![]() "Larry Dighera" wrote in message ... On Mon, 02 Oct 2006 19:32:15 GMT, "Allen" wrote in : Twin Cessna's are the same way; if you switch to the aux tanks before burning a certain amount out of the mains (90 minutes for the large aux tanks) the mains will overfill and vent overboard before the aux tanks are empty. Are you saying that Cessna designed the fuel system that way, and the FAA certified it? Or are you referring to a ferry tank? It makes you wonder if the FAA would certify kinking the fuel line instead of providing a valve to shut off fuel flow. :-) I should have said the "tip tank" Twin Cessnas. Cessna designed it that way. Fuel injected cars do the same thing but have only one tank to return the fuel to so it is not a problem. If you wanted to return the excess fuel to the same tank it was drawn from you would need two sets of directional valves; one on the supply line and another on the return line that were synched to each other. It is much easier just to tell the pilot to burn 90 minutes out of the mains before switching to the aux's. Allen |
On Tue, 03 Oct 2006 01:40:46 GMT, "Allen"
wrote in : I should have said the "tip tank" Twin Cessnas. Cessna designed it that way. If you wanted to return the excess fuel to the same tank it was drawn from you would need two sets of directional valves; one on the supply line and another on the return line that were synched to each other. What would prevent plumbing the fuel return line into the top of all fuel tanks above the fuel level, so that the returning fuel would be able to fill whatever tank space was available at the time? There would be the added cost of labor and materials, and the added weight, but the hidden hazard would be eliminated. It is much easier just to tell the pilot to burn 90 minutes out of the mains before switching to the aux's. It would seem a placard would be more prudent. |
Larry Dighera schrieb:
What would prevent plumbing the fuel return line into the top of all fuel tanks above the fuel level, so that the returning fuel would be able to fill whatever tank space was available at the time? This would prevent an informed tank management. It is much easier just to tell the pilot to burn 90 minutes out of the mains before switching to the aux's. It would seem a placard would be more prudent. If this simple instruction is already too complicated for a pilot... Stefan |
On Tue, 03 Oct 2006 12:47:45 +0200, Stefan
wrote in : It would seem a placard would be more prudent. If this simple instruction is already too complicated for a pilot... It's more a matter of the possibility of someone failing to inform the pilot of this hidden hazard. A placard is more foolproof than relying on the spoken word or a phrase buried in the POH. |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 05:54 PM |
