Peter R. wrote:
I replied, "Negative traffic" to which he responded, "Maintain 3,000." Being momentarily confused ... What's confusing about "maintain 3000"? Should the controller have canceled my approach clearance first, then issued the altitude restriction? His primary responsibility is to keep you spearated from traffic. He should have given you clear, simple instructions to that end, which he did. Would cancelling your approach clearance, assigning an altitude, then re-vectoring you on the approach have been easier, or clearer, or safer? I was initially confused because I still had 5 miles at 3,000 feet before stepping down to the next altitude as part of the approach ... Well then, there was no conflict, and no reason to be confused. ... and it seemed that his first call was simply reinforcing the altitude minimums on the approach (that is, until he responded in a terse manner that he wanted to keep me there without ever rescinding my approach clearance). Fortunately, most controllers have enough sense to fill in where more is needed. |
Brien K. Meehan ) wrote:
Well then, there was no conflict, and no reason to be confused. It must be hard for you to walk the earth with us mere mortal pilots. As a two year instrument pilot who has only logged about 80 hours IMC now, I *was* confused but complied with his instruction nonetheless. Carrying that confusion with me outside of the cockpit is what prompted the question here. If this forum is only for expert IFR pilots like you, let me know and I will be sure to filter my future questions appropriately. 'kay? -- Peter |
Peter R. wrote:
It must be hard for you to walk the earth with us mere mortal pilots. There are good days and bad days. If this forum is only for expert IFR pilots like you, let me know and I will be sure to filter my future questions appropriately. 'kay? Okay, but I'd really like you to take this much away from this discussion: You were advised of traffic. You didn't report it in sight, so you were given an altitude assignment. If you found that so confusing that you actually found it necessary to call the controller back for clarification, you're head is really in the wrong place while you're flying. |
You were advised of traffic. You didn't report it in sight, so you were given an altitude assignment. If you found that so confusing that you actually found it necessary to call the controller back for clarification, you're head is really in the wrong place while you're flying. LOL! Usenet clairvoyance at its finest. With nothing more than a few sentences in this forum, you somehow were able to correctly deduce that my head was not in the right place, although personally I don't consider my wife's lap the "wrong place." That's too biblical. -- Peter |
In article , Peter R.
writes: If this forum is only for expert IFR pilots like you, let me know and I will be sure to filter my future questions appropriately. 'kay? -- Peter Peter, In this (or any) form you get a varity of answers, some good and some from "smart asses". It's up to you to separate them and ignore the latter. Chuck |
![]() "Brien K. Meehan" wrote in message oups.com... Peter R. wrote: I replied, "Negative traffic" to which he responded, "Maintain 3,000." Being momentarily confused ... What's confusing about "maintain 3000"? Perhaps the fact that he was already restricted to 3000 until passing ELESE. I was initially confused because I still had 5 miles at 3,000 feet before stepping down to the next altitude as part of the approach ... Well then, there was no conflict, and no reason to be confused. Since there was no conflict there was no reason for the 3000' restriction, hence the confusion. |
"Peter R." wrote in message
... Today I was practicing a GPS approach and had been cleared for the approach with the normal, "Cessna XXX, cross ELESE at 3,000, cleared GPS 15 approach." A minute or so later the controllers switched positions and another one took over that slice of airspace. The new one came on frequency and called my aircraft with, "Cessna XXX, traffic one o'clock, 2,500 and two miles, southbound" (the traffic was was crossing my path right to left underneath me). I replied, "Negative traffic" to which he responded, "Maintain 3,000." Being momentarily confused, I called to clarify the altitude restriction. The controller responded rather tersely that he wanted me at 3,000 for traffic avoidance. Should the controller have canceled my approach clearance first, then issued the altitude restriction? I was initially confused because I still had 5 miles at 3,000 feet before stepping down to the next altitude as part of the approach, and it seemed that his first call was simply reinforcing the altitude minimums on the approach (that is, until he responded in a terse manner that he wanted