Mxsmanic wrote:
RK Henry writes: 1. In FARs part 1.1, Definitions, "Operate" is defined: "Operate, with respect to aircraft, means use, cause to use or authorize to use aircraft, for the purpose (except as provided in §91.13 of this chapter) of air navigation including the piloting of aircraft, with or without the right of legal control (as owner, lessee, or otherwise)." I don't see the word "engine" anywhere in the quoted text--again. It's best to read what regulations say, and not try to guess what you'd like them to mean. Legal documents are generally explicit; imagination is neither required nor recommended. If you're planning on using the airplane for flying, I'd interpret that as beginning with the moment you turn the key 'til the airplane is back in the hangar. So it's your interpretation; it's not written in the regulations. You are such a little cock wad. If you are starting the aircraft to fly you are operating the aircraft. |
Actually the FAA means , in the paragraph you cited, that
"operate" means use an airplane in a business or otherwise have the control of the airplane. It does not mean that the engine is running. "RK Henry" wrote in message ... | On Sat, 14 Oct 2006 20:52:59 +0200, Mxsmanic | wrote: | | RK Henry writes: | | Yes it does. In the excerpt here, "Operate" means running the engines. | | According to whom? | | 1. In FARs part 1.1, Definitions, "Operate" is defined: | | "Operate, with respect to aircraft, means use, cause to use or | authorize to use aircraft, for the purpose (except as provided in | §91.13 of this chapter) of air navigation including the piloting of | aircraft, with or without the right of legal control (as owner, | lessee, or otherwise)." | | If you're planning on using the airplane for flying, I'd interpret | that as beginning with the moment you turn the key 'til the airplane | is back in the hangar. I suppose it could exclude running the engine | at the shop, since that's not for the purpose of air navigation, but | the mechanics usually turn on the beacon too. | | 2. The mention in the AIM about lights isn't regulatory, but it may as | well be. It's good operating practice, and a pilot ignoring good | operating practice could conceivably be caught by the catch-all | regulation, FAR 91.13, Careless or reckless operation. Especially if | someone got hurt. And of course, none of us wants anyone to get hurt. | | Running the anti-collision system is low-cost insurance. Except for | cases like not operating strobes around people, it's better to just go | ahead and use it. It could save someone's life. | | RK Henry |
It means all that and more. It's an all-purpose definition intended to
be plugged into wherever the term is found in the regulations. I found a source on AOPA's site. I won't reproduce it here, but AOPA members can search for it as article 352. It says that the pilot must turn on the anti-collision lights whenever he "operates" [their quotes] the aircraft, which means every time he starts the engine. I consider that a fairly authoritative source, though not as authoritative as the FAA, of course. RK Henry On Sat, 14 Oct 2006 19:09:14 -0500, "Jim Macklin" wrote: Actually the FAA means , in the paragraph you cited, that "operate" means use an airplane in a business or otherwise have the control of the airplane. It does not mean that the engine is running. "RK Henry" wrote in message .. . | On Sat, 14 Oct 2006 20:52:59 +0200, Mxsmanic | wrote: | | RK Henry writes: | | Yes it does. In the excerpt here, "Operate" means running the engines. | | According to whom? | | 1. In FARs part 1.1, Definitions, "Operate" is defined: | | "Operate, with respect to aircraft, means use, cause to use or | authorize to use aircraft, for the purpose (except as provided in | §91.13 of this chapter) of air navigation including the piloting of | aircraft, with or without the right of legal control (as owner, | lessee, or otherwise)." | | If you're planning on using the airplane for flying, I'd interpret | that as beginning with the moment you turn the key 'til the airplane | is back in the hangar. I suppose it could exclude running the engine | at the shop, since that's not for the purpose of air navigation, but | the mechanics usually turn on the beacon too. | | 2. The mention in the AIM about lights isn't regulatory, but it may as | well be. It's good operating practice, and a pilot ignoring good | operating practice could conceivably be caught by the catch-all | regulation, FAR 91.13, Careless or reckless operation. Especially if | someone got hurt. And of course, none of us wants anyone to get hurt. | | Running the anti-collision system is low-cost insurance. Except for | cases like not operating strobes around people, it's better to just go | ahead and use it. It could save someone's life. | | RK Henry |
Mxsmanic wrote:
Emily writes: Can't he just read the regulations? He's obviously got access to internet. § 91.209 Aircraft lights. No person may: (a) During the period from sunset to sunrise (or, in Alaska, during the period a prominent unlighted object cannot be seen from a distance of 3 statute miles or the sun is more than 6 degrees below the horizon)— (1) Operate an aircraft unless it has lighted position lights; ^^^^^^^ (2) Park or move an aircraft in, or in dangerous proximity to, a night ^^^^ flight operations area of an airport unless the aircraft— (i) Is clearly illuminated; (ii) Has lighted position lights; or (iii) is in an area that is marked by obstruction lights; (3) Anchor an aircraft unless the aircraft— (i) Has lighted anchor lights; or (ii) Is in an area where anchor lights are not required on vessels; or (b) Operate an aircraft that is equipped with an anticollision light system, unless it has lighted anticollision lights. However, the anticollision lights need not be lighted when the pilot-in-command determines that, because of operating conditions, it would be in the interest of safety to turn the lights off. Nothing in this quoted section mentions engines, so it doesn't answer my question. How is it possible to operate an aircraft without an engine that is in operation? On the other hand, no reply from anyone here will satisfy your questions. Obviously, non-stop simming on MSFS has removed any and all common sense from you. And, you obviously have no concept of "logic" |
"Blanche Cohen" wrote in message
