Does Lycoming make any sense?
Old October 21st 06, 03:45 AM posted to rec.aviation.piloting,rec.aviation.owning
Stan Prevost
Default Does Lycoming make any sense?
I was wondering if the excessive fuel flow indication changes with pump on
vs off.
Stan Prevost wrote:
Robert, does it matter whether the boost pump is on or not?
No, pressure holds solid at 22lbs.
-Robert
Old October 21st 06, 09:41 AM posted to rec.aviation.piloting,rec.aviation.owning
Jim Macklin
Your turbine JPI device may only report to the JPI display.
The fuel pressure indicator/fuel flow that was original
equipment shows high pressure is there is a blockage and low
fuel flow. But the higher indicated pressure is also
interpreted as a higher fuel flow.
If you have EGT on each cylinder, checking temperatures and
thus fuel being burned can help determine if the cylinders
are rich or lean.
ps.com...
|I just spoke with Lycoming regarding my very high fuel
flow. Recently
| I've had a problem where I'm getting almost double my
normal fuel flow
| at idle even with the mixture at the edge of cut-off. I
suspected a
| servo but called Lycoming. They said I may have a nozzel
with a
| blockage and the other nozzles are streaming because of
it.
| Does this make any sense? Could a blockage cause an
*INCREASE* in fuel
| flow?
| I have a JPI fuel transducor wheel that measures fuel flow
that has
| shown to be very accurate.
| -Robert
Does Lycoming make any sense? Robert M. Gary Piloting 22 October 24th 06 12:01 AM
Which overhauled Lycoming 0-360 A4M Engine To Fit In My Archer ? Roy Page Owning 7 February 2nd 06 02:19 AM
MAKE THOUSANDS NO SCAM [email protected] Home Built 0 February 28th 05 02:06 AM
millionaire on the Internet... in weeks! Malcolm Austin Soaring 0 November 5th 04 11:14 PM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 September 2nd 04 05:15 AM
