Midair near Minden
Old August 29th 06, 07:08 PM posted to rec.aviation.soaring
jb92563
Default Midair near Minden
Here are links with pictures.
http://news.rgj.com/apps/pbcs.dll/ar...0365/1144/NEWS
http://www.aero-news.net/index.cfm?C...-acbbb7a5f04e&
Its interesting to note that the perception is that the glider crashed
into the jet.
Hmmmm......60+ foot span glider doing 50 mph in perfect VFR conditions
at 16,000' above the Minden Area......vs Hawker Jet with 50' span and 2
pilots traveling over 300mph.
So it was the glider that initiated the accident, as opposed to
stringently trained and licensed profesional airline pilots in perfect
VFR conditions outside of controlled airspace that ran down another
aircraft?
See how the public perceives us!!!!!
We are apparently a hazard to comercial aviation.
This should be really interesting, as precidents will be set through
the determination of fault in this accident.
Thanks god hundreds of passengers were not killed, and no one infact
was even seriously injured......but it will be a wakeup call to the FAA
and you can bet they will be obligated to take action to prevent this
sort of thing, or worse, from happening again.
Old August 29th 06, 07:32 PM posted to rec.aviation.soaring
John O. Graybill
Does anyone know whether or not the glider was transponder/mode C
equipped?
Any thoughts about a Reno Class Bravo?
John O. Graybill
Old August 29th 06, 07:44 PM posted to rec.aviation.soaring
Marc Ramsey
equipped?
I don't know for sure, but unlikely, given what I know of the owners and
the circumstances.
Yes. It would pretty much eliminate cross-country soaring out of Air
Sailing and Truckee, and seriously impair soaring out of Minden. If the
accident took place within 30 miles of Reno, I expect this option will
get some discussion...
Marc
Old August 30th 06, 05:09 PM posted to rec.aviation.soaring
Al[_1_]
"jb92563" wrote in message
into the jet.
Sure, just like my cat hit that car doing seventy...
Al G
Old August 29th 06, 07:39 PM posted to rec.aviation.soaring
raulb
I am sure that Chip Gardner is thinking that it is deja vu all over
again. He had a Navy jet (A-4? A-6?) eat 3 feet of his wingtip near
Mt. Palomar about 20 years ago.
Gardner managed to fy back and land at the gliderport at Hemet and the
jet limped back to Miramar NAS with a fiberglass wingtip lodged in one
of his engines.
I remember at the time that Chip said that at the speeds they fly, we
go from being a speck on the windshield to a full target in less than
16 seconds.
Old August 29th 06, 08:37 PM posted to rec.aviation.soaring
Robert Backer
A couple of small corrections here. Chip was flying on Hot Springs
Mountain just east of Warner Springs. The jet was on or near a low
level training route. After the collision, Chip was still able to climb
the LS4 and proposed flying back to Hemet. He was convinced by others
flying nearby that observed the damage, that maybe it would be more
prudent to land at Warner Springs.
Bob
of his engines.
16 seconds.
Old August 29th 06, 09:54 PM posted to rec.aviation.soaring
Mal[_2_]
"Robert Backer" wrote in message
news:IH0Jg.18249$RD.7286@fed1read08...
Mountain just east of Warner Springs. The jet was on or near a low level
training route. After the collision, Chip was still able to climb the LS4
and proposed flying back to Hemet. He was convinced by others flying
nearby that observed the damage, that maybe it would be more prudent to
Bob
of his engines.
16 seconds.
Did they buy Lotto tickets afterwards bloody lucky I say.
Old August 31st 06, 01:07 PM posted to rec.aviation.soaring
jodom
16 seconds is a long time to make an avoidance manuver.
of his engines.
16 seconds.
Old August 31st 06, 06:15 PM posted to rec.aviation.soaring
Jack[_1_]
Effective clearing is a lot harder than it looks.
You might even be able to do a complete loop in 16 seconds in your
aircraft, but that doesn't mean you can find the traffic in 16 sec.,
especially if there is more than one target to deal with, let alone
avoid it safely.
Sixteen seconds is not a long time to scan the inner surface of a globe
whose diameter is measured in miles and from which threats are emerging
at closing speeds of from 200 to 500 kts below 10,000' msl. Above that
level you can raise potential closing speeds to nearly 600 kts, and
still be below Class A.
By the way, with a closing speed of only 300 kts, you have just 12
seconds to close from a mile out. The inner surface of a two-mile
diameter globe cannot be fully scanned in less than 12 seconds, leaving
you less than zero time to react and to maneuver to avoid.
Think of how many aircraft you have seen and subsequently you took some
evasive action (e.g., ten)-- now think of how many of those took no
action to evade you (e.g., seven), presumably because they did not see
you. In this example 70% of the other pilots were unaware of potential
midair collisions. How does that apply to you? Could we assume that you
were also unaware of 70% of potential traffic conflicts? No, because you
are, of course, twice as effective as the average pilot. Therefore you
only missed slightly more than one third of those potentially fatal
conflicts.
To what do we attribute your continued survival? The big-sky concept
works, but not forever. Is today's flight your last? Could be, unless
all of us get serious about the BIG PICTURE of traffic awareness and
avoidance.
Jack
Old September 1st 06, 04:25 AM posted to rec.aviation.soaring
Yuliy Gerchikov
"jodom" wrote in message
Err... How, exactly? -- Yuliy
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 04:40 AM
Minden Vote - Results [email protected] Soaring 1 November 20th 05 06:01 PM
Minden In Two Weeks ADP Soaring 3 August 10th 04 01:51 AM