... How is it possible to operate an aircraft without an engine that is in operation? Well, for one...operate an aircraft that has no engine at all. There may be other ways. But I'd think the above would be a sufficient counter-example for you. The regulation does NOT say anything about engine operation, nor does the definition of "operate" per the FAA. It's true that engine start and aircraft operation are closely related, but the regulation isn't about engines, it's about aircraft. Inasmuch as an operation can take place at a different time than engine start, the former is what the regulation is talking about, not the latter. Pete |
Blanche Cohen writes:
How is it possible to operate an aircraft without an engine that is in operation? You'll have to ask glider pilots about that. On the other hand, no reply from anyone here will satisfy your questions. Quotations of regulations need to at least mention the subject of my queries. Many people seem to believe that their own personal interpretation of regulations has the same force of law as the regulations themselves, but that is not the case. -- Transpose mxsmanic and gmail to reach me by e-mail. |
In rec.aviation.student Mxsmanic wrote:
Blanche Cohen writes: How is it possible to operate an aircraft without an engine that is in operation? You'll have to ask glider pilots about that. On the other hand, no reply from anyone here will satisfy your questions. Quotations of regulations need to at least mention the subject of my queries. Many people seem to believe that their own personal interpretation of regulations has the same force of law as the regulations themselves, but that is not the case. Regulations are written to get the maximum meaning in the fewest words. Sometimes that requires one to make some common sense interpretation of the words. You seem to want "operation" to mean "when the wheels turn" or perhaps "when the wheels leave the ground". Most of us think it means "when the engine starts" (for planes with engines). Arguing over a definition like this is a common, yet tiring, USENET exercise. It's especially tiring when the entire thread is posted to multiple groups. Followups set to RAS. -- Transpose mxsmanic and gmail to reach me by e-mail. -- Don Poitras |
"Don Poitras" wrote in message
... Regulations are written to get the maximum meaning in the fewest words. You base that assertion on what? The FARs certainly don't bear that out. There's plenty of verbiage there, much of it excess if one takes the position that one must make inferences with respect to definitions of words in the regulations. Sometimes that requires one to make some common sense interpretation of the words. One does need to occasionally use "common sense" definitions, yes. However, when the FAA has provided a definition (as they have here), that is not required. You seem to want "operation" to mean "when the wheels turn" or perhaps "when the wheels leave the ground". Most of us think it means "when the engine starts" (for planes with engines). YOU seem to want "operation" to mean "when the engine starts". This isn't how the FAA defines it, nor does it make any sense that the FAA would write a regulation that applies to all aircraft, but have some sort of implicit exclusion for powered aircraft in which only "engine start" defines the course of operation. What happens with a motor glider? Is the aircraft not being operated when the engine is shut down in flight? How about a regular powered airplane? Does shutting the engine down in flight allow the pilot to stop using anticollision lights? What about a balloon? Are lights required only when the burner is operating? Arguing over a definition like this is a common, yet tiring, USENET exercise. It's especially tiring when the FAA has already provided a definition, and yet people insist that their definition is incomplete or that one should infer additional meaning beyond that provided in the official definition. It's especially tiring when the entire thread is posted to multiple groups. Followups set to RAS. If you think that your comments and replies to them belong only in r.a.student, then don't post your comments to another newsgroup in the first place. Pete |
Recently, Mxsmanic posted:
Blanche Cohen writes: How is it possible to operate an aircraft without an engine that is in operation? You'll have to ask glider pilots about that. On the other hand, no reply from anyone here will satisfy your questions. Quotations of regulations need to at least mention the subject of my queries. Many people seem to believe that their own personal interpretation of regulations has the same force of law as the regulations themselves, but that is not the case. The subject of your query was stated: "I understand that one normally turns on beacons or anticollision lights whenever an aircraft's engines are running. Is this a regulation, or just a polite custom?" Note that YOU were the one that set the parameters that the "aircraft's engines are running", therefore, the regs quoted directly answered your original question, as the PIC is always "operating an aircraft" if the engines are running, and therefore it is not "just a polite custom". Once again, you choose to argue rather than learn. Neil |
"Neil Gould" wrote in message
. com... Note that YOU were the one that set the parameters that the "aircraft's engines are running", therefore, the regs quoted directly answered your original question, as the PIC is always "operating an aircraft" if the engines are running, and therefore it is not "just a polite custom". The PIC is NOT "always 'operating an aircraft' if the engines are running". The FAA specifically defines "operate" to relate to "air navigation". There is nothing in the definition that suggests that simply having the engine running constitutes "operating". Is it a good idea to turn on the anticollision lights if you've got the engine running? Sure, especially if you are going to move the airplane (for example, taxiing from one spot on the ground to another). Is it a regulatory requirement? No, it is not. If you are not engaged in "air navigation", you are not "operating" the aircraft as far as the FARs are concerned. Once again, you choose to argue rather than learn. Seems to me, that accusation is more appropriately leveled at many of the other participants in this thread, this time. Pete |
[VERY LONG} MD airplanes, complete and projects, engines, gliders, many other items. | [email protected] | Aviation Marketplace | 0 | June 10th 06 10:51 PM |
Landing lights | Robert Barker | Owning | 20 | May 11th 06 02:33 AM |
Jet sailplane update | Bob C | Soaring | 0 | April 13th 06 08:06 AM |
Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 04:03 AM |
36HP VW Engine | Claton Cadmus | Home Built | 12 | October 24th 03 05:18 AM |
