Robert M. Gary wrote:
It depends on the plane. High performance planes almost always have rudder interconnect. Planes like Arrows, Mooneys, Bonanzas, etc My Beech Sundowner has an interconnect, but you still need a tad of input. I'm pretty sure Arrows don't have an interconnect, but I only know about the standard version, not the T-tail. |
Mxsmanic wrote:
Is it always necessary to use the rudder to execute a coordinated turn? When I turn (in simulation) it seems that just rolling the aircraft suffices, as long as the bank angle isn't too steep. (And no, I don't have automatic rudder control enabled.) What plane are you using? If I turn off auto rudder control with the Cessna 172, the little ball is all over the place. Marc |
Marc Adler writes:
What plane are you using? I've been flying the Baron 58 and the 737 from the stock game, plus the Dreamfleet Bonanza A36 and the PMDG 737-800. In all cases, standard, gradual turns don't seem to require much rudder input, even with auto rudder control turned off. I did look at the A36 from the outside while moving the stick, and the rudder doesn't move. So presumably the loose connection that the real aircraft has between ailerons and rudder is not being simulated, but I'm not really sure (it could be simulated without the video, although that's unlikely--or it could be so gentle that it's hard to see movement in the rudder). If I turn off auto rudder control with the Cessna 172, the little ball is all over the place. I see the ball move occasionally, but not much. I tend to make gradual turns, though, especially in large aircraft. (Remember that I flew MSFS with just a keyboard for 15 years, and that teaches you to be gentle.) -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
I see the ball move occasionally, but not much. I tend to make gradual turns, though, especially in large aircraft. (Remember that I flew MSFS with just a keyboard for 15 years, and that teaches you to be gentle.) I always fly out of one airport (KAUS) with the weather set to real-time and the time of day the current time of day (because that's the airport where (I'm assuming) I'll learn to fly), so maybe the wind conditions affect performance, because even on level flight the ball in the inclinometer is hard to keep in place. Incidentally, speaking of input devices, do any people here who use a yoke* and who also actually fly think the yoke is more realistic (and therefore worth the price tag) than the joystick? Marc *e.g.: http://www.pilotshop.com/flight-yoke...4bf5edfca0c21b |
Marc,
because even on level flight the ball in the inclinometer is hard to keep in place. Have you compared realism settings yet? Also, in the bigger aircraft, the ball will move less. Incidentally, speaking of input devices, do any people here who use a yoke* and who also actually fly think the yoke is more realistic (and therefore worth the price tag) than the joystick? As long as the yoke also has engine controls, I'd say yes, it's worth it. -- Thomas Borchert (EDDH) |
Thomas Borchert wrote:
Have you compared realism settings yet? Also, in the bigger aircraft, the ball will move less. I have the realism settings set to maximum. As long as the yoke also has engine controls, I'd say yes, it's worth it. My Christmas list is growing like a tapeworm... g Marc |
Mxsmanic wrote
I've been flying the Baron 58 and the 737 from the stock game All swept wing airliners that I am familiar with (Boeings) have a full time yaw damper that keeps the rudder where it belongs at all times. The airplanes make perfectly coordinated turns with one's feet flat on the floor. :-) Bob Moore ATP B-707 B-727 PanAm (retired) |
Bob Moore writes:
All swept wing airliners that I am familiar with (Boeings) have a full time yaw damper that keeps the rudder where it belongs at all times. The airplanes make perfectly coordinated turns with one's feet flat on the floor. :-) I thought a yaw damper was just intended to prevent dutch roll. At least on the 737-800, the yaw damper can be turned on or off at pilot discretion. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote
At least on the 737-800, the yaw damper can be turned on or off at pilot discretion. Turned ON and OFF...Yes, but hardly at the pilot's discretion. I have no 737 experience, but the 727 has 2 rudders and 2 yaw dampers. If just one of them fails, the pilot must descend below 30,000' and slow to a specified maximum speed, just in case the other one should fail also. Bob Moore |
"Rudder" is required to make coordinated rolls into banks in most aircraft.
The next question would be: is the rudder applied automatically by the movement of the lateral controls? If not, then the pilot may have to displace the rudder himself. Some aircraft have rudder input applied automatically when the control column/stick is displaced. One example of that is the B-58 which has a rudder/elevon interconnect which uses a computer to determine when, if, how much, and in what direction the rudder should be moved when the pilot makes a lateral input to the elevons. In subsonic flight the rudder is normally displaced in the same direction as the lateral input. In transonic flight the shock wave hits the vertical stabilizer producing a "rudder" force which has to be corrected. At some speeds the rudder is actually moved in the opposite direction since the shockwave force on the vertical stabilizer produces more "rudder" input that is desirable. The automatic rudder input changes more as the aircraft accelerates to mach 2. The B-52 is different also, in that the H model (that I flew) has no ailerons and uses hydraulic spoilers on the top of the wings to produce the required roll input. With no speed brakes deployed a roll input causes the spoilers on the downward moving wing to be deployed, spoiling lift and dropping the wing. The resultant drag makes a rudder input in that direction to not be required. Because the spoilers are aft of the center of lift, deploying a spoiler on a clean wing also causes an undesired pitch up. In the traffic pattern speed brakes are normally deployed to an intermediate position. In this case a roll input to the left will cause the left speedbrake/spoilers to rise further and the right speedbrake/spoilers to lower somewhat. This about eliminates the pitchup and makes flying more stable. That said, most aircraft require a pilot input of rudder to coordinate a roll input. Little, if any, rudder is required once the roll stops and a constant bank is maintained. Fancier aircraft have yaw dampers which also reduces the required pilot rudder input. So, to answer your original question it is necessary to change your question somewhat. Change the word "turns" to "rolls", since most rudder coordination is necessary only while rolling into a bank and little is needed once bank is established to further coordinate the turn while bank stays constant. In light aircraft the amount of wing dihedral can affect turn coordination. -- Darrell R. Schmidt B-58 Hustler Web Site URL (below) http://members.cox.net/dschmidt1/ "Mxsmanic" wrote in message ... Is it always necessary to use the rudder to execute a coordinated turn? When I turn (in simulation) it seems that just rolling the aircraft suffices, as long as the bank angle isn't too steep. (And no, I don't have automatic rudder control enabled.) -- Transpose mxsmanic and gmail to reach me by e-mail. |
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? | S. Ramirez | Instrument Flight Rules | 17 | April 2nd 04 11:13 AM |
1-34 Rudder | DGRTEK | Soaring | 23 | February 16th 04 04:36 AM |
PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 12:14 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
