![]() Papa3 wrote: Doug Haluza wrote: Oh, my, where to start? KM wrote: After an upset, the towplane will enter an unrecoverable dive, and if the rope does not break, the speeds will quickly increase beyond maneuvering speed. Where do you come up with this?I have NEVER flown an airplane that could not be pulled out of a dive. Another thing to consider is that the tow pilot would just release by this point.The tost hook will release at vitually any angle, and even if the plane had a Schweitzer hook, by forcing the tail up you will change the angle on the rope and the pilot could then release it. You can't pull out of the dive if the glider is still attached to your tail by a rope that won't break. And if you have a Schweizer hook on the tail, it may not release after the upset because the pull is greater and may no longer be straight back. There have been several cases of upset where the tow pilot could not make the hook release, and the dive would have been unrecoverable if the rope did not break. I recall that John Campbell did a detailed analysis of this issue (loads on a Schweizer towplane release mechanism) when he was a postDoc. There were a couple of pretty sobering conclusions IIRC: 1. There is a critical angle (not a particularly steep one) beyond which the vertical component of the force applied by the towrope will overcome the force available from the emergency release cable on the towplane side. In other words, once the glider kites up to a certain angle, the towpilot may (probably won't) be able to release. Anyone who has ever eyeballed the Schweizer release will immediately be able to see why this is the case. 2. The force required for this was significantly less than the breaking strength of a typical towrope. I could probably rough out the numbers for this, but it is intuitively makes sense. Maybe somebody has a copy of this analysis handy? P3 Here's a very good analysis: http://home.att.net/~jdburch/Towstudy.htm |
Oh, now why did you have to inject facts into the discussion? ;-)
A very good analysis. The AC 43.13-2 referenced can be found at: http://tinyurl.com/25oz7 The information on tow hook installatioin is at the end. Papa3 wrote: Here's a very good analysis: http://home.att.net/~jdburch/Towstudy.htm |
![]() Doug Haluza wrote: Oh, my, where to start? How about with your condisending tude? No, I'm saying the airplane was designed to handle flight and landing loads, based on it's max gross weight. These loads on the tail are only a fraction of it's weight. The glider can transfer most of the lifting force developed by the wing to the rope if a C.G. hook is used for aerotow. An aircraft with a design load limit of 4.4 G's will have an ultimate load limit 6.6 G's so a glider with a 1000 lb gross weight could deliver over 6000 lb of force, before the glider's wings failed. OK now focus here Doug, the math is not in dispute. The question is whether a glider could exert this force while on tow. After an upset, the towplane will enter an unrecoverable dive, and if the rope does not break, the speeds will quickly increase beyond maneuvering speed. But what makes you think the dive would be "Unrecoverable" just because the tow plane is past its manurering speed? You can't pull out of the dive if the glider is still attached to your tail by a rope that won't break. And if you have a Schweizer hook on the tail, it may not release after the upset because the pull is greater and may no longer be straight back. There have been several cases of upset where the tow pilot could not make the hook release, and the dive would have been unrecoverable if the rope did not break. Completely true statement.But, as the nose of the tow plane drops, this would change the angle on the release would it not?A couple of local pilots tried this (At altitude of course) and found this to be the case.Now at low altitudes, all bets are off of course.This is the beauty of the tost hook. Even if you tow with a Tost hook, you still need to react and operate the release. Doesnt this go without saying? I have to take issue with your previous post where you implied that a pilot could get away with aerobatics in a Super Cub as long as he wasnt doing "Tailslides".To coin your phrase this is "Ignorant Thinking".You should read my response to Baron 58Yankee on this one.I think that any aerobatics in a Super Cub should be discuraged. Most Respectfully Yours, KMU |
![]() KM wrote: OK now focus here Doug, the math is not in dispute. The question is whether a glider could exert this force while on tow. If both aircraft are in a steep dive from a high altitude upset, and the glider pilot panics and pulls the sitck, it certainly can. But it really doesn't matter--using a dockline as a tow rope means it won't break before one of the aircraft does. But what makes you think the dive would be "Unrecoverable" just because the tow plane is past its manurering speed? The dive after an upset will be unrecoverable as long as the glider stays attached to the towplane. |
![]() KM wrote: Are you telling us that the tail can only handle its own weight?You are using apples and oranges here because you used the FLIGHT loads of a sailplane and the actual weight of the tow plane.In other words, if a towplane can sustain 4.4Gs (In the utility category) shouldnt the tail of said towplane ALSO sustain 4.4Gs. Happy Landings KMU KM, I think what you're missing here is the difference between the limiting load factor on the towplane as a system (ie. the 4.4Gs) vs. the limiting load factor on a component. Typically, the primary load-bearing components in flight are the wing spars and the carry-through structure; this is carrying the majority of the load. The tail section will never sustain anything near those sorts of loads in normal flight. Think of this way. Suppose your towplane weights 1,500 lbs (just an illustration). It's pretty easy to imagine it supporting 6,000 lbs of sandbags spread along the wings (just think of those impressive ads showing proof-testing of spars). Now, imagine piling those same 6,000 lbs of sandbags on the empennage (assuming you could find the space to stack them :-)) Anyway, I can probably come up with some guesstimates on what the tail section of a typical welded steel cluster could withstand, but why bother? P3 |
Winch Launch Stresses on Vintage Gliders | Mike Schumann | Soaring | 31 | January 30th 06 09:29 PM |
Blanik Weak Link for Winch Launch??? | Gary Emerson | Soaring | 6 | February 24th 04 08:08 PM |
Weak Dollar (Bad News - Good News) | JJ Sinclair | Soaring | 6 | January 27th 04 03:06 AM |
Aviation Links Nov. 2 | DHeitm8612 | General Aviation | 0 | October 31st 03 01:50 PM |
