![]() Tauno Voipio wrote: The localizer signal is a combination of three signals Whoah. Hang on. I've learned (from appropriate FAA publications) that the localizer was made up of two signals, one modulated at 150 Hz and the other at 90 Hz, each sent in lobes on either side of the centerline and the localizer reciever just compares the relative strength of each signal. Is that right, wrong, or overly simplified? thanks, Peter |
On Tue, 24 Oct 2006 17:35:41 GMT, Tauno Voipio
wrote: wrote: Tauno Voipio wrote: The localizer signal is a combination of three signals Whoah. Hang on. I've learned (from appropriate FAA publications) that the localizer was made up of two signals, one modulated at 150 Hz and the other at 90 Hz, each sent in lobes on either side of the centerline and the localizer reciever just compares the relative strength of each signal. Is that right, wrong, or overly simplified? That's right - after the three components are combined in the receiver antenna. All the three components carry both 90 Hz and 150 Hz modulation, but they are all different in such a way that being off the centerline causes an increase of the modulation depth (sound stregth) one modulation frequency and a decrease of the other. This is where the phase differences are needed. A very interesting discussion and nice to have a technical explanation. It makes more sense as a simple signal strength change would be likely to be unreliable. Thanks for the explanation of the glideslope antenna. I always thought it was the ground reflection that caused the unwanted lobe and had not appreciated the ground was deliberately used to simulate the underground antenna as well as introducing the extra unwanted lobe(s). |
Yes, it happens. We have that problem here in Billings. It is for that
reason that our RY28R ILS has no procedure turn. It's also why I have two marks on my radar scope, one north and one south. The aircraft must be at or inside these marks beore I can turn an aircraft on the localizer and issue the clearance. If I do it too soon the aircraft may grab the wrong localizer. wrote: I recall reading about false lobes on the glideslope, and have seen it firsthand doing practice approaches in VMC. I thought it was due to antenna sidelobes, and thus the localizer might be subject to a similar phenomenon. I have yet to see anyone reference this, so is there a technical reason why they don't exist? One of the localizer transmitter frequencies have a different antenna pattern to interleave the sidelobes perhaps? -Cory |
"War on terror" = false metaphor | [email protected] | Naval Aviation | 10 | August 17th 06 09:32 PM |
American nazi pond scum, version two | bushite kills bushite | Naval Aviation | 0 | December 21st 04 10:46 PM |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
AIR-2A Genie on F-104 true or false ? | Prowlus | Military Aviation | 22 | August 21st 04 03:53 AM |
True or false | zalzon | Naval Aviation | 1 | August 12th 04 03:29 PM |
