Sounds like poor planning if you don't start your final glide early enough
to get back before sunset and you don't have lights. Mike Schumann "Marc Ramsey" wrote in message ... Doug Haluza wrote: I agree that night flight withing gliding distance of a lighted airport is not that dangerous(I would probably do it if I could). That is why I commented specifically about night cross-country flight in gliders. Night VFR in airplanes has been shown to be many times more dangerous than Day VFR in the accident record. I would only expect the situation to be worse without an engine running. The vast majority of landings after legal sunset are the result of long final glides that started before sunset. These are not "night cross-country flight", except in the legal sense, and would likely have aborted much earlier if there was doubt about reaching the destination airport. Legally, they absolutely should be equipped with position lights, but it is hardly dangerous (and I know of a few people who have installed lights for precisely this reason). In fact there are a few places (Tonopah comes to mind) where it would be more dangerous to abort the final glide at sunset, and try to find someplace else to land, than it would be to just continue... Marc |
Mike Schumann wrote:
Sounds like poor planning if you don't start your final glide early enough to get back before sunset and you don't have lights. We aren't all perfect, like you obviously are... |
Marc Ramsey wrote:
Mike Schumann wrote: Sounds like poor planning if you don't start your final glide early enough to get back before sunset and you don't have lights. We aren't all perfect, like you obviously are... Why would planning to meet an arrival time be any more demanding than the other planning and decision making that glider pilots do? It's not a matter of perfection, it's a matter of priorities. Jack |
![]() Marc Ramsey wrote: lights, but it is hardly dangerous (and I know of a few people who have installed lights for precisely this reason). In fact there are a few So Mark, any chance of enlighetning(!) us about these installations? I'm very interested in finding out how it was done both technically and of course the legalities for my Standard airworthiness ASH-26E. Thanks, -Tom |
![]() "5Z" wrote in message oups.com... Marc Ramsey wrote: lights, but it is hardly dangerous (and I know of a few people who have installed lights for precisely this reason). In fact there are a few So Mark, any chance of enlighetning(!) us about these installations? I'm very interested in finding out how it was done both technically and of course the legalities for my Standard airworthiness ASH-26E. Thanks, -Tom There was a long thread on rec.aviation.homebuilding last year about home made LED position lights. It turned out that the FAA specs are pretty lenient - easily met with high-brightness LED's. The gist is that if you met the FAA angular, brightness and color specifications, you could build your own lights and get them signed of - at least for an experimental airworthiness certificate. I have seen pictures of glider winglets with red or green plastic (Plexi?) tips that had high brightness LED's imbedded in them. Looking at the current draw of these LED arrays it appears that a couple of "D" size lithium batteries in each winglet would power them for 12 - 24 hours. That would mean they could be left on for the entire flight so no in-wing wiring or switches would be needed. There is also a Nimbus 4DM in, I think, Argentina with an array of ultra high brightness Luxeon white LED's on the landing gear as a landing light. I doubt even these would actually light up a runway but they would be bright enough to produce visible reflections from runway stripes and edge reflectors. Bill Daniels |
Interesting. will these LED lights can also help the more common issue
of visibility during day time? Ramy Bill Daniels wrote: "5Z" wrote in message oups.com... Marc Ramsey wrote: lights, but it is hardly dangerous (and I know of a few people who have installed lights for precisely this reason). In fact there are a few So Mark, any chance of enlighetning(!) us about these installations? I'm very interested in finding out how it was done both technically and of course the legalities for my Standard airworthiness ASH-26E. Thanks, -Tom There was a long thread on rec.aviation.homebuilding last year about home made LED position lights. It turned out that the FAA specs are pretty lenient - easily met with high-brightness LED's. The gist is that if you met the FAA angular, brightness and color specifications, you could build your own lights and get them signed of - at least for an experimental airworthiness certificate. I have seen pictures of glider winglets with red or green plastic (Plexi?) tips that had high brightness LED's imbedded in them. Looking at the current draw of these LED arrays it appears that a couple of "D" size lithium batteries in each winglet would power them for 12 - 24 hours. That would mean they could be left on for the entire flight so no in-wing wiring or switches would be needed. There is also a Nimbus 4DM in, I think, Argentina with an array of ultra high brightness Luxeon white LED's on the landing gear as a landing light. I doubt even these would actually light up a runway but they would be bright enough to produce visible reflections from runway stripes and edge reflectors. Bill Daniels |
