that flight. Since the flight was conducted far above the operating ceiling of the Piper, I see no reason that a glider couldn't have made the same flight. While IFR/IMC flight in glider is both possible and legal with the right equipment and training, it must be said that the skillset required is quite large and the task is very demanding. Many very experienced instrument pilots regard single pilot IFR in airplanes inadvisable due to the cockpit workload. Adding the mind share needed to soar to that workload makes for a formidable task. I'm interested in glider IFR flight as much as any one. However, I think I would keep it to IFR flight under VMC in low traffic areas. For example, access to airspace above FL180 to permit a climb to the very high CU bases that sometimes develop in the western US. Bill Daniels "Fox Two" wrote in message ps.com... Jacek, I'm anxiously awaiting the article as well! Until it is, though, here are some tasty morsels: There aren't any FAR's that clearly say: "To fly a glider under IFR, you must..." But there are some regs that we can correlate together to find that, yes, flying a glider under IFR is completely legal. Such as: There is no instrument rating available for gliders, as is specified by CFAR § 61.5(b)(8): § 61.5 Certificates and ratings issued under this part. b) The following ratings are placed on a pilot certificate (other than student pilot) when an applicant satisfactorily accomplishes the training and certification requirements for the rating sought: (8) Instrument ratings (on private and commercial pilot certificates only)- (i) Instrument-Airplane. (ii) Instrument-Helicopter. (iii) Instrument-Powered-lift. But, CFAR § 61.3(e)(3) states that a pilot can get certified to fly a glider under IFR: § 61.3 Requirement for certificates, ratings, and authorizations. (e) Instrument rating. No person may act as pilot in command of a civil aircraft under IFR or in weather conditions less than the minimums prescribed for VFR flight unless that person holds: (3) For a glider, a pilot certificate with a glider category rating and an airplane instrument rating. And, CFAR § 61.57(c)(2) specifies the recent pilot experience needed to act as PIC in a glider under IFR: § 61.57 Recent flight experience: Pilot in command. (c) Instrument experience. Except as provided in paragraph (e) of this section, no person may act as pilot in command under IFR or in weather conditions less than the minimums prescribed for VFR, unless within the preceding 6 calendar months, that person has: (2) For the purpose of obtaining instrument experience in a glider, performed and logged under actual or simulated instrument conditions- (i) At least 3 hours of instrument time in flight, of which 1 1/2 hours may be acquired in an airplane or a glider if no passengers are to be carried; or (ii) 3 hours of instrument time in flight in a glider if a passenger is to be carried. Furthermore, CFAR § 61.57(d)(1)(iii) specifies how a glider pilot can get an instrument competency check: § 61.57 Recent flight experience: Pilot in command. (d) Instrument proficiency check. Except as provided in paragraph (e) of this section, a person who does not meet the instrument experience requirements of paragraph (c) of this section within the prescribed time, or within 6 calendar months after the prescribed time, may not serve as pilot in command under IFR or in weather conditions less than the minimums prescribed for VFR until that person passes an instrument proficiency check consisting of a representative number of tasks required by the instrument rating practical test. (1) The instrument proficiency check must be- (iii) For a glider, in a single-engine airplane or a glider. As far as inspections are concerned, CFAR § 91.413(a) does not exempt gliders from the 24-month transponder inspection requirement: § 91.413 ATC transponder tests and inspections. (a) No persons may use an ATC transponder that is specified in 91.215(a), 121.345(c), or §135.143(c) of this chapter unless, within the preceding 24 calendar months, the ATC transponder has been tested and inspected and found to comply with appendix F of part 43 of this chapter. But the altimeter inspection required by CFAR § 91.411 only applies to airplanes and helicopters: § 91.411 Altimeter system and altitude reporting equipment tests and inspections. (a) No person may operate an airplane, or helicopter, in controlled airspace under IFR unless- snip Equipment requirements to certify your glider for IFR flight are determined by the manufacturer, and the FAA. If you certify your glider with an Experimental Airworthiness Certificate, you will need to comply with your certificate's limitations, just like any other experimantal aircraft. As far as the procedure for receiving your IFR clearance is concerned, you can use any approved method, there aren't any special procedures for gliders. And, FYI, I just visited the Schempp-Hirth factory last week where I saw a beautiful new IFR-certified Ventus with a US registration. Yes, it's legal. Chris Fleming, F2 wrote: Yeah, IFR it is....I am very curious about that article, will you include all the FAR's and AIM's for glider flight in IMC? How about xponder check out every 24 months? How about the instrument rating? Is one available for a glider? And yeah, how about the clearance? Do you get a pop-up clearance or , since you are not flying from controlled airport simply have a void time? I would like to be educated in all of those aspects. Thanks, Jacek Washington State |
