Larry Dighera schrieb:
Would that Mode S requirement be a result of the implement ion of outsource ATC? No, why should it? Mode S implementation is very expensive for ATC. It's as I said: They say that in certain regions iof Europe, Mode C reaches its limits. As I don't know anything about it, I have to believe it. From http://www.eurocontrol.int/msa/public/faq/faq.html: Mode S is being deployed because the current SSR systems have reached the limit of their operational capability. This takes the form of exceeded maximum number of targets, RF pollution, lost targets, identity errors and Mode A code shortage. Mode S is therefore a necessary SSR replacement in airspace subject to high levels of traffic density. Stefan |
On Thu, 31 Aug 2006 16:47:21 +0200, Stefan wrote:
Mode S is being deployed because the current SSR systems have reached the limit of their operational capability. This takes the form of exceeded maximum number of targets, RF pollution, lost targets, identity errors and Mode A code shortage. Mode S is therefore a necessary SSR replacement in airspace subject to high levels of traffic density. I've some difficulty understanding this. From reading here, I've been lead to believe that aviation is more common in the US than in the EU. Given this, I have to assume that a locality like the KEWR/KLGA/KJJK area would have a higher aircraft density than anywhere in Europe. No? If so, then how can a locality like that not be suffering from the same problem as that described in the cited text? I fly in this area, and I've never noted identity errors nor have I ever been denied service due to an insufficiency of mode A codes. - Andrew |
wrote in : Larry Dighera schrieb: Would that Mode S requirement be a result of the implemention of outsource ATC? No, why should it? Because the corporation providing ATC services under contract to the government(s) thinks it's a good idea? Mode S implementation is very expensive for ATC. Perhaps the ATC contractor can get the funds necessary to implement Mode S equipment installation from the government(s), and then use the added functionality provided by Mode S to enhance their revenue stream in the future. It's as I said: They say that in certain regions iof Europe, Mode C reaches its limits. As I don't know anything about it, I have to believe it. Either believe it, or do the research necessary to verify the allegation. From http://www.eurocontrol.int/msa/public/faq/faq.html: Mode S is being deployed because the current SSR systems have reached the limit of their operational capability. This takes the form of exceeded maximum number of targets, RF pollution, lost targets, identity errors and Mode A code shortage. Mode S is therefore a necessary SSR replacement in airspace subject to high levels of traffic density. Can European airspace possibly be more congested than that in the US, say Chicago or Los Angeles? |
Stefan wrote:
Bob Noel schrieb: I know the advantages from an ATC POV, but what is the advantage for the aircraft owner? To be allowed to fly in controlled airspace at all? In Europe, Mode S will be mandated, because ATC claims Mode C reaches its limits. This means in the forseeable futu No Mode S, no fly in controlled airspace. Stefan We will see. Such a mandate will meet considerable opposition. Same as GA user fees. Heck, the FAA has not even started any sort of 406 MHh ELT mandate to my knowledge. (USA applicability) Ron Lee |
Ron,
We will see. Such a mandate will meet considerable opposition. Not in Europe. We have seen, here. It has met considerable opposition - and has been mandated nonetheless. -- Thomas Borchert (EDDH) |
Stefan wrote: I know the advantages from an ATC POV, but what is the advantage for the aircraft owner? To be allowed to fly in controlled airspace at all? In Europe, Mode S will be mandated, because ATC claims Mode C reaches its limits. This means in the forseeable futu No Mode S, no fly in controlled airspace. Sorry. I should have clarified that my question was applicable to the US NAS. I do understand the European requirements for Mode S, 8.33, ACAS, etc etc. But in the US, Mode S is still just a solution looking for a problem. -- Bob Noel Looking for a sig the lawyers will hate |
![]() "Mark Manes" wrote FSM where I'mbased had TIS for the first year after I installed the Garmin but theyupgraded the radar (to ASR 11, I believe) and are not going to turn TIS onfor whatever reason.MarkN28409WC5I"Andrew Gideon" wrote in messagenews ![]() 29 Aug 2006 23:34:27 -0400, Doug Vetter wrote: The FAA is continuing to invest in Mode-S radars (the ASR-11 is replacing the ASR 7, 8, and 9 units that currently support TIS), so an investmentin the airborne component is still a wise move and will be for MANY years. Aside from TIS, what is the benefit (either to the pilot or ATC) of modeS? - Andrew Dood, buy a space, or sumpthin' ! g -- Jim in NC |
