Yes, this is an interesting point. Did they say "practice approach approved, maintain VFR", or did they
say "cleared for the approach"? If it's a practice approach in a VFR environment, it's not all that unusual to get altitude restrictions, especially to keep you above the VFR traffic pattern, if they can't work you in. Mike Michelle P wrote: If you are operating in VMC and practicing approaches you are operating on IFR and VFR rules. You will have VFR conflicts and a big bang in the sky is bad, follow the controller. If you were in IMC this would have been a different story. Michelle Peter R. wrote: Today I was practicing a GPS approach and had been cleared for the approach with the normal, "Cessna XXX, cross ELESE at 3,000, cleared GPS 15 approach." A minute or so later the controllers switched positions and another one took over that slice of airspace. The new one came on frequency and called my aircraft with, "Cessna XXX, traffic one o'clock, 2,500 and two miles, southbound" (the traffic was was crossing my path right to left underneath me). I replied, "Negative traffic" to which he responded, "Maintain 3,000." Being momentarily confused, I called to clarify the altitude restriction. The controller responded rather tersely that he wanted me at 3,000 for traffic avoidance. Should the controller have canceled my approach clearance first, then issued the altitude restriction? I was initially confused because I still had 5 miles at 3,000 feet before stepping down to the next altitude as part of the approach, and it seemed that his first call was simply reinforcing the altitude minimums on the approach (that is, until he responded in a terse manner that he wanted to keep me there without ever rescinding my approach clearance). |
On Sun, 05 Dec 2004 18:43:20 GMT, Mike Adams wrote:
Yes, this is an interesting point. Did they say "practice approach approved, maintain VFR", or did they say "cleared for the approach"? If it's a practice approach in a VFR environment, it's not all that unusual to get altitude restrictions, especially to keep you above the VFR traffic pattern, if they can't work you in. Hmmm, never got a practice approach approved..... I have always received cleared for the "type of approach" approach when I am doing approaches under VMC. Maybe practice approach is a regional thing? Allen |
A Lieberman wrote:
On Sun, 05 Dec 2004 18:43:20 GMT, Mike Adams wrote: Yes, this is an interesting point. Did they say "practice approach approved, maintain VFR", or did they say "cleared for the approach"? If it's a practice approach in a VFR environment, it's not all that unusual to get altitude restrictions, especially to keep you above the VFR traffic pattern, if they can't work you in. Hmmm, never got a practice approach approved..... I have always received cleared for the "type of approach" approach when I am doing approaches under VMC. Maybe practice approach is a regional thing? Allen Maybe so. My experience is mostly with the Phoenix Tracon, and they have a standard litany, "Practice approach approved. No separation services provided. Maintain VFR.", which to me has always seemed distinct from the normal IFR "cleared for the approach" terminology. I looked in the AIM, and there's some words on practice approaches in 4-3-21, but I didn't see anything on communications terminology. Mike |
![]() "Mike Adams" wrote in message news:AnKsd.176820$bk1.47553@fed1read05... Hmmm, never got a practice approach approved..... I have always received cleared for the "type of approach" approach when I am doing approaches under VMC. Maybe practice approach is a regional thing? Maybe so. My experience is mostly with the Phoenix Tracon, and they have a standard litany, "Practice approach approved. No separation services provided. Maintain VFR.", which to me has always seemed distinct from the normal IFR "cleared for the approach" terminology. I looked in the AIM, and there's some words on practice approaches in 4-3-21, but I didn't see anything on communications terminology. It's standard phraseology where separation services are not provided to VFR aircraft practicing instrument approaches. FAA Order 7110.65P Air Traffic Control Chapter 4. IFR Section 8. Approach Clearance Procedures 4-8-11. PRACTICE APPROACHES Except for military aircraft operating at military airfields, ensure that neither VFR nor IFR practice approaches disrupt the flow of other arriving and departing IFR or VFR aircraft. Authorize, withdraw authorization, or refuse to authorize practice approaches as traffic conditions require. Normally, approaches in progress should not be terminated. NOTE- The priority afforded other aircraft over practice instrument approaches is not intended to be so rigidly applied that it causes grossly inefficient application of services. a. Separation. 1. IFR aircraft practicing instrument approaches shall be afforded standard separation in accordance with Chapter 3, Chapter 4, Chapter 5, Chapter 6, and Chapter 7 minima until: (a) The aircraft lands, and the flight is terminated, or (b) The pilot cancels the flight plan. 2. Where procedures require application of IFR separation to VFR aircraft practicing instrument approaches, standard IFR separation in accordance with Chapter 3, Chapter 4, Chapter 5, Chapter 6, and Chapter 7 shall be provided. Controller responsibility for separation begins at the point where the approach clearance becomes effective. Except for heavy aircraft/B757, 500 feet vertical separation may be applied between VFR aircraft and between a VFR and an IFR aircraft. REFERENCE- FAAO 7210.3, Practice Instrument Approaches, Para 6-4-4. FAAO 7210.3, Practice Instrument Approaches, Para 10-4-5. 