![]() snoop wrote: Chris, I don't want to make it difficult. Then don't. I was a freight dog, too. I always had to watch everything with a magnifying glass to make sure I was legal to the letter. I understand your mindset. But this isn't that. My point here is I'm still fuzzy on the official guys (FSS, ATC) accepting something as simple as the flight plan for our glider as you described. From an operational viewpoint, it's clear as a bell to me, it's simple. I've received untold numbers of pop up clearances in the past. You're right. FSS/ATC may not have ever received an IFR request from a glider before. But they will likely be excited to do something different. Once I'm on the frequency, I quickly become a celebrity. The controllers are asking me questions purely out of curiosity, and I get funny one liners like: ATC: American 325 climb and maintain 17,000, expect further climb in 20 miles, you have traffic at 11 o'clock 15 miles at FL190, a glider. AMR325: What the h*&% is a glider doing up there?! Me: Descending! My point is that controllers will work with you if you work with them. Fitting a glider into their traffic flow can be a burden to them, so make it less so. Stay away from busy airways. If you need to transit a busy airway, you may need to wait for a few minutes for ATC to make room. Then when you're cleared to proceed, cross the airway quickly so they can use it again. If they need an altitude that you've currently got blocked, if you can, release it back to them to get the transient through. Let's all just get along. There are still MEAs, MOCAs, MVAs, things, that the contollers have to govern who they turn loose in the clouds. How does the local guy work around these. Again it appears quite simple from the operational end, but....... You're scaring me, snoop! Gliders aren't operating anywhere near the MEA! Use some judgment here. As you well know most of these FAA regs have blood written on them. I would have to have the controller himself tell me the TERPs are out the window when it comes to my glider flying IFR. Snoop, TERPS apply to terrain & obstruction clearance during departure and arrival. We're not doing that. We are thousands of feet off the ground with cloudbase being thousands of feet above the ground. We're not flying low IFR; we're flying into an isolated cloud, or flying along the edge of a lenticular. let's get those who do file, and fly their glider IFR, to get their local ATC/FSS people to present a paper, or talk to the local groups, about the procedures and responsibilities of flying our gliders IFR. What do you think we're doing? Perhaps you should take a break from typing, and reread the entire thread. Your questions have been answered. IFR in gliders in legal, and people do it every day. Here's my recommendation to you, snoop. You already know that you learned more on your first night flying freight out of Chicago than you did in all of your previous training. So, take an IFR-equipped glider and fly it IFR in VMC conditions. Take your normal tow, release, and climb several thousand feet. Then call up ATC, pick up an IFR clearance to maneuver in the vicinity. Explore the cloudbase, but don't go into the cloud (for safety). Then cancel IFR, and go home. Viola! IFR in gliders. Small steps. Chris Fleming, F2 |
#29
![]() Fox Two wrote: You're right. FSS/ATC may not have ever received an IFR request from a glider before. But they will likely be excited to do something different. Once I'm on the frequency, I quickly become a celebrity. The controllers are asking me questions purely out of curiosity, and I get funny one liners like: ATC: American 325 climb and maintain 17,000, expect further climb in 20 miles, you have traffic at 11 o'clock 15 miles at FL190, a glider. AMR325: What the h*&% is a glider doing up there?! Me: Descending! Chris, this is the exact reason I'm still looking for the technical answers. You just made about every working pilot reading your celebrity dialouge, pass out. "11o'clock 15 miles", your descending out of who knows what exact altitude, and the big boy is climbing toward you, this would wake everyone up. I would venture that the captain on that AA flights' first thought would be, "we're turning now", then he would ask the center about the accuracy of the gliders' altimeter. You're scaring me, snoop! Gliders aren't operating anywhere near the MEA! Use some judgment here. Chris, I'll give you the benefit of the doubt here and assume you mean that your not doing this near an airway. MEA is an altitude, and although you may be flying in the Flight Levels, MEA's do run from down in the thousands to the flight levels. Snoop, TERPS apply to terrain & obstruction clearance during departure and arrival. We're not doing