I had to edit the comments manually so the freqs, headings and runway
dimensions would all display in GNII. One "problem" I've noted with SeeYou is that it sometimes offers to delete nearby waypoints even when there really are two points you may want to keep; e.g., two airports within a mile or so, or two different sets of coordinates for the same airport caused by the FAA and organizers' data being slightly different. That's another reason why I went the Excel/text editor route. I assumed it was better (i.e,. easier for me) to edit externally and then use SeeYou to export/upload in the proper format. Chip Bearden ASW 24 "JB" |
I purchased a copy of Global Mapper, and as an experiment, I am
offering custom made charts for licensed customers of GlidePlan. Just send me an email from this page: (http://www.glideplan.com/download/Experimental.html). Resulting maps will be posted for download at the above link. In this way, hopefully we can get around the limitations of single sectional flight planning. As a first example, I have included a map that covers the area from CedarVille down to Bakersfield CA, and Sacramento East to Tonopah, which will account for most of the reachable destinations out of the Reno area. |
Hi Eric,
You are correct of course. The radio frequency data was not exported - which is a bummer. I requested that SeeYou add the ability to select what data is put into the export file's comment field but no luck so far. The data is in SeeYou. I believe it is possible to get the radio frequency into the file using some creative column copying in Excel, but I haven't tried it yet. Even so, it is very easy to create a waypoint file for any area of the USA with very current airport data using SeeYou or StrePla. Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "Eric Greenwell" wrote in message news:W90Wg.1696$WD1.1000@trndny04... Eric Greenwell wrote: Doug Haluza wrote: John Liebacher has made the FAA airport database available at: http://soaring.aerobatics.ws/TP/FAA If you have SeeYou, you can load this database, then overlay your turnpoints, and reject nearby duplicates. This will update the airport data in your exiting turnpoint database, plus give you landout airports for the whole country. You can then trim this down as much as you like. You may not need SeeYou, as John may have a version for GNII. The SeeYou version does include the frequencies, runway width, fuel availability (for motorgliders, of course). Some formats have smaller comment/description fields and may not have all info. I just tried exporting to a Cambridge DAT format, and the radio frequencies are not exported, though the runway width and fuel show up in the comments field. -- Eric Greenwell - Washington State, USA Change "netto" to "net" to email me directly "Transponders in Sailplanes" on the Soaring Safety Foundation website www.soaringsafety.org/prevention/articles.html "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Sectionals | Simulators | 1 | July 21st 06 12:45 AM | |
Purchased sectionals i dont need ( do you need them?) | Troy Towner | Aviation Marketplace | 0 | June 12th 04 10:20 PM |
class C and B comms on sectionals? | Magnus | Piloting | 31 | April 27th 04 09:49 PM |
AVIATIONTOOLBOX: Christmas sectionals are here and rsync-able. | Kyler Laird | General Aviation | 4 | January 1st 04 05:11 AM |
Old Iowa City Sectionals on line! | Jay Honeck | Piloting | 4 | December 17th 03 09:59 PM |