3. Where separation services are not provided to VFR aircraft practicing instrument approaches, the controller shall; (a) Instruct the pilot to maintain VFR. (b) Advise the pilot that separation services are not provided. PHRASEOLOGY- "(Aircraft identification) MAINTAIN VFR, PRACTICE APPROACH APPROVED, NO SEPARATION SERVICES PROVIDED." (c) Provide traffic information or advise the pilot to contact the appropriate facility. 4. If an altitude is assigned, including at or above/below altitudes, the altitude specified must meet MVA, minimum safe altitude, or minimum IFR altitude criteria. REFERENCE- FAAO 7110.65, Altitude Assignments, Para 7-7-5. 5. All VFR aircraft shall be instructed to maintain VFR on initial contact or as soon as possible thereafter. NOTE- This advisory is intended to remind the pilot that even though ATC is providing IFR-type instructions, the pilot is responsible for compliance with the applicable parts of the CFR governing VFR flight. b. Missed Approaches. 1. Unless alternate instructions have been issued, IFR aircraft are automatically authorized to execute the missed approach depicted for the instrument approach being flown. REFERENCE- FAAO 7110.65, Missed Approach, Para 4-8-9. 2. VFR aircraft are not automatically authorized to execute the missed approach procedure. This authorization must be specifically requested by the pilot and approved by the controller. When a missed approach has been approved, separation shall be provided throughout the missed approach. REFERENCE- FAAO 7110.65, Visual Separation, Para 7-2-1. |
No, it's in the ATC Handbook. I get it about 1 out of 50 approaches. |
"A Lieberman" wrote in message
... On Sun, 05 Dec 2004 18:43:20 GMT, Mike Adams wrote: Yes, this is an interesting point. Did they say "practice approach approved, maintain VFR", or did they say "cleared for the approach"? If it's a practice approach in a VFR environment, it's not all that unusual to get altitude restrictions, especially to keep you above the VFR traffic pattern, if they can't work you in. Hmmm, never got a practice approach approved..... I have always received cleared for the "type of approach" approach when I am doing approaches under VMC. Maybe practice approach is a regional thing? Allen Yes it can be a "regional thing" or more correctly an "airspace" or "workload" thing. VFR aircraft making practice approaches are supposed to be provided standard IFR separation from the time clearance is issued until the MAP. The phraseology for that is one of the normal approach clearances. See FAAO 7110.65 4-8-11a(2) However, sometimes full IFR separation not worth the effort so there are provisions to let VFR aircraft do the approaches pure VFR with no separation provided. The phraseology for that is "Practice approach approved..." See FAAO 7110.65 4-8-11a(3) |
![]() KP wrote: VFR aircraft making practice approaches are supposed to be provided standard IFR separation from the time clearance is issued until the MAP. Except we only need 500 feet vertical. |
![]() "KP" nospam@please wrote in message ... VFR aircraft making practice approaches are supposed to be provided standard IFR separation from the time clearance is issued until the MAP. Only if the aircraft is a heavy or a Boeing 757. However, sometimes full IFR separation not worth the effort so there are provisions to let VFR aircraft do the approaches pure VFR with no separation provided. The phraseology for that is "Practice approach approved..." See FAAO 7110.65 4-8-11a(3) Actually, it's the other way around. VFR aircraft practicing approaches are provided separation where procedures are established for it. Where no procedures have been established no separation is provided. |
![]() "Mike Adams" wrote in message news:cFIsd.176809$bk1.168609@fed1read05... Yes, this is an interesting point. Did they say "practice approach approved, maintain VFR", or did they say "cleared for the approach"? If it's a practice approach in a VFR environment, it's not all that unusual to get altitude restrictions, especially to keep you above the VFR traffic pattern, if they can't work you in. He said the clearance was "Cessna XXX, cross ELESE at 3,000, cleared GPS 15 approach." Since 500 feet vertical separation was used the other aircraft had to be VFR so we can conclude it was a practice approach in a VFR environment. |
![]() "Michelle P" wrote in message news ![]() If you are operating in VMC and practicing approaches you are operating on IFR and VFR rules. What VFR rules am I operating on if I'm practicing approaches on an IFR clearance? |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
Approach Question- Published Missed Can't be flown? | Brad Z | Instrument Flight Rules | 8 | May 6th 04 04:19 AM |
Procedure Turn | Bravo8500 | Instrument Flight Rules | 65 | April 22nd 04 03:27 AM |
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? | S. Ramirez | Instrument Flight Rules | 17 | April 2nd 04 11:13 AM |
IR checkride story! | Guy Elden Jr. | Instrument Flight Rules | 16 | August 1st 03 09:03 PM |
