On Sat, 21 Oct 2006 23:53:24 -0400, "Morgans" wrote:
"Ron Wanttaja" wrote Take a look, then, at a photo of the panel of *my* airplane: http://www.wanttaja.com/hhrad2.JPG I can't help but notice that your "fun" meter is pegged, even while it is sitting on the ground. You really need to get that thing worked on. It should not move off the bottom peg at least until you start the engine, and not peg until you get airborn. It's a *recording* fun meter, like a G-Meter. :-) Ron Wanttaja |
sitting on the ground. You really need to get that thing worked on. It should not move off the bottom peg at least until you start the engine, and not peg until you get airborn. It's a *recording* fun meter, like a G-Meter. :-) OK, it's a cumulative thing, eh? I guess you are in original factory new specifications, then. I will call the FAA, and tell them not to visit you. I have my eye on you, though! ;-) -- Jim in NC |
"Morgans" wrote in
: I can't help but notice that your "fun" meter is pegged, even while it is sitting on the ground. You really need to get that thing worked on. It should not move off the bottom peg at least until you start the engine, and not peg until you get airborn. I dunno. That plane looks fun even on the ground! ![]() |
![]() "Ron Wanttaja" wrote in message ... On Sat, 21 Oct 2006 23:02:49 +0200, Mxsmanic wrote: Judah writes: The first plane I trained in was as basic as they get - one radio, one NAV. It was adequate as a trainer, and even for renting (although I bought a handheld GPS after I started renting more frequently). But they sold that flight school and I don't think you can rent those planes anymore. I think I'd be worried in a plane like that. Take a look, then, at a photo of the panel of *my* airplane: http://www.wanttaja.com/hhrad2.JPG Be afraid. Be very afraid. :-) Ron Wanttaja Looks like an IC-T8 ham rig on the panel. |
On Sun, 22 Oct 2006 07:58:39 GMT, "Alt Beer" wrote:
http://www.wanttaja.com/hhrad2.JPG Be afraid. Be very afraid. :-) Looks like an IC-T8 ham rig on the panel. Close. IC-A5 aircraft transceiver. Built in, powered by the aircraft electrical system, hooked to the standard PTT switch. Replaced a defunct Narco, weighs less than a pound. Hooked to an antenna made from Radio Shack and plumbing parts. http://www.bowersflybaby.com/stories/antenna.htm Ron Wanttaja |
![]() "Ron Wanttaja" wrote Close. IC-A5 aircraft transceiver. Built in, powered by the aircraft electrical system, hooked to the standard PTT switch. Replaced a defunct Narco, weighs less than a pound. Hooked to an antenna made from Radio Shack and plumbing parts. I thought your electrical system consisted of a gel cell battery for the radio and lights, charged on the ground by a 110V battery charger. No? I might have you confused with someone else. It does not happen very often. Me getting confused, that is. At least I don't think it does. :-) -- Jim in NC |
On Sun, 22 Oct 2006 13:06:57 -0400, "Morgans" wrote:
"Ron Wanttaja" wrote Close. IC-A5 aircraft transceiver. Built in, powered by the aircraft electrical system, hooked to the standard PTT switch. Replaced a defunct Narco, weighs less than a pound. Hooked to an antenna made from Radio Shack and plumbing parts. I thought your electrical system consisted of a gel cell battery for the radio and lights, charged on the ground by a 110V battery charger. No? I might have you confused with someone else. It does not happen very often. Me getting confused, that is. At least I don't think it does. :-) Add this to one of the times, then. :-) I've got a "normal" electrical system in Moonraker, though given my preference, I would have preferred just a battery. Too damn much weight in the generator, battery, and starter, though I did switch to an Odyssey dry cell a couple of years back. Ron Wanttaja |
Ron Wanttaja writes:
Take a look, then, at a photo of the panel of *my* airplane: http://www.wanttaja.com/hhrad2.JPG Be afraid. Be very afraid. :-) Where are the cabin pressure controls and the FMCs? -- Transpose mxsmanic and gmail to reach me by e-mail. |
On Sun, 22 Oct 2006 10:06:24 +0200, Mxsmanic wrote:
Ron Wanttaja writes: Take a look, then, at a photo of the panel of *my* airplane: http://www.wanttaja.com/hhrad2.JPG Be afraid. Be very afraid. :-) Where are the cabin pressure controls and the FMCs? They fall away with the SRBs. http://www.bowersflybaby.com/stories/leoraker.JPG Ron Wanttaja |
... Take a look, then, at a photo of the panel of *my* airplane: Awh, 'ell, that's quite a bit more than my previous aircraft (a gyrocopter)... Its airspeed indicator was a disc in a plastic tube that rose up with increased air speed -- similar to this (http://www.hallwindmeter.com/images/short_bracket.jpg)... No altimeter... I'm thinking that there *might* have been some sort of engine temperature gauge, but I'm not sure... There might have been some sort of very small tachometer, but it was small enough to not be really useful... Come to think of it, I'm not even sure it had a compass... Most flights were done at 500 ft or less, so you follow roads, rivers, or anything else that might be interesting... grin |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 12:56 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
