End of Season Sunset Warning for SSA-OLC Participants
Old September 28th 06, 01:10 AM posted to rec.aviation.soaring
Doug Haluza
Default End of Season Sunset Warning for SSA-OLC Participants
Graeme Cant wrote:
I have a crazy suggestion too.
So do I. How about if you actually join the community first by
registering for the OLC and then posting some flights, before you jump
in and start telling us what we should or should not be doing.
Old September 22nd 06, 10:48 PM posted to rec.aviation.soaring
Doug Haluza
Graeme Cant wrote:
Paul Remde wrote:
I must respectfully disagree. If we just use sunset as the end of soaring
flight that gives an unfair advantage to a pilot that is far from home or at
altitude when the sun sets. He/she should have planned ahead and landed on
time.
And exactly which time would that be, Paul?
The time calculated by the USNO, the "the preeminent authority in the
areas of Precise Time and Astrometry" (at least in the US).
You seem to have lost track of the story so far:
Doug wants to be able to pick illegal flights on OLC but he's having
trouble deciding which flights are illegal because he doesn't know when
it's "sunset" (as 'un'defined in the FARs) at all the places OLC flights
go to.
First, how dare you decide what I "want" based on what? If you look at
the subject line, and the original post to this thread, a reasonable
person would conclude that I do not want to do as you insinuate, and am
trying to warn pilots in advance, so it does not become a bigger issue.
Now read on:
I know this won't help but in Oz the rules a
1. "Night" is the period between the end of evening civil twilight and
the beginning of morning civil twilight.
2. CASA (FAA equivalent) publishes beginning and end of daylight graphs
for latitudes from 0 to 45 throughout the year.
3. Daylight flight occurs between those times after converting local
time to Standard/Daylight Time.
Note that daylight "ceases" at a particular longitude solely dependent
on its latitude. No allowance for terrain, etc.
And the date of course. This is based on the zenith angle of the sun.
But the following is also in the AIP:
"Users ... should note that the parameters used in compiling the ...
Graphs do not include the nature of the terrain ... other than a
cloudless sky and unlimited visibility ... Consequently, the presence
of cloud cover, poor visibility or high terrain to the west of an
aerodrome will cause daylight to end ... earlier than that extracted
from the appropriate graph.
Allowance should made for these factors when planning a flight..."
Yes, and all of these factors make sunset earlier, not later than
predicted by the standard formula for almost all normal soaring
flights. Unless you are flying off of a west facing beach in Winter,
sunset will be earlier than predicted because the horizon will be
higher, and the refraction will be less because the atmosphere is less
dense than standard sea level.
The rules are reasonable but are no help in maintaining a level playing
field for a gliding competition.
So, Doug. Make up your mind what arbitrary rule you would like to
implement for the SSA-OLC and publish it. Let's say - evening civil
twilight at the latitude.
This is similarly an insulting insinuation. First off, I am not making
the rules, just trying to follow the direction the Committee and I have
been given by the Board. The direction is clear; the flight must end by
sunset, unless approved lighting was used, and this is noted in the
comments section of the OLC claim.
Stop using the FAA as an excuse and a crutch. Stand on your own feet.
Make a rule. Publish it. Enforce it. Cop the flak.
Done. Done. and being Done.
Old September 25th 06, 08:23 PM posted to rec.aviation.soaring
Yuliy Gerchikov
"Doug Haluza" wrote in message
If you look at
person would conclude that I ... am
Just to keep the facts straight, let's say that "in advance" is a bit of an
exaggeration on Doug's part. The thread with the subject "...Warning..." was
posted *after* several flights were suddenly found to appear to be in
violation of the sunset rule.
Old September 28th 06, 01:05 AM posted to rec.aviation.soaring
Doug Haluza
If you look at
Yes, and the original post says that too. It's a warning to anyone else
who may think that it's OK to follow in your footsteps.
Old September 23rd 06, 06:22 AM posted to rec.aviation.soaring
Jack[_6_]
Paul Remde wrote:
"Andy" wrote in message
oups.com.
Given the uncertainty of the actual official sunset time I repeat my
request that SAA's sunset time be used only to determine the "end of
soaring flight" and not used to determine the validity of the entire
flight.
time.
I think calling sunset the end of soaring flight for the OLC is fine if
the pilot is given a few minutes more to land. If the flight continues
beyond that it could be considered sufficient evidence of poor planning,
or bad faith, and the whole flight automatically disallowed.
"SS + 0:05" might work for everybody in determining when to disqualify
an entire flight, and not require the services of both defense counsel
and a battery of astronomers just to mollify a nanny SSA-OLC.
And who cares how far from home the pilot is? Let him land out and walk
home, as long as the ship touched down within a few minutes of whatever
"FAA Official Sunset" might have been at that place and time. There are
no declarations necessary, nor is OLC an assigned task. Next thing we
know, we'll be needing Official Observers.
Jack
For Keith Willshaw... robert arndt Military Aviation 253 July 6th 04 05:18 AM
S-TEC 60-2 audio warning Julian Scarfe Owning 7 March 1st 04 08:11 PM
