In article , Jan Carlsson wrote:
Good reading is the "I could never be so lucky again" and also "The Spirit of ST Louis" (1953) The last one tells a lot about how it was to be a mail pilot in the 20's _The Spirit of St. Louis_ is one of those books all pilots should read (because they'll probably like them), like _Fate is the Hunter_. If I recall correctly, Lindberg talks about getting caught over a deck and letting the plane find its own way down while he walks. I think *that's* how the mail pilots handled hard IFR. (If it's really in a different book, it still doesn't change the recommendation to read it!). Mike |
Dick,
Since you indicated you did not wish to use a venturi, one alternative that had been used in the 20-30s for sufficient vacuum/flowrate to reliably operate a Turn and Bank is to tap off your motor's intake spider downstream of the carb (on a Continental, you could use one of the pre-threaded primer fitting holes). What you do is start with a fitting a small hole (~#40 or so) and, by a series of iterative enlargements, adjust until the level of desired vacuum was reached at cruise power. This is similar to the standby vacuum systems now sold for modern aircraft but, as the old vacuum T&Bs needed less vacuum levels/airflow, one would normally have sufficient vacuum throughout most flight regimes. Just a thought. Mike Bednarek "Dick" wrote in message m... Staring at my empty instrument panel while considering which instruments and their placement, I got wondering how old time Mail pilots flew if caught in IFR conditions. On my project plane, I'm considering just a airspeed/altitude/ ball & tube slip (no needle) indicator/compass setup in order to avoid the venturi or vacuum pump setup. Since I consider "electric" too expensive and wondered whether a dome style compass might be the key?? Any thoughts would be appreciated. Thanks, Dick -Lakeland, Florida |
![]() Dick wrote: Staring at my empty instrument panel while considering which instruments and their placement, I got wondering how old time Mail pilots flew if caught in IFR conditions. By the 30's, the mail was going by airlines. I assume you mean the old open cockpit planes of the 20's (like the Pitcairn Mailwing or the earlier Jennie). A skilled pilot can keep one straight and level by the feel of the relative wind on his cheeks and the sound of the wind in the wires, combined with the ball and altimeter. This still isn't as good as a gyro stack, and the accident rate was high. Lots of the pilots simply put the mail on the train if things got too bad. Lindberg discusses some of this in one of his books, and Gann has at least two novels about the period. I've also read an old book by a veteran mail pilot, but I have no idea any more what the title was (I checked it out from either the Knoxville public library or the Bearden High School library in the 60's). George Patterson Brute force has an elegance all its own. |
"G.R. Patterson III" writes:
A skilled pilot can keep one straight and level by the feel of the relative wind on his cheeks and the sound of the wind in the wires, combined with the ball and altimeter. I'm not too sure about the first two -- if relative wind told you anything at all about whether the wings were level, we be able to use something simpler than gyroscopic instruments for IFR today. It you take the last two, ball and altimeter, and add the magnetic compass, then it would be at least theoretically possible to fly straight (-ish) and level (-ish) in IMC, though they probably just flew very close to the ground, as Durden's article suggested. All the best, David |
A skilled pilot can keep one straight and level by the feel of the relative wind on his cheeks and the sound of the wind in the wires, Hmm, in a old airplane like that I'd say the relative wind is pretty much always gonna be about 80-90 mph off the nose! :^) |
got too bad. -------------------------------------------------- IFR = I Follow Railroads Old joke but true. I learned to love railroads the first time I ferried an airplane cross-country. Compass proved to be about ninety degrees off flying east to west (and I to get from Ohio to Sandy Eggo). Altimeter stuck at 2500 feet... and stayed there until the second bounce of the next landing. Had a spiffy new leather Pilot's Case for all those charts, couple of notebooks filled with Good Information... that turned out to be faiery tales ("They went out of business last summer" or, "We've always closed at five. Least ways, in the winter.") Ended up using an Esso road map because it showed all the railroads (at least, for the western United States). I'd be happy as a clam with needle, ball and alcohol, so long as that fan up front keeps turning and the little wheel in back don't fall off. -R.S.Hoover |
On Sat, 30 Aug 2003 18:28:43 -0400, "G.R. Patterson III"
wrote: Dick wrote: Staring at my empty instrument panel while considering which instruments and their placement, I got wondering how old time Mail pilots flew if caught in IFR conditions. By the 30's, the mail was going by airlines. I assume you mean the old open cockpit planes of the 20's (like the Pitcairn Mailwing or the earlier Jennie). A skilled pilot can keep one straight and level by the feel of the relative wind on his cheeks and the sound of the wind in the wires, combined with the ball and altimeter. This still isn't as good as a gyro stack, and the accident rate was high. Lots of the pilots simply put the mail on the train if things got too bad. Lindberg discusses some of this in one of his books, and Gann has at least two novels about the period. I've also read an old book by a veteran mail pilot, but I have no idea any more what the title was (I checked it out from either the Knoxville public library or the Bearden High School library in the 60's). George Patterson Brute force has an elegance all its own. You guys must not remember the "Cat and Duck" method of flying instruments. Hell, when I was a kid in the 1950's that's all we used. Any of you young punks know what the hell I'm talking about? BWB |
![]() Lindberg discusses some of this in one of his books, and Gann has at least two novels about the period. I've also read an old book by a veteran mail pilot, but I have no idea any more what the title was (I checked it out from either the Knoxville public library or the Bearden High School library in the 60's). George Patterson Brute force has an elegance all its own. You guys must not remember the "Cat and Duck" method of flying instruments. Hell, when I was a kid in the 1950's that's all we used. Any of you young punks know what the hell I'm talking about? BWB ++++++++++++++++++++++++++++++++++++++++++++ Hey - I'm still a young punk.... at heart. http://www.skyhawk.org/2D/tinduck.htm http://www.flippyscatpage.com/instrument.html http://jokes-quotes.com/contentid-239.html http://www.eaa445.org/instrument.htm http://www.ahajokes.com/ani031.html http://monster-island.org/tinashumor/humor/catduck.html Barnyard BOb -- 50 years of flight |
I heard someplace through the years in some hanger flying that a
pencil was used in IFR in the very early days. Can't remember how it was used but might be something like it was hung from a string in cockpit???? Maybe some real old, old, old timers remember some to the stories about the time the AAC was tasked to fly the Airmail? There's got to be some lurkers older than BOB and me G Big John On Fri, 29 Aug 2003 21:15:30 GMT, "Dick" wrote: Staring at my empty instrument panel while considering which instruments and their placement, I got wondering how old time Mail pilots flew if caught in IFR conditions. On my project plane, I'm considering just a airspeed/altitude/ ball & tube slip (no needle) indicator/compass setup in order to avoid the venturi or vacuum pump setup. Since I consider "electric" too expensive and wondered whether a dome style compass might be the key?? Any thoughts would be appreciated. Thanks, Dick -Lakeland, Florida |
