I should have mentioned I wouldn't depart if it didn't qualify as an
alternate. wrote in message ... On Mon, 6 Dec 2004 11:54:29 -0600, "dlevy" wrote: Can you file the departure airport as the alternate? Does it qualify as an alternate? Two airports in the middle of nowhere 40 miles apart. I can't think of another reasonable option. |
dlevy wrote:
I should have mentioned I wouldn't depart if it didn't qualify as an alternate. Why not? |
Because I would use the qualification as an alternate as a reasonable way to
get back on the ground. "Ron Natalie" wrote in message ... dlevy wrote: I should have mentioned I wouldn't depart if it didn't qualify as an alternate. Why not? |
On Tue, 7 Dec 2004 10:39:22 -0600, "dlevy" wrote:
Because I would use the qualification as an alternate as a reasonable way to get back on the ground. The qualifications for an alternate have nothing to do with a reasonable way to get back on the ground, except by coincidence. Alternates are used for computing legal fuel requirements. What you do to get back on the ground will depend on circumstances at the time. There's a huge difference between "alternate" and "alternative". "Ron Natalie" wrote in message m... dlevy wrote: I should have mentioned I wouldn't depart if it didn't qualify as an alternate. Why not? |
On Mon, 06 Dec 2004 21:13:25 GMT, wrote:
On Mon, 6 Dec 2004 11:54:29 -0600, "dlevy" wrote: Can you file the departure airport as the alternate? Does it qualify as an alternate? You can file it as the destination too. I filed from 3BS direct MBS VOR, LAN, AMN, 3BS. There was a pause and the briefer said, I think I can see a way to save you a lot of gas if you are willing to go direct. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Two airports in the middle of nowhere 40 miles apart. I can't think of another reasonable option. |
Roger wrote:
I filed from 3BS direct MBS VOR, LAN, AMN, 3BS. There was a pause and the briefer said, I think I can see a way to save you a lot of gas if you are willing to go direct. :-) Actually, I've filed similar plans with Lansing, and they wouldn't let me. They insisted that I file at least 2 plans, one departing Midland and the other departing Lansing. I've also tried to file flight plans with the alternate the same as the departure, and they wouldn't take it. I didn't argue, and just gave another nearby alternate (e.g. DET instead of PTK). |
"Brien K. Meehan" wrote in
oups.com: Actually, I've filed similar plans with Lansing, and they wouldn't let me. They insisted that I file at least 2 plans, one departing Midland and the other departing Lansing. I've also tried to file flight plans with the alternate the same as the departure, and they wouldn't take it. I didn't argue, and just gave another nearby alternate (e.g. DET instead of PTK). Not all FSS specialists know everything they need to know. -- Regards, Stan |
![]() I've also tried to file flight plans with the alternate the same as the departure, and they wouldn't take it. I didn't argue, and just gave another nearby alternate (e.g. DET instead of PTK). They have no basis to refuse to take it. The alternate airport doesn't even get processed into the system beyond the originating FSS. I know of an operator who operates a Gulfstream 5 on a regular basis from LAX to HNL. During the winter when the weather is really churning in the islands with a tropical convergence and all that brings, he files LAX as his alternate. Experience has shown that operator that since they can carry the fuel it is sometimes better to turn around should things be nastier than forecast when they arrive in the area over there. |
![]() wrote in message ... I know of an operator who operates a Gulfstream 5 on a regular basis from LAX to HNL. During the winter when the weather is really churning in the islands with a tropical convergence and all that brings, he files LAX as his alternate. Wow. Talk about the mother of all 180 degree turns! -cwk. |
Notes on NACO Obstacle Departure Procedures | John Clonts | Instrument Flight Rules | 1 | July 15th 04 10:20 PM |
Interesting Departure Procedu MRB Trixy Two | Richard Kaplan | Instrument Flight Rules | 26 | February 18th 04 11:42 PM |
Alternate Intersection Name in Brackets? | Marco Leon | Instrument Flight Rules | 7 | January 22nd 04 04:55 AM |
Requirement to fly departure procedures | [email protected] | Instrument Flight Rules | 77 | October 15th 03 06:39 PM |
Alternate requirements | Anthony Chambers | Instrument Flight Rules | 8 | September 17th 03 09:45 PM |
