Silly controller
Old August 26th 06, 02:49 PM posted to rec.aviation.piloting,rec.aviation.ifr
Sam Spade
Default Silly controller
Denny wrote:
.. Watching two branches of the federal government duke it out
could be highly entertaining...
It's all the FAA. They often never talk to each other.
Old August 26th 06, 04:55 PM posted to rec.aviation.piloting,rec.aviation.ifr
Matt Barrow
"Denny" wrote in message
Umm, I would like to see this cancellation scenario happen when the IFR
student is on his check ride with either an FAA examiner or DER in the
plane... Watching two branches of the federal government duke it out
Which two of the three (Judicial, Legislative, Executive)?
Are you one of those modern public school graduates? :~)
Old August 26th 06, 05:07 PM posted to rec.aviation.piloting,rec.aviation.ifr
Christopher C. Stacy
"Steven P. McNicoll" writes:
"Christopher C. Stacy" wrote in message
When he gave you the clearance for the approach, did he say
"Maintain VFR?" If not, you were really IFR.
No. You're really IFR when you hear "Cleared to..."
Like in, "Cleared for the ILS runway 23 at Foobar maintain 2000 until established" ?
Old August 26th 06, 07:12 PM posted to rec.aviation.piloting,rec.aviation.ifr
Robert M. Gary
Or "Cleared to Land"
Word games aside, Steven is right. The difference between being IFR and
VFR in controlled airspace is being told "cleared to foobar".
-Robert
Old August 26th 06, 07:54 PM posted to rec.aviation.piloting,rec.aviation.ifr
Steven P. McNicoll[_1_]
established" ?
No. Like when you picked up your IFR clearance some time prior to that and
heard "Cleared to..."
Old August 27th 06, 11:32 PM posted to rec.aviation.piloting,rec.aviation.ifr
My interpretation of the ATC handbook is that there are three types of
practice approaches:
1) You can be IFR, in which case it works just like any other IFR
operation except that practice approaches are lower priority (you can
be delayed). This comes with a proper IFR clearance (with a clearance
limit) as has been stated in this thread.
2) You can be VFR, but with separation services. Here you get 500 ft
vertical separation from other traffic and standard lateral separation.
The published miss is not authorized unless the controller
specifically approves it, and if he does approve it, separation
services are provided for the missed approach procedure as well. This
comes with the instruction "CLEARED FOR THE APPROACH" or similar.
3) You can be VFR, but without separation services. The missed
approach is again not authorized. This comes with the instruction
"PRACTICE APPROACH APPROVED" or similar.
If you're operating under VFR, the controller is supposed to remind you
by saying "MAINTAIN VFR" at some point, but if the controller forgets,
it doesn't change anything.
If separation services are provided, then the controller must be
informed when to terminate those services. Could this be when the
confusion occurs? What is the terminology for terminating VFR
separation services? I've assumed that many controllers use standard
IFR cancellation terminology for that even when the airplane is
operated under VFR.
Peter
Old August 27th 06, 02:09 AM posted to rec.aviation.piloting,rec.aviation.ifr
Emily[_1_]
I once requested a practice approach with a student, and the controller
asked if I wanted to do it VFR or IFR. I replied that I preferred VFR,
and he gave me an altitude to climb to. I told him that if he wanted us
there, we'd have to do it IFR. His response? "Ok, you're IFR then.
Climb and maintain 5000." It's really hard to teach correct phraseology
to a student with instructions like that. Student and I had a really
long talk on the ground later.
Old August 28th 06, 02:03 AM posted to rec.aviation.piloting,rec.aviation.ifr
Sam Spade
How about this:
Pilot: "SoCal Approach, Piper 1234B is 10 west of Paradise on top at
5,500. Request ILS approach to Chino 26 Right."
ATC: "34B squawk 2133...34B radar contact, fly present heading for the
Chino ILS 26 Right. Descend and maintain 4,000."
Did the controller issue an IFR clearance?
Old August 28th 06, 02:13 AM posted to rec.aviation.piloting,rec.aviation.ifr
A Lieberma
Sam Spade wrote in news:FhrIg.196$c07.193@fed1read04:
How about this:
Request for an ILS approach is not a request for an IFR clearance using
CRAFT as guidelines. You have not met the C part of CRAFT
Nope, you were not cleared, nor were you on an IFR flight. You were VFR in
the beginning and was treated accordingly from what I have been reading.
ATC does not know what is outside YOUR window (VMC or IMC). The above ATC
instructions does not meet the C part of CRAFT (Cleared to)
Allen
Old August 28th 06, 02:17 AM posted to rec.aviation.piloting,rec.aviation.ifr
Jose[_1_]
ATC: "34B squawk 2133...34B radar contact, fly present heading for the Chino ILS 26 Right. Descend and maintain 4,000."
I've had the situation where I've contacted SoCal approach just like
that, VFR, for an approach into STS (which was IFR with nighttime fog).
They gave me a squawk and all, but told me to maintain VFR while they
worked out an actual IFR clearance. At some point I was given a hard
IFR altitude (they used that phrase) and said "you are now IFR". I
don't remember whether they said "cleared to", but I bet they did.
Jose
The monkey turns the crank and thinks he's making the music.
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 04:40 AM
What was controller implying?? Bill J Instrument Flight Rules 65 September 28th 04 12:32 AM
Columns by a Canadian centre controller David Megginson Instrument Flight Rules 1 August 9th 04 10:05 PM
Skyguide traffic controller killed HECTOP Piloting 39 March 3rd 04 01:46 AM
AmeriFlight Crash C J Campbell Piloting 5 December 1st 03 02:13 PM
