At one point in time, my flying club had 10 planes, from a 150 to a
bonanza. I was able to fly all but the taildragger and the bonanza at the time. Now, with a tailwheel endorsement and HP signoff, I could have flown those two as well. Cessna 150/152, 172, 177, Warrior, Archer, Arrow, Grumman Tiger and a Mooney 20-E Its all about having the checklists and proper performance data right there. I had a checkride in each plane from an instructor. I was considered current by our rules in all. Rather than memorizing ALL the performance data for a given plane, you review it before flight, and know your speeds based on reference to the checklist. Even the airline guys have different speeds based on aircraft weight, and have to look itup on a flight by flight basis. It's a non issue in my mind (multiple currency) Dave wrote: Hi guys, another question. What are the most commonly-held views on flying more than one make and model of aircraft? Take the example of a 172 and a Warrior. Clearly the aircraft are different and the best solution would be to fly only one make and model, but the reality of plane rental is that if you are checked out and current in more than one aircraft, you have more flexibility in terms of when you can go flying, which means more fun and more overall currency. At what experience level is it generally seen as sensible to regularly fly two different makes and models of plane? Is this a big deal or not? Tom |
says... Dave Doe wrote: In article .com, says... Hi guys, another question. What are the most commonly-held views on flying more than one make and model of aircraft? Take the example of a 172 and a Warrior. Clearly the aircraft are different and the best solution would be to fly only one make and model, but the reality of plane rental is that if you are checked out and current in more than one aircraft, you have more flexibility in terms of when you can go flying, which means more fun and more overall currency. At what experience level is it generally seen as sensible to regularly fly two different makes and models of plane? Is this a big deal or not? I think it's fine - once you have your PPL! ie I don't think it's a good idea to mix plane types while a student pilot. Why not? As I posted earlier, I think it is a great idea. I'd flown two fairly different airplanes before I soloed! And no, I didn't take a long time to solo. Because when you're learning to fly - that's what you should be concentrating on - not learning to adjust and fly a different type aircraft, as well. Question back at you: why do you think it's a great idea? - and another, since you mentioned it didn't take long for you to solo - how long might that be: ![]() -- Duncan |
Dave Doe wrote:
Because when you're learning to fly - that's what you should be concentrating on - not learning to adjust and fly a different type aircraft, as well. I agree, you should be learning to fly, not learning to fly just a C150 or whatever your training aircraft happens to be. Question back at you: why do you think it's a great idea? - and another, since you mentioned it didn't take long for you to solo - how long might that be: ![]() I posted earlier why I think it is a good idea. 8.2 hours. Matt |
Dave Doe wrote: I think it's fine - once you have your PPL! ie I don't think it's a good idea to mix plane types while a student pilot. Why not? As I posted earlier, I think it is a great idea. I'd flown two fairly different airplanes before I soloed! And no, I didn't take a long time to solo. Because when you're learning to fly - that's what you should be concentrating on - not learning to adjust and fly a different type aircraft, as well. That's part of flying too. Question back at you: why do you think it's a great idea? The CFI gets to see if the student is flying by rote or actually being a pilot - and another, since you mentioned it didn't take long for you to solo - how long might that be: ![]() 8 hours to solo, 48 hours to ASEL. -- Bob Noel Looking for a sig the lawyers will hate |
Dave Doe wrote: At what experience level is it generally seen as sensible to regularly fly two different makes and models of plane? Is this a big deal or not? I think it's fine - once you have your PPL! ie I don't think it's a good idea to mix plane types while a student pilot. My CFI would do that regularly with her students - but normally after first solo. A 172 and a warrior simply aren't that different. btw - my CFI would also take up a passenger or two so that that I (the student) would not get used to the weight configuration and get surprised when flying solo. -- Bob Noel Looking for a sig the lawyers will hate |
Dave Doe wrote:
I think it's fine - once you have your PPL! ie I don't think it's a good idea to mix plane types while a student pilot. Fly one airplane, and only the one you're currently flying, at a time. While attending a Part 141 school, I swapped between (3) differently equipped PA28's with AI's calibrated in knots. At 20 hours, I changed to a BE23 with an AI in MPH, and took my check ride @ 47 hours. I was required to give a ~30 minute presentation to each instructor on the systems and flying (V speeds, emergency procedures, etc...) differences, using the POH's as visual aids. None of the instructors had previously flown any Beech 23 family aircraft. I made laminated V-speed and extra checklists that were offered to each instructor and the DE. In hindsight, I think the extra homework was beneficial, and an excellent experience. Both aircraft became that much more detailed in my mind. A great example learned while actually flying involved stalls. Using the stall recovery technique for the Warrior on the Sundowner resulted in an unwanted pitch down attitude, while gently relaxing the elevator pressure worked perfectly. The Sundowner also needed slightly different inputs to slip, when compared to the Piper. I believe that I was a much better pilot when the DE arrived for the PPL ride, because I felt like I _really _ knew the aircraft, in addition to being able to execute maneuvers. All in all, I think changing aircraft can actually be good, if the student is willing and able to put in the proper effort. |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Where are the CFIG's? | Michael | Soaring | 10 | August 19th 03 12:23 AM |
