Roger (K8RI) wrote:
You might try the reverse order too. Look at best glide speed. In calm air the best glide speed gives you the most distance per time unit, NO! It gives you the most distance per altitude lost. |
On Tue, 26 Sep 2006 08:33:23 -0400, Ron Natalie
wrote: Roger (K8RI) wrote: You might try the reverse order too. Look at best glide speed. In calm air the best glide speed gives you the most distance per time unit, NO! It gives you the most distance per altitude lost. Yur right. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
RandyL schrieb:
Vy is the best rate of climb for an aircraft. I can't seem to visualize why Vx is not the best rate of climb. Simple: The steeper you climb, the slower the airplane flyes (as long as you don't have excessive power). So you can climb steep but flying slow, or you can climb shallow but flying fast. Simple calculation shows that you can optimize for shortest distance or shortest time, but those optima need not be the same (and usually are not). Stefan |
RandyL wrote:
Here is something that I have always wondered about, but have yet to hear a good explanation for. Vx is the best angle of climb speed for an aircraft. Vy is the best rate of climb for an aircraft. I can't seem to visualize why Vx is not the best rate of climb. To my feeble way of thinking, Vx - the best climb angle - gets you to the highest altitude in the shortest period of time, no? Why is that not the best rate of climb? I hope someone can enlighten me on this. I know that there must be a good explanation, but as I said, I just can't visualize it. Thanks... You are forgetting that part of the equation for best angle of climb is also speed across the ground. For example, say best rate is 1000 fpm and best angle is 800 fpm. Now suppose that the groundspeed (assume no wind) is 120 knots for best rate climb, but only 60 knots for best angle. If you draw out the triangle you will see that the best angle airspeed really does give you the steepest climb gradient even though the rate of climb is 200 fpm lower than best rate. Matt |
"RandyL" wrote in message
... Here is something that I have always wondered about, but have yet to hear a good explanation for. Vx is the best angle of climb speed for an aircraft. Vy is the best rate of climb for an aircraft. I can't seem to visualize why Vx is not the best rate of climb. To my feeble way of thinking, Vx - the best climb angle - gets you to the highest altitude in the shortest period of time, no? Why is that not the best rate of climb? I hope someone can enlighten me on this. I know that there must be a good explanation, but as I said, I just can't visualize it. Thanks... How's this: I can get up a flight of stairs in around three seconds (best rate of climb). It will probably take me 20 seconds to climb a ladder the same height (I hate ladders). The ladder will get me up at a much steeper angle, hence best angle of climb. The stairs will get me there faster, hence best rate of climb. |
Say there's a hill a couple miles from the runway you need to clear to stay
alive. You would choose to climb at Vx, the best angle. If the hill wasn't there you'd climb at Vy, best rate. Say.. at Vx it takes you 5 minutes to get to that hill (which you clear) by 500'. The hill is 2500' above the runway and you cross it at 3000'. Let's say that hill is 10 miles from the runway. If you, instead, climbed at Vy you'd fly at a higher airspeed and get to the hill in 4 minutes (but crash into the top). If the hill wasn't really there, in an elapsed time of 5 minutes you might be at 3500' at a point 2 miles beyond where that hill would have been. (12 miles). So with 5 minutes of climb.. at Vx you cleared the hill and were at 3,000'. So with 5 minutes of climb.. at Vy (without the hill) you were at 3,500'. Vx gives you the best angle (to clear terrain) in distance. Vy gives you the best rate (to get to cruise altitude) in time. -- Darrell R. Schmidt B-58 Hustler Web Site URL (below) http://members.cox.net/dschmidt1/ "RandyL" wrote in message ... Here is something that I have always wondered about, but have yet to hear a good explanation for. Vx is the best angle of climb speed for an aircraft. Vy is the best rate of climb for an aircraft. I can't seem to visualize why Vx is not the best rate of climb. To my feeble way of thinking, Vx - the best climb angle - gets you to the highest altitude in the shortest period of time, no? Why is that not the best rate of climb? I hope someone can enlighten me on this. I know that there must be a good explanation, but as I said, I just can't visualize it. Thanks... Randy L. -- Remember: Any landing that you can walk away from, is a landing that you can be fined, sued, or prosecuted for. |
All have provided some very good answers, and I will add this: for
planes with Vx Vy (which is most planes I believe), when taking off into the wind, the wind will improve you climb angle w.r.t. the ground in the same manner and direction. That is, flying slower will allow you to clear obstacles more easily. In IFR this comes into play when following obstacle departure procedures, which specify a minimum climb *angle* (specified in feet per nautical mile). Of course, the wind direction does not affect Vx per se. -- Cheers, John Clonts Temple, Texas N7NZ Darrell S wrote: Say there's a hill a couple miles from the runway you need to clear to stay alive. You would choose to climb at Vx, the best angle. If the hill wasn't there you'd climb at Vy, best rate. Say.. at Vx it takes you 5 minutes to get to that hill (which you clear) by 500'. The hill is 2500' above the runway and you cross it at 3000'. Let's say that hill is 10 miles from the runway. If you, instead, climbed at Vy you'd fly at a higher airspeed and get to the hill in 4 minutes (but crash into the top). If the hill wasn't really there, in an elapsed time of 5 minutes you might be at 3500' at a point 2 miles beyond where that hill would have been. (12 miles). So with 5 minutes of climb.. at Vx you cleared the hill and were at 3,000'. So with 5 minutes of climb.. at Vy (without the hill) you were at 3,500'. Vx gives you the best angle (to clear terrain) in distance. Vy gives you the best rate (to get to cruise altitude) in time. -- Darrell R. Schmidt B-58 Hustler Web Site URL (below) http://members.cox.net/dschmidt1/ "RandyL" wrote in message ... Here is something that I have always wondered about, but have yet to hear a good explanation for. Vx is the best angle of climb speed for an aircraft. Vy is the best rate of climb for an aircraft. I can't seem to visualize why Vx is not the best rate of climb. To my feeble way of thinking, Vx - the best climb angle - gets you to the highest altitude in the shortest period of time, no? Why is that not the best rate of climb? I hope someone can enlighten me on this. I know that there must be a good explanation, but as I said, I just can't visualize it. Thanks... Randy L. -- Remember: Any landing that you can walk away from, is a landing that you can be fined, sued, or prosecuted for. |
RandyL wrote:
I can't seem to visualize why Vx is not the best rate of climb. I think what's confusing about it is that it's always presented in terms of getting over obstacles at the end of the runway. You (as in "everyone") always think of getting over those obstacles as quickly as possible, which is why Vx seems "faster." (At least, that's the way it seemed to me.) So forget time for a second and think about it in terms of horizontal distance: Vx will get you to a higher altitude over a shorter distance than Vy. It's a steeper slope. And that's it. If you add time into the equation, it'll take you longer to reach the same altitude along Vx than Vy, but that's because you can go that much faster at Vy than at Vx. Hope that helps. Marc |
figuring Rate of Climb | Michael Horowitz | Home Built | 1 | June 19th 05 03:16 AM |
Newbie question on Rate of Climb | Wright1902Glider | Home Built | 0 | August 17th 04 03:48 PM |
Rate of climb | Dillon Pyron | Home Built | 3 | May 8th 04 01:08 PM |
Angle of climb at Vx and glide angle when "overweight": five questions | Koopas Ly | Piloting | 16 | November 29th 03 10:01 PM |
Minimum rate of climb or descent | Aaron Kahn | Instrument Flight Rules | 3 | July 25th 03 03:22 PM |
