Even simpler approach to a movable seat - on rails with a latch
(C clamp concept) or holes in the rail and drop a steel bar (weight training - lots of iron bars and you select the weight by selecting the number of iron bars and putting a *hefty* latchpin in the bottom bar). Watch out for your fingers! |
On 2006-10-30, Blanche wrote:
Watch out for your fingers! Auugh. I flipped by an infomercial where a guy was "testing" a ladder by bouncing it on the step side. It's the kind of ladder that has a beefy hinge at the apex and no crossmember. He was holding it with his fingers INSIDE the ladder. I'm sure if the hinge had failed I could include a link to the online video of the guy losing his fingers... -- Ben Jackson AD7GD http://www.ben.com/ |
![]() Jay Honeck wrote: Until now, flying MS Flight Sim '04 using the big screen projector at the hotel has been cool, but, well, unreal. A joystick -- even a force-feedback stick, like we used -- is simply a bad compromise Yes, far better with yoke and rudder pedals with toe brakes. To solve many of your sensitivity problems and be able to add all sorts of cool things, be sure to get the #1 FS addon: FSUIPC: http://www.schiratti.com/dowson.html Next, order up your local scenery and better terrain from someone like: http://www.pcaviator.com/megascenery/ http://portal.fsgenesis.net/ I can actually follow the roads and lakes around northern NJ on the sim! Personally, I use a sim to pre-plan flights (hey, look there's a ridge I could use as a landmark, cool), practice instrument scan and navigation (zoom yourself somewhere random and then try to find yourself with VORs), and to keep fresh with flows. The last requires you go a bit crazy and build radios, fuel, magneto, etc switches in more or less the right spot to practice emergencies. So here comes some radio links, which should make you drool a bit: http://www.flyelite.com/hardware.php http://www.goflightinc.com/order/index.php http://sim.itra.de/default_en.htm http://www.simkits.com/ Best, Kev |
of cool things, be sure to get the #1 FS addon: FSUIPC: http://www.schiratti.com/dowson.html Wow, what a perfect example of a poorly designed webpage. No where on the page do they bother to explain what "FSUIPC" is -- although you *can* download FSUIPC (and other flight sim stuff) from there. After a little searching, I found the answer here, on another webpage: http://simmarket.com/product_info.php?products_id=2068 Thanks for the other links, BTW. Lots of good stuff there. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
In article .com,
"Jay Honeck" wrote: To solve many of your sensitivity problems and be able to add all sorts of cool things, be sure to get the #1 FS addon: FSUIPC: http://www.schiratti.com/dowson.html Wow, what a perfect example of a poorly designed webpage. No where on the page do they bother to explain what "FSUIPC" is -- although you *can* download FSUIPC (and other flight sim stuff) from there. After a little searching, I found the answer here, on another webpage: http://simmarket.com/product_info.php?products_id=2068 Thanks for the other links, BTW. Lots of good stuff there. and you don't even tell us... sheeesssh. -- Bob Noel Looking for a sig the lawyers will hate |
I've spent some time day-dreaming over a motion simulator. Take a look
at: http://www.acesim.com/main.html Jeff Kev wrote: Jay Honeck wrote: Until now, flying MS Flight Sim '04 using the big screen projector at the hotel has been cool, but, well, unreal. A joystick -- even a force-feedback stick, like we used -- is simply a bad compromise Yes, far better with yoke and rudder pedals with toe brakes. To solve many of your sensitivity problems and be able to add all sorts of cool things, be sure to get the #1 FS addon: FSUIPC: http://www.schiratti.com/dowson.html Next, order up your local scenery and better terrain from someone like: http://www.pcaviator.com/megascenery/ http://portal.fsgenesis.net/ I can actually follow the roads and lakes around northern NJ on the sim! Personally, I use a sim to pre-plan flights (hey, look there's a ridge ... So here comes some radio links, which should make you drool a bit: http://www.flyelite.com/hardware.php http://www.goflightinc.com/order/index.php http://sim.itra.de/default_en.htm http://www.simkits.com/ Best, Kev |
at: http://www.acesim.com/main.html Cool! A tad pricey, at $1800 (pre-built; less if you build it yourself), but cool nonetheless. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
CRS: V-22 Osprey Tilt-Rotor Aircraft | Mike | Naval Aviation | 0 | August 30th 06 02:11 PM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