to keep me there without ever rescinding my approach clearance). -- Peter What class of airspace were you in? If Class B or C the answer is probably "Yes, he should have cancelled approach clearance to be 'book correct." But maybe he decided ensuring separation was a higher priority task. Or has the view that if he told you to maintain 3000 it should be obvious to you you're no longer authorized descend on the approach (not saying it is; saying he thinks it should be -/ ) . If Class D or E if either aircraft was VFR, he had no business issuing the restriction in the first place. Traffic? Yes, altitude restrictions? No Or there is also the possibility there was a genuine "deal" where standard separation of 1000ft or 3NM was already lost, and the 500ft/2NM was better than nothing. That might also explain the controller's "Do something now! Worry about being "book correct" later" instruction as well as what seemed to you a terse attitude. |
KP (nospam@please) wrote:
What class of airspace were you in? Class E airspace making a GPS approach while VFR into a class C airport (we were still several miles outside the class C ring). If Class B or C the answer is probably "Yes, he should have cancelled approach clearance to be 'book correct." But maybe he decided ensuring separation was a higher priority task. Or has the view that if he told you to maintain 3000 it should be obvious to you you're no longer authorized descend on the approach (not saying it is; saying he thinks it should be -/ ) . The other issue that prompted my confusion was the controller change. One controller cleared me, the next issued an altitude restriction. Was the second's altitude restriction due in part to the fact that he was not familiar with the GPS approach? http://www.myairplane.com/databases/.../00411RY15.PDF On the chart above, we were still outside of PAGER, approaching from the east, when this occurred. The approach required at least another 5 miles west at 3,000, then 12 more southwest-bound at 3,000 before descending - with strong headwinds that day I had at least another thirteen minutes at 3,000 without the altitude restriction. The other VFR aircraft was 500 feet below us crossing our path at a 90 degree right to left direction and was well south of us a minute or so after the restriction. -- Peter |
Peter R. writes:
KP (nospam@please) wrote: What class of airspace were you in? Class E airspace making a GPS approach while VFR into a class C airport (we were still several miles outside the class C ring). If Class B or C the answer is probably "Yes, he should have cancelled approach clearance to be 'book correct." But maybe he decided ensuring separation was a higher priority task. Or has the view that if he told you to maintain 3000 it should be obvious to you you're no longer authorized descend on the approach (not saying it is; saying he thinks it should be -/ ) . The other issue that prompted my confusion was the controller change. One controller cleared me, the next issued an altitude restriction. Was the second's altitude restriction due in part to the fact that he was not familiar with the GPS approach? http://www.myairplane.com/databases/.../00411RY15.PDF On the chart above, we were still outside of PAGER, approaching from the east, when this occurred. The approach required at least another 5 miles west at 3,000, then 12 more southwest-bound at 3,000 before descending - with strong headwinds that day I had at least another thirteen minutes at 3,000 without the altitude restriction. The other VFR aircraft was 500 feet below us crossing our path at a 90 degree right to left direction and was well south of us a minute or so after the restriction. Am I missing something? You were assigned an altitude that you were going to maintain without the assignment? It would seem that letting the assignment pass without comment and simply waiting for the controller to remove the altitude restriction, probably with the words "cleared for the approach", would have worked. If the restriction weren't removed before needing to start the descent, a verification of the approached clearance would then be in order. |
Everett M. Greene ) wrote:
Am I missing something? Just a low-time pilot who apparently over-analyzed the situation. Nothing else to see here... please move along. -- Peter |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
Approach Question- Published Missed Can't be flown? | Brad Z | Instrument Flight Rules | 8 | May 6th 04 04:19 AM |
Procedure Turn | Bravo8500 | Instrument Flight Rules | 65 | April 22nd 04 03:27 AM |
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? | S. Ramirez | Instrument Flight Rules | 17 | April 2nd 04 11:13 AM |
IR checkride story! | Guy Elden Jr. | Instrument Flight Rules | 16 | August 1st 03 09:03 PM |
