#31
Robert M. Gary wrote:
Sam Spade wrote: I've never used TIS, but I heard before what you state. Problem is the limited coverage and I understand the feds can turn it off if the need arises. They can't fiddle with TCAS. They can also turn of GPS. The Europeans are very concerned about this. -Robert But, they have turned off TIS whereas they haven' turned off GPS. The former is low-level tactical stuff at the air traffic facility level; the latter is at the presidential and joint chiefs staff level. The Europeans have been known to cry about falling sky on more than one occasion. Their "concerns" about GPS defy logic for those involved in aviation planning and system risk assessment. |
#32
But when it all goes TU, a heading and time to find by DR,
the place within fuel endurance that is VFR, and being prepared to just hold an altitude and heading, and have an idea of where you are when you break out an hour or two later at 8,000 feet 300 miles from you last knew your position and then find an airport. I would expect ATC to notice the transponder failed and try to call, and after no response, track raw returns and clear everything out of your path. I would expect 2 F-16s to joint up and lead the way to someplace or shoot my ass down if I was headed toward a major target, er city. "Robert M. Gary" wrote in message oups.com... | | Jim Macklin wrote: | Mt point is that the G1000 is easy that the pilot WILL | become totally dependent on the nav display for situational | awareness. If it fails, the pilot will not have any idea on | how or where to go. Backup battery is fine, but in many | areas there isn't an airport of any king within 30 minutes, | and an IFR approach will be difficult. I'm not worried | about the control being lost, I'm worried about the pilot | being lost. | | But again, I think you would notice both screens going blank. Teaching | students to look for errors in displayed pitch is probably not useful | (or probable). | | An IFR approach with a totally dead G1000 isn't possible under any | situation. You have no VORs, no GPSs, and only can talk on 121.5. You | just can't shoot an approach with the backup A/S, altimeter, and | attitude indicator. | | The chance of a total failure of the G1000 is much less than the chance | that my Mooney loses its only electrical bus and my handheld GPS fails | at the same time. | | All that being said, I really don't see a situation where a student | becomes dis-engaged from the system. Flying the G1000 system can be | demanding. Flying an ILS in my old Mooney is (in many ways) much easier | than programming the approach sequence in the G1000. The G1000 may be | safer but the Mooney does not require as much pilot attention. | | -Robert | |
#33
"Jim Macklin" wrote:
I would expect 2 F-16s to joint up Not within 50 feet of the aircraft or for 8 hours before engine start. |
#34
You can see 50 feet in a formation, even in a cloud.
"Roy Smith" wrote in message ... | "Jim Macklin" wrote: | I would expect 2 F-16s to joint up | | Not within 50 feet of the aircraft or for 8 hours before engine start. |
#35
That's not what Roy meant.
He must know more about "jointing up" than we senior citizens. :-) My late brother-in-law said a SAC rule was: "No smoking within 24 hours of flying, and No drinking within 50 feet of an airplane." "Jim Macklin" wrote in message news:WS5Kg.6624$SZ3.5252@dukeread04... You can see 50 feet in a formation, even in a cloud. "Roy Smith" wrote in message ... | "Jim Macklin" wrote: | I would expect 2 F-16s to joint up | | Not within 50 feet of the aircraft or for 8 hours before engine start. |
#36
It is hard to proofread your own work. I didn't see the
typo, joint instead of join. Missed his humor, too. "John R. Copeland" wrote in message news ![]() He must know more about "jointing up" than we senior citizens. :-) My late brother-in-law said a SAC rule was: "No smoking within 24 hours of flying, and No drinking within 50 feet of an airplane." "Jim Macklin" wrote in message news:WS5Kg.6624$SZ3.5252@dukeread04... You can see 50 feet in a formation, even in a cloud. "Roy Smith" wrote in message ... | "Jim Macklin" wrote: | I would expect 2 F-16s to joint up | | Not within 50 feet of the aircraft or for 8 hours before engine start. |
#37
![]() Jim Macklin wrote: But when it all goes TU, a heading and time to find by DR, the place within fuel endurance that is VFR, and being prepared to just hold an altitude and heading, and have an idea of where you are when you break out an hour or two later at 8,000 feet 300 miles from you last knew your position and then find an airport. That's just basic IFR training. The same thing can happen in a steam gauge airplane. The only difference is that G1000 has more backups. If you lose your single alternator in a Bonanza and you're IMC for an hour or so, short of a handheld, you're in the same situation. However, the original discussion was about second guessing the accuracy of the information. That is critical in steam gauges since they often fail in strange ways (like my night IMC "tilted but functional AI"). However, its MUCH less likely in the G1000. In the G1000 you'll either get red X's or, worse case, blank screen, but not slightly off data. -Robert |
#38
You're missing the point, the G1000 displays some much
information in picture form, the pilot WILL almost certainly come to rely on the system to work and stop doing that "basic IFR" thinking. Sort of like pilots forget to check the runway heading. With steam gauges, the pilot is forced to THINK about the navigation situation, with the G1000 thinking is done by the machine. "Robert M. Gary" wrote in message oups.com... | | Jim Macklin wrote: | But when it all goes TU, a heading and time to find by DR, | the place within fuel endurance that is VFR, and being | prepared to just hold an altitude and heading, and have an | idea of where you are when you break out an hour or two | later at 8,000 feet 300 miles from you last knew your | position and then find an airport. | | That's just basic IFR training. The same thing can happen in a steam | gauge airplane. The only difference is that G1000 has more backups. If | you lose your single alternator in a Bonanza and you're IMC for an hour | or so, short of a handheld, you're in the same situation. | However, the original discussion was about second guessing the accuracy | of the information. That is critical in steam gauges since they often | fail in strange ways (like my night IMC "tilted but functional AI"). | However, its MUCH less likely in the G1000. In the G1000 you'll either | get red X's or, worse case, blank screen, but not slightly off data. | | -Robert | |
#40
![]() "Jim Macklin" wrote in message news:_bYJg.6559$SZ3.6391@dukeread04... You'd need ARNIC or remote AI and HSI, either mechanical or electronic, that appears to be a cabin class piece of equipment. (Is that two sentences there?) Not at all. Compare this AHRS to the ones that do, in fact, typically go into cabin class/turbine stuff. "Matt Barrow" wrote in message ... | The solid state gyros are the best thing IMHO, the weakness | in the small GA airplanes is the poor sensitivity and | accuracy of the gyros and the small size of the displays. | | Something like this might be more better! | http://www.xbow.com/Products/product...ls.aspx?sid=59 | | Too quick on the SEND button | | I was wondering if these could replace the mechanical gyros even if you're | still running steam gauges? |
IPC G1000 | [email protected] | Instrument Flight Rules | 38 | September 3rd 06 12:22 AM |
Steam guages | [email protected] | Instrument Flight Rules | 14 | February 5th 05 04:58 AM |
