Recently, Thomas Borchert posted:
Larry, But if the aircraft is below 1,000', the CAPS system is probably not an option. IF you are in a fully developed spin (1 full turn, as certification requires and the handbook says), traditional spin recovery isn't an option either at 1000 feet. Why not? Are you implying that 1 full turn spin loses too much altitude, and if so, based on what? Some planes spin pretty flat, while others are pretty nose-down, which type is the SR22? Neil |
Neil,
Why not? Because you won't make a recovery from a fully developed spin in less than 920 feet with a plane of the approximate weight and size of the Cirrus, say a Bo. Remember, you have done one complete turn in a fully developed spin. Then you start counting when you apply rudder in the opposite direction and push the yoke (or whatever conventional recovery is to you). From that point to a positive climb rate, there's no way you'll lose less than 920 feet of altitude. And certification doesn't even require you to. -- Thomas Borchert (EDDH) |
Neil,
Why not? Because you won't make a recovery from a fully developed spin in less than 920 feet with a plane of the approximate weight and size of the Cirrus, say a Bo. Remember, you have done one complete turn in a fully developed spin. Then you start counting when you apply rudder in the opposite direction and push the yoke (or whatever conventional recovery is to you). From that point to a positive climb rate, there's no way you'll lose less than 920 feet of altitude. And certification doesn't even require you to. -- Thomas Borchert (EDDH) I did a little adding machine calculation, and you appear to be correct. :-( Obviously a situation to be avoided. Peter |
![]() "Thomas Borchert" wrote in message ... Larry, But if the aircraft is below 1,000', the CAPS system is probably not an option. IF you are in a fully developed spin (1 full turn, as certification requires and the handbook says), traditional spin recovery isn't an option either at 1000 feet. There is a limit to altitude loss during recovery to meet certification. The chute obviously qualifies. -- Thomas Borchert (EDDH) I presume that we are still just talking about fast and slick aircraft; because the Cessna 150M and Cessna 152 can both be spun a full turn, recovered and flown away losing half that altitude. However, the point is essentially moot, since no pilot who was that proficient in the recovery would allow it to happen. Peter |
Trip report: Cirrus SR-22 demo flight | Jose | Piloting | 13 | September 22nd 06 11:08 PM |
Wing Loadings (was SR22 discussion) | john smith | Piloting | 8 | June 23rd 06 11:41 PM |
SR22 Spin Recovery | gwengler | Piloting | 9 | September 24th 04 07:31 AM |
Cirrus SR22 Purchase advice needed. | Dennis | Owning | 170 | May 19th 04 04:44 PM |
New Cirrus SR22 Lead Time | Lenny Sawyer | Owning | 4 | March 6th 04 09:22 AM |