The requirements are given in AC 20-74, but I would not describe them
as "lenient - easily met." I agree that LED's could be a good solution, but developing and testing a LED system for an aircraft installation is not for the faint of heart. You can dowload it he http://tinyurl.com/fm6df. BTW, wouldnt adding position lights on the wingtips violate the span limits for span limited classes (15m, 18m, 20m)? Bill Daniels wrote: "5Z" wrote in message oups.com... Marc Ramsey wrote: lights, but it is hardly dangerous (and I know of a few people who have installed lights for precisely this reason). In fact there are a few So Mark, any chance of enlighetning(!) us about these installations? I'm very interested in finding out how it was done both technically and of course the legalities for my Standard airworthiness ASH-26E. Thanks, -Tom There was a long thread on rec.aviation.homebuilding last year about home made LED position lights. It turned out that the FAA specs are pretty with high-brightness LED's. The gist is that if you met the FAA angular, brightness and color specifications, you could build your own lights and get them signed of - at least for an experimental airworthiness certificate. I have seen pictures of glider winglets with red or green plastic (Plexi?) tips that had high brightness LED's imbedded in them. Looking at the current draw of these LED arrays it appears that a couple of "D" size lithium batteries in each winglet would power them for 12 - 24 hours. That would mean they could be left on for the entire flight so no in-wing wiring or switches would be needed. There is also a Nimbus 4DM in, I think, Argentina with an array of ultra high brightness Luxeon white LED's on the landing gear as a landing light. I doubt even these would actually light up a runway but they would be bright enough to produce visible reflections from runway stripes and edge reflectors. Bill Daniels |
5Z wrote:
Marc Ramsey wrote: lights, but it is hardly dangerous (and I know of a few people who have installed lights for precisely this reason). In fact there are a few So Mark, any chance of enlighetning(!) us about these installations? I'm very interested in finding out how it was done both technically and of course the legalities for my Standard airworthiness ASH-26E. Actually, I understand that Schleicher is one of the companies that will install the necessary wiring, and even provide an LED-based solution. Just order a new one, and I'm sure they'll be happy to help you 8^) Marc |
Night flight legally begins after twilight (not sunset). I wasn't
talking about final glides, I was talking about making long flights in the dark using wave or ridge. Frankly, I think this would not be worth the substantially increased risk, and we should not encourage it by giving recognition for this. We dropped endurance records for gliding when the records were measured in days for the same reason. So assuming most people agree that Night X/C in gliders is not wise, then we need to look at whether we want to encourage people to install position lights so they can fly for a few extra minutes between sunset and twilight. Or should we discourage this so they can spend their money installing transponders, or other safety equipment. Marc Ramsey wrote: Doug Haluza wrote: I agree that night flight withing gliding distance of a lighted airport is not that dangerous(I would probably do it if I could). That is why I commented specifically about night cross-country flight in gliders. Night VFR in airplanes has been shown to be many times more dangerous than Day VFR in the accident record. I would only expect the situation to be worse without an engine running. The vast majority of landings after legal sunset are the result of long final glides that started before sunset. These are not "night cross-country flight", except in the legal sense, and would likely have aborted much earlier if there was doubt about reaching the destination airport. Legally, they absolutely should be equipped with position lights, but it is hardly dangerous (and I know of a few people who have installed lights for precisely this reason). In fact there are a few places (Tonopah comes to mind) where it would be more dangerous to abort the final glide at sunset, and try to find someplace else to land, than it would be to just continue... Marc |
![]() Doug Haluza wrote: So assuming most people agree that Night X/C in gliders is not wise, then we need to look at whether we want to encourage people to install position lights so they can fly for a few extra minutes between sunset and twilight. Or should we discourage this so they can spend their money installing transponders, or other safety equipment. I can see a properly equipped two seater making a 24 or more hour flight in the Andes wave in relatively safety, as long as the pilots figure out how to stay warm. The key would be to have enough lighted airfields available for a safe glide. As for another comment about lights increasing the span: I think that with LEDs, one could flush mount several at strategic places in the leading edge and around the wingtip. -Tom |
For Keith Willshaw... | robert arndt | Military Aviation | 253 | July 6th 04 05:18 AM |
S-TEC 60-2 audio warning | Julian Scarfe | Owning | 7 | March 1st 04 08:11 PM |
