"Bucky" wrote in messageI found this article on the Airbus 320, which has
an all glass cockpit: All glass, except the back-up altimeter and back-up airspeed indicator, which are mechanical. The back-up attitude indicator has an internal battery which is normally recharged by the aircraft's system. The FADECs are self powered but the EICAS is not. Many steam gauge airplanes will have indicator failures following the loss of all electricity because the air reference instruments get data from an air data computer and can't function in a stand-alone mode. Before RVSM , many airplanes had purely mechanical air reference instruments on the co-pilot's side, but now most of those operate on a second air data computer. "The energy supply is backed up in several ways. Along with one generator per engine, a third generator is powered by the APU. A fourth power supply is available by extending a little fan generator into the airstream. The chances of experiencing a complete power loss in an A320 are calculated to be at around one in one trillion. And yet, it did happen recently. A loss of all display units has happened a number of times. Should this happen, the above mentioned mechanical system of the rudder and the elevator trim ensure a safe landing." All well and good if one is in VMC conditions. Even then, the landing will be 'eventful'. In the simulator, in VMC conditions, only 50% get on the runway without damage and many of those don't stop on the runway. And good luck finding an airport in the first place without the IRS, GPS, VOR, ADF, or ATC. D. |
On Thu, 19 Oct 2006 16:37:08 GMT, "Neil Gould"
wrote in : Recently, Larry Dighera posted: http://world.honda.com/HondaJet/Styling/FlightDeck/ [...] It will be interesting to see how this one is FAA-certified. Power failure would be a worst-case scenario, so I'd be surprised if this plane lacked multiple power sources, but a lightning hit could be a problem. If the glass cockpit is engineered anything like the Garmin system installed in the Cessna 172S, that went into an infinite re-boot loop while en route from Greenland to Iceland causing the loss of all communications, navigation, flight instruments, fuel gages, autopilot etc., it would only take a malfunction affecting the main CPU to create a serious hazard. |
![]() Neil Gould wrote: Recently, Larry Dighera posted: http://world.honda.com/HondaJet/Styling/FlightDeck/ · All information, from flight and engine instrumentation to navigation, communication, terrain and traffic data, is uniquely integrated and digitally presented on the dual, large-format, high- resolution primary flight displays and the multifunction display · The HondaJet cockpit configuration provides a high degree of integration for enhanced situational awareness, functionality, ease of operation, redundancy, and flight safety. It will be interesting to see how this one is FAA-certified. Power failure would be a worst-case scenario, so I'd be surprised if this plane lacked multiple power sources, but a lightning hit could be a problem. It might surprise you, but a vacuum pump is not required for FAA certification. There are quite a number of airplanes out there flying without them, including most airliners. Many general aviation planes are all electric. A vacuum pump is a *liability* not a backup system. Complete power failure in a jet is not a good thing anyway. Many jets and turboprops could not survive it, not least because it means complete loss of flight controls. |
Recently, cjcampbell posted:
Neil Gould wrote: Recently, Larry Dighera posted: http://world.honda.com/HondaJet/Styling/FlightDeck/ · All information, from flight and engine instrumentation to navigation, communication, terrain and traffic data, is uniquely integrated and digitally presented on the dual, large-format, high- resolution primary flight displays and the multifunction display · The HondaJet cockpit configuration provides a high degree of integration for enhanced situational awareness, functionality, ease of operation, redundancy, and flight safety. It will be interesting to see how this one is FAA-certified. Power failure would be a worst-case scenario, so I'd be surprised if this plane lacked multiple power sources, but a lightning hit could be a problem. It might surprise you, but a vacuum pump is not required for FAA certification. There are quite a number of airplanes out there flying without them, including most airliners. Many general aviation planes are all electric. A vacuum pump is a *liability* not a backup system. Well, not only does this not surprise me, it isn't news. ;-) Having experienced a vacuum pump failure, and knowing the relatively short MTBF of those units, it is not a matter of *whether* they'll fail, but when. Complete power failure in a jet is not a good thing anyway. Many jets and turboprops could not survive it, not least because it means complete loss of flight controls. Understandable. In the case of this plane, I don't know whether the flight controls are electric or hydraulic, but I'd hope that in either case they'd have backups for normal power issues (failed generators, etc.) and be robust enough to withstand the power surge from a lightning hit. However, PFD circuits may not survive such a hit, so it made me think about what I'd do as a pilot of one of these planes, and the answer was pretty simple: keep a Garmin 496 in the "glove box"! ;-) Neil |
Manufacturing Quality | john smith | Piloting | 100 | August 13th 06 01:22 PM |
HondaJet a reality | [email protected] | Piloting | 3 | July 28th 06 01:50 AM |
Romance of steam | Denny | Piloting | 12 | October 18th 05 06:45 AM |