that. We are thousands of feet off the ground with cloudbase being thousands of feet above the ground. We're not flying low IFR; we're flying into an isolated cloud, or flying along the edge of a lenticular. Chris, I will concur that we're not flying low IFR, and we won't be doing ILS approaches, although I have a glider accident in mind, where the pilot did try to penetrate some LIFR weather and lost. He lived, but there was a lot of serious head scratching on his part. The answers I'm looking for, the fundamental, basic answers we need are, how do I explain my right to be at 19,000ft with an airliner bearing down on me, (your scenario), to the fed that meets me on the ramp after the part 121 captain calls this in. Your a professional pilot, what are your words to all the basic, specific, fundamental, IFR pilot/equipment questions that your going to face? What do you think we're doing? Perhaps you should take a break from typing, and reread the entire thread. Your questions have been answered. IFR in gliders in legal, and people do it every day. Chris, I'm not convinced, and saying people do it everyday, well let's just say I think all USA clubs need to get the donuts out and talk this one up. I know there are people in clubs who can get this discussion going. Here's my recommendation to you, snoop. You already know that you learned more on your first night flying freight out of Chicago than you did in all of your previous training. So, take an IFR-equipped glider and fly it IFR in VMC conditions. Take your normal tow, release, and climb several thousand feet. Then call up ATC, pick up an IFR clearance to maneuver in the vicinity. Explore the cloudbase, but don't go into the cloud (for safety). Then cancel IFR, and go home. Viola! IFR in gliders. Small steps. Chris I would love to turn on a t&b and climb into the cloud, but I want to know that my bases are covered! I want the blessing of the people who would otherwise fry me, and you! It would be fun just to be the celebrity kind of pilot, and forge ahead, but I've found in my world it's been more enjoyable, to find out the facts, do it right, and let the feds go after the uninformed. Later, I'm off to the soaring club! |
#30
![]() snoop wrote: Chris, this is the exact reason I'm still looking for the technical answers. You just made about every working pilot reading your celebrity dialouge, pass out. "11o'clock 15 miles", your descending out of who knows what exact altitude, and the big boy is climbing toward you, this would wake everyone up. I would venture that the captain on that AA flights' first thought would be, "we're turning now", then he would ask the center about the accuracy of the gliders' altimeter. Oh, for God's sake, snoop. You're really beginning to annoy me. If you fly IFR as much as you say you do, you hear that every day. Aircraft A receives a hold down clearance until he is clear of traffic B above. American was thousands of feet below me, climbing to an altitude two thousand feet below me. He saw me on his TCAS. There was no conflict. ATC was providing separation. Everybody was happy. Geez. Chris, I'll give you the benefit of the doubt here and assume you mean that your not doing this near an airway. MEA is an altitude, and although you may be flying in the Flight Levels, MEA's do run from down in the thousands to the flight levels. Snoop, we aren't navigating airways! In fact, no navigation equipment of any kind is required to fly IFR! You need to stop thinking like a 135/121 airplane pilot. You're in a GLIDER. The world of aviation is a big place, and most pilots are only familiar with their little slice of it. You need to think outside of your box. Scroll up to my first message; I've referenced the exact regs that legalize IFR gliders. It is legal. Period. My final case-in point: The Goodyear Blimp flies IFR over football games all of the time. There are tens of thousands of people who are first-person eye witnesses to this fact as they watch the blimp fly in and out of the clouds on a snowy day. Millions more see this on TV. I'm sure that one or two of those fans is a fed. The pilot of the blimp is getting paid. It's a commercial operation with passengers on board. But there is no requirement for that pilot to have an instrument rating of any kind. He might be 1,000 feet AGL, definitely below the lowest minimum IFR altitude for airplanes. He's IFR without a rating, and he's perfectly legal. It's a big world out there, snoop. The rules that apply to airplane 135/121 don't apply to all other types of flying. Going out to the glider club? That's sounds good. I'll join you. Chris Fleming, F2 |
Kid day at the airport... | Jay Honeck | Piloting | 92 | September 20th 05 04:42 AM |
Passing of Richard Miller | [email protected] | Soaring | 5 | April 5th 05 01:54 AM |
Mountain Flying Course: Colorado, Apr, Jun, Aug 2005 | [email protected] | Piloting | 0 | April 3rd 05 08:48 PM |
Four States and the Grand Canyon | Mary Daniel or David Grah | Soaring | 6 | December 6th 04 10:36 AM |
ADV: CPA Mountain Flying Course 2004 Dates | [email protected] | Piloting | 0 | February 13th 04 04:30 AM |