Andrew Gideon wrote:
On Tue, 29 Aug 2006 23:34:27 -0400, Doug Vetter wrote: The FAA is continuing to invest in Mode-S radars (the ASR-11 is replacing the ASR 7, 8, and 9 units that currently support TIS), so an investment in the airborne component is still a wise move and will be for MANY years. Aside from TIS, what is the benefit (either to the pilot or ATC) of mode S? - Andrew Here are a few advantages of Mode-S over Mode-A: 1) Selective interrogations. Because the mode-s airborne component has a unique address, any ground or airborne interrogator may request your particular transponder (and only your transponder) to reply. It learns your unique ID by using a broadcast request called "all call". This is helpful on a technical level where the radar is attempting to acquire the position of many aircraft that may be on or near the same radial from the radar site (say, for example, three aircraft on the 237 radial from the radar antenna at 5, 10, and 40 miles away). The result is less of a chance for ghosting and other radar anomalies. For example, I used to have a problem when talking to Phili approach near the Yardley VOR where they used to report a ghost image of my aircraft about a mile away. They haven't reported the problem since I upgraded to Mode-S. This increases the distance at which a transponder may be identified (thus increasing the effective range of the radar) because the site can keep the aircraft at 5 and 10 miles quiet while it listens for a reply from the aircraft 40 miles out. There are some practical limitations to this benefit, mostly caused by the continued use of mode-a transponders, but hopefully that won't be the case forever. 2) Support for Ground mode, which replies only with the unique ID (Mode-S ID or Tail Number) and a software flag that tells the interrogator the unit is on the ground. It does NOT respond with the currently-entered squawk code (1200 or otherwise). This is a nice feature simply because it helps identify your aircraft to ground radar (like that deployed for testing at Providence, RI), and because it prevents the need to turn the transponder off to prevent squawking an old code after landing (most important to IFR pilots). The great thing about the 330 in particular is that the unit switches modes automatically based on either a landing gear position switch or (in the case of our fixed gear 172) the speed of the aircraft as derived from a GPS' serial data interface. It even knows whether to switch from ALT to GND or from ALT to STBY, based on recent activity, or so said a Garmin tech rep. 3) Although this is not unique to the 330 or Mode-S, I mention it because I've seen the test results with my own eyes on my 330 -- specifically, the ability to respond to a interrogation rate at 100% of the theoretical maximum, while most older "analog" transponders can only manage 40% of that rate before becoming saturated. The ability of a transponder to handle a high reply rate will become more important as more aircraft are equipped with systems such as TCAS and Skywatch that actively interrogate targets much in the same way ground facilities do. For more info, check out the 330 review on my site. Click through: Aviation-Articles-Reviews-Garmin 396 -Doug -------------------- Doug Vetter, ATP/CFI http://www.dvatp.com -------------------- |
On Thu, 31 Aug 2006 23:32:47 -0400, Doug Vetter wrote:
The ability of a transponder to handle a high reply rate will become more important as more aircraft are equipped with systems such as TCAS and Skywatch that actively interrogate targets much in the same way ground facilities do. Let's assume that a [mode c] transponder is being interrogated at a rate higher than that at which it can respond. Does this matter? If the transponder is responding as quickly as it can (let's pick a hypothetic 10/second), while it is receiving [a hypothetic] 20 interrogations/second, won't each interrogator still see the 10 responses per second and therefore "see" responses to its own interrogations? Or is there some unique mapping from a specific interrogation to the specific reply? - Andrew |
18 Oct 2005 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | October 19th 05 02:19 AM |
NTSB: USAF included? | Larry Dighera | Piloting | 10 | September 11th 05 10:33 AM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 12th 03 11:01 PM |
