NW_Pilot schrieb:
Look where the plane went! I assure you that it is going to over fly water again in IMC conditions! In the Arab desert? Ok, there's a lot more about Arabia than just desert, I know. But this is beside the point anyway. The point is, the buyer of a new plane decides what instruments he wants to be fitted. If the buyer decides he wants just the basics as a backup, then this is the buyers decision and neither Cessna's nor Garmin's. And I do perfectly understand if this buyer doesn't want to spend a couple of thousand for instruments which might be useful just for the ferry flight. After all, you knew this acted accordingly: You had an independant radio and an independant GPS as backup with you. Stefan |
Stefan wrote:
Matt Whiting schrieb: I'd prefer redundancy at both the sensor and instrument level if I was flying IFR across the pond. It was a *ferry flight* in an airplane which was not supposed to ever fly over water again. You want full redundancy installed for one ferry flight? Ok, just don't ferry fly then. I'd prefer it for all flights given the importance of fuel supply in an airplane and given the fairly high rate of fuel exhaustion incidents. I especially want redundancy with a system as fragile as the G1000 appears to be. Matt |
I'd prefer it for all flights given the importance of fuel supply in an airplane and given the fairly high rate of fuel exhaustion incidents. I especially want redundancy with a system as fragile as the G1000 appears to be. Ok, so you want the FAA jump in and require full redundancy on all instruments for all privately operated light singles to be considered airworthy? I'm not sure you really want this. (Heck, I fly routinely with T&B, ASI, Altimeter and whisky compass in clouds, with no Garmin whatsoever in the first place. Granted, not 200 miles over water and on no other mission than for the fun of it.) Stefan |
John Theune writes:
and as had been pointed out by a number of people, there is no solid evidence that make it clear that the reboots where caused by the out of range sensor. It doesn't matter what caused the reboots, because only defective software reboots in the first place. Even it the G1000 is a bad design/system, it's still no reason to say that we must stay with steam gauges. True. But a truly safe software system would be so expensive that nobody could afford it--which means in effect that we should stay with real instruments for the time being. Most people designing and writing software today have absolutely no clue when it comes to safety-of-life issues. What worries me is that systems like this are being "certified." Apparently certification means very little when it comes to software. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
John Theune writes: and as had been pointed out by a number of people, there is no solid evidence that make it clear that the reboots where caused by the out of range sensor. It doesn't matter what caused the reboots, because only defective software reboots in the first place. Even it the G1000 is a bad design/system, it's still no reason to say that we must stay with steam gauges. True. But a truly safe software system would be so expensive that nobody could afford it--which means in effect that we should stay with real instruments for the time being. Most people designing and writing software today have absolutely no clue when it comes to safety-of-life issues. What worries me is that systems like this are being "certified." Apparently certification means very little when it comes to software. Once again you have shown that you have no clue what your talking about. My day job is medical software and we most certainly know what safety of life means. |
John Theune writes:
My day job is medical software and we most certainly know what safety of life means. The G1000 is not running medical software. But the Therac was. -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() "Mxsmanic" wrote in message ... John Theune writes: and as had been pointed out by a number of people, there is no solid evidence that make it clear that the reboots where caused by the out of range sensor. It doesn't matter what caused the reboots, because only defective software reboots in the first place. No a hardware problem could have also been the cause. An electrical short caused by the "hacked" wiring sounds like an excellent place to start looking. |
Gig 601XL Builder writes:
No a hardware problem could have also been the cause. Not for synchronized reboots. Those come from software. An electrical short caused by the "hacked" wiring sounds like an excellent place to start looking. A short will either have no effect or it will prevent the system from operating at all. It will not reboot the system in perfect synchronization with the software. -- Transpose mxsmanic and gmail to reach me by e-mail. |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 05:54 PM |
