Why are multiple engines different?
Old October 11th 06, 06:42 AM posted to rec.aviation.piloting
Jim Macklin
Default Why are multiple engines different?
Don't you hate it when the spell check adds punctuation you
don't want?
"Emily" wrote in message
| Emily wrote:
| Jim Macklin wrote:
| E90 King Air, F90 King Air 200 King Air. The 300/350
is a transport
| over 12,500 pounds and has to do it.
| King Air's are not light twins.
| Er, King Airs.
Old October 11th 06, 06:41 AM posted to rec.aviation.piloting
Jim Macklin
Yes, they are, they do not require two pilots. They do
weight more than 6,000 pounds, but that just means the FAA
requires an ability to climb at 5,000 feet.
| Jim Macklin wrote:
| E90 King Air, F90 King Air 200 King Air. The 300/350 is
a
| transport over 12,500 pounds and has to do it.
Old October 11th 06, 04:33 AM posted to rec.aviation.piloting
Mortimer Schnerd, RN[_2_]
Jim Macklin wrote:
E90 King Air, F90 King Air 200 King Air. The 300/350 is a
You call those light twins? I call them turboprops. To me a light twin is one
where you can't walk down an aisle inside... ie, smaller than cabin class. That
means airplanes such as the Duchess, Seminole, Aztec, Seneca, C-310, etc.
Compared to airliners, sure, I can see where you might consider a King Air a
light twin. But very few of us get to start in one and yet I do have a bit of
twin time, mostly in light twins and maybe a third of it in cabin class. I
doubt any of them could get out of their own way on takeoff with only one fan
turning.
mschnerdatcarolina.rr.com
Old October 11th 06, 07:07 AM posted to rec.aviation.piloting
Jim Macklin
I consider a high performance airplane as one that has
cruise speed above Va, because it requires a deft touch in a
spiral recovery since you are always above the speed where
you can break the airplane. You are trimmed for, let's say
175 and get into a spiral. By the time you discover the
error and begin recovery you are 25-50 knots above Va. You
do the recovery the way you were taught and pull power,
level the wings and pull the nose up. You also die.
The trim is going to do the pull up as you get the bank
angle into the 30 degree or less range since you are very
much above trim speed. The proper recovery in such a plane
is pull the power, hold the wheel forward and level the
wings, controlling the rate at which the nose comes up to
control the G loads. That is my definition. But the FAA
says that it is just anything with an engine over 200 hp.
FAA Part 1.1
Large aircraft means aircraft of more than 12,500 pounds,
maximum certificated takeoff weight.
§ 23.66 Takeoff climb: One-engine inoperative.
For normal, utility, and acrobatic category reciprocating
engine-powered airplanes of more than 6,000 pounds maximum
weight, and turbine engine-powered airplanes in the normal,
utility, and acrobatic category, the steady gradient of
climb or descent must be determined at each weight,
altitude, and ambient temperature within the operational
limits established by the applicant with-
(a) The critical engine inoperative and its propeller in the
position it rapidly and automatically assumes;
(b) The remaining engine(s) at takeoff power;
(c) The landing gear extended, except that if the landing
gear can be retracted in not more than seven seconds, the
test may be conducted with the gear retracted;
(d) The wing flaps in the takeoff position(s):
(e) The wings level; and
(f) A climb speed equal to that achieved at 50 feet in the
demonstration of §23.53.
In-flight acoustic measurements on a light twin-engined
turboprop ... In-flight acoustic measurements on a light
twin-engined turboprop airplane ... levels inside and
outside the cabin of a twin-engined turboprop airplane. ...
adsabs.harvard.edu/abs/1985bbn..reptQ....W - Similar
pages
Light Twin Performance Characteristics From the
transitioning pilot's point of view, the basic difference
between a light twin and single engine airplane is the
potential problem involving engine ...
avstop.com/AC/FlightTraingHandbook/LightTwinPerformanceCharacteristics.html
- 7k - Cached - Similar pages
[PDF] Subject: Pilot Transition Courses for Complex Single
Engine and ... File Format: PDF/Adobe Acrobat - View as HTML
Complex Single-. Engine Airplane Transition Training
Syllabus. Light Twin-Engine Airplanes. The syllabus in
figure 2 may be used for either of two purposes; ...
www.airweb.faa.gov/.../rgAdvisoryCircular.nsf/0/9fb4b32f92b4de56862569b9007093eb/$FILE/ATT4Q7X4/AC61-9B.pdf
- Similar pages
"Mortimer Schnerd, RN" mschnerdatcarolina.rr.com wrote in
message
a
Seneca, C-310, etc.
in cabin class. I
| turning.
Old October 11th 06, 05:57 AM posted to rec.aviation.piloting
karl gruber[_1_]
King Airs probably could, if you could get them going straight in the
beginning. But no, it's a LIGHT TWIN, with conventional Lycoming 180HP
engines. It's NOT a Piper.
The 300/350 has to do it once past V1. And by definition you have to be past
Vmcg, which might take Edwards AFB for the required runway length. King Air
doesn't taxi well on one engine, BTDT.
I have witnessed this airplane do it in relative safety.
Somebody tried to do this once on purpose in a Lear Jet out of KPDX about 25
years ago. He didn't make it.
Karl
"Jim Macklin" wrote in message
news:zVYWg.2132$XX2.900@dukeread04...
| karl gruber wrote:
| Some can, easily.
| Name one light twin that can take off on one engine.
| Note: a 737 is not considered a light twin.
Old October 11th 06, 01:45 PM posted to rec.aviation.piloting
Matt Barrow
The Twin Commander 690/695 series with the Dash-10 conversion is another
series. Single engine ceiling with that series is over 20,000 feet.
| karl gruber wrote:
| Some can, easily.
Home Built Aircraft - Alternative Engines - Geo/Suzuki OtisWinslow Home Built 1 October 12th 05 02:55 PM
Book Review: Converting Auto Engines for Experimental Aircraft , Finch Paul Home Built 0 October 18th 04 10:14 PM
P-3C Ditches with Four Engines Out, All Survive! Scet Military Aviation 6 September 27th 04 01:09 AM
U.S. Air Force Moves Ahead With Studies On Air-Breathing Engines Otis Willie Military Aviation 0 October 29th 03 03:31 AM
