Can EFIS / EFMS lead to removing basic safety checks?
Old September 2nd 06, 01:30 AM posted to rec.aviation.ifr
Jim Carter[_1_]
Default Can EFIS / EFMS lead to removing basic safety checks?
This question is the result of the wrong runway issue at LEX last
weekend.
Not having flown an EFIS or EFMS myself, I'm not sure of the "into
position checklist items". For example, in a standard steam-gauge panel
one of the last things we check is to align the directional gyro with
the runway heading and compass. With an EFIS or EFMS, is there any such
last minute check, or is the heading assumed to be correct because it
was aligned by the GPS when the bird came out of the chocks?
If there is no requirement to manually align and verify runway heading,
compass, and EFIS/EFMS then our technological advances have
inadvertently removed one of our heretofore unrecognized safety checks.
I heard some retired commuter pilot on the news last weekend suggesting
that the only way to prevent this in the future is to put traffic lights
(stop / go) on the end of every runway. I absolutely got the impression
that he was there to convince the public that it is almost impossible
for the pilots to get it right and the lack of the traffic signal was
the whole cause of the problem. Sort of the typical "not my fault"
attitude.
Old September 2nd 06, 02:11 AM posted to rec.aviation.ifr
Beavis[_1_]
In article 004101c6ce26$e77966d0$4001a8c0@omnibook6100,
No, the GPS doesn't align the heading gyro -- an electronic flux gate
does. There are two independent heading gyros, and two independent flux
gates to set them. If there's a disagreement of more than a few
degrees, an error flag will come up, and the crew will troubleshoot to
see where the error lies.
So yes, on that type of system, the heading is assumed to be correct.
The odds of both flux gates failing at exactly the same time, but to
exactly the same erroneous heading, are about nil.
Old September 2nd 06, 02:23 AM posted to rec.aviation.ifr
Jose[_1_]
Are the flux gate sensors located near each other?
Jose
Robert M. Gary
I saw this demoed somewhere (but I don't remember where). It was pretty
cool. There was a row of read lights across the taxiway access to the
runway until cleared for takeoff.
-Robert
Old September 2nd 06, 05:07 AM posted to rec.aviation.ifr
Beavis[_1_]
Depends on the model of airplane, I'm sure. Though I don't know the CRJ
enough to answer with respect to it, on my airplane there's one near
each wingtip, purposely placed as far from interference as possible.
Old September 2nd 06, 05:41 AM posted to rec.aviation.ifr
Jose[_1_]
I would expect that for those models where the sensors are close
together, the right stray magnetism (whether deliberate or accidental)
could cause both redundant systems to have the same error.
Jose
Old September 2nd 06, 10:02 AM posted to rec.aviation.ifr
Sam Spade
Jose
A whole lot of design work goes into isolating those flux gates. And,
most of the mainline airliners have three IRUs, so they don't even use
flux gates. Everything is in true, then automatically converted to
local magnetic for display purposes.
Old September 2nd 06, 10:03 AM posted to rec.aviation.ifr
Sam Spade
the whole cause of the problem. Sort of the typical "not my fault" attitude.
If he thinks that is the only way, he is clueless.
Old September 2nd 06, 10:04 AM posted to rec.aviation.ifr
Sam Spade
-Robert
That has been tried off and on for years, with less than great success.
It is a saturation job for someone in the tower to keep the system
working. Sooner or later, a wrong signal is sent.
Old September 2nd 06, 02:31 PM posted to rec.aviation.ifr
Jim Carter[_1_]
-----Original Message-----
Posted At: Saturday, September 02, 2006 4:03 AM
Posted To: rec.aviation.ifr
Conversation: Can EFIS / EFMS lead to removing basic safety checks?
Subject: Can EFIS / EFMS lead to removing basic safety checks?
suggesting
lights
impression
impossible
was
attitude.
My sentiments exactly Sam.
My question was more along the lines of new systems removing old safety
checks, but no one seems to be addressing that. Is there any physical
action that must be taken as an aircraft with and EFIS / EFMS moves into
position for takeoff to assure that the compass / gyro (or suitable
substitute) / display all agree on the runway heading? Could the modern
glass cockpits be setting us up for incidents or accidents because
insidious little actions we used to take with analog panels aren't
necessary any more?
