A disturbing statistic
Old October 31st 06, 04:13 PM posted to rec.aviation.ifr
Paul kgyy
Default A disturbing statistic
Only Day VFR has the potential for being *very* safe in small,
single-engine aircraft.
I got my Instrument rating when a couple of Day VFR flights turned
really wormy because of weather. I've had far less stress and no bad
situations flying conservative IFR compared with the vagaries of trying
to stay VFR in the midwest.
Old October 31st 06, 05:21 PM posted to rec.aviation.ifr
A light plane is somewhere in the neighborhood of motorcycle riding, as
far as danger goes. You can double your odds of survival if you avoid
VFR into IMC and low-altitude maneuvering.
Dane Spearing wrote:
I've had many non-pilot friends and co-workers ask, "Is flying a small plane
more or less dangerous than driving a car?"
Old October 31st 06, 11:44 PM posted to rec.aviation.ifr
Dane Spearing
According to the DOT, the motorcycle accident fatality rate for 2002 was
34.0 fatalities per 100 million miles traveled. That's over 20 times
the rate for automobiles (1.47 fatalities per 100 million miles)!
(see http://www-nrd.nhtsa.dot.gov/pdf/nrd...FatsUpdate.pdf)
If we compare it with the aviation accident rate of 1.2 fatalities per
100,000 hours flown, and assume an average GA velocity of 150 mph, this
comes to a fatality rate for GA of about 8 fatalities per 100 million miles
flown.
Thus, motorcycle riding is roughly 4 times more dangerous than flying GA.
I feel better now.
-- Dane
In article .com,
Old November 1st 06, 03:06 AM posted to rec.aviation.ifr
RK Henry
On Tue, 31 Oct 2006 00:14:52 +0000 (UTC),
(Dane Spearing) wrote:
According to the DOT, the 2005 automobile fatality accident rate is:
1.47 fatalities per 100 million miles traveled
(see
http://www-fars.nhtsa.dot.gov/)
According to the 2005 Nall Report, the general aviation fatality accident rate
is: 1.2 fatalities per 100,000 flight hours
(see http://www.aopa.org/asf/publications/nall.html)
In order to compare these two statistics, we obviously need to assume an
average velocity for either automobiles or GA aircraft. If we assume an
average GA aircraft velocity of 150 mph, then the aviation accident statistic
becomes 1.2 fatalities per 15 million miles.
The 2005 Nall report shows a total 1413 GA accidents, fatal and
non-fatal, or 6.22 accidents/100,000 flight hours. Applying the
assumed average cruising speed of 150, the 6.22 accidents becomes
41.47 accidents per 100 million miles.
According to NHTSA, there were an estimated 6,159,000 police-reported
motor vehicle accidents in 2005, of which there were 43,443
fatalities. Dividing the 43,443 by the 2,965 billion miles traveled is
where they got the figure of 1.47 fatalities per 100 million miles.
Dividing the 6,159,000 accidents by the same 2,965 billion miles gives
an accident rate of 207.72 accidents per 100 million miles traveled.
It appears that if you drive a car, you're 5 times more likely to be
involved in an accident than if you fly, even in a General Aviation
aircraft. Since you have to have had some kind of accident in order
for it to be fatal, this is somewhat encouraging.
The problem is that airplanes go so much faster. If you do have an
accident at 150 mph, you're more likely to die as a result, whether
you're in a car or an airplane, and airplanes are much less
crashworthy than automobiles. One might speculate what the fatality
rate for automobiles could be if cars routinely cruised at 150 mph,
even if such speeds didn't bring with it an even higher accident rate.
Examining automotive fatality and accident rates in places like
Germany, where in some parts high speed driving is commonplace, might
be instructive. Only 0.7% of those automobile accidents were fatal
while 20% of the aircraft accidents were fatal. Airplanes don't crash
as often, but when they do, it's bad.
Perhaps one conclusion is that more attention should be paid to making
aircraft accidents survivable. Some work has already been done in this
area, but it looks like there's much room for improvement.
RK Henry
Old November 1st 06, 05:02 AM posted to rec.aviation.ifr
Andrew Sarangan[_1_]
No matter how you present the statistics, GA flying has a higher
fatality rate than driving. But one has to look at all the factors when
evaluating a mode of transportation. Nothing beats walking for safety,
plus it is good for your health too. Yet many people take the car for
even short distances. While GA flying is more convenient, faster and
flexible compared to driving, and even compared to airline travel, they
come at a certain amount of risk. Some people choose to accept that
risk, and some won't. It is better to be aware of the risks in flying
rather than pretend they don't exist, or assume they don't apply to
you.
(see
RK Henry
Old November 1st 06, 10:28 AM posted to rec.aviation.ifr
Jim Macklin
Much of the risk is controllable. Weather is never a
surprise anymore. modern weather satellites and automated
observations are not perfect, but some caution and honest
self-evaluation of a pilot's actual skill level could
eliminate ,any accidents.
JFK Jr. died because he did not have the skill to make the
flight under the conditions which existed at the time he
actually made the flight. The airplane was just fine, the
weather was OK for an IFR rated pilot or a VFR pilot who had
be taught properly how to use the equipment available. He
had lots of instruction, maybe too much instruction and not
enough developed judgment. Perhaps the instructors he had
used did not have "real" experience and thus failed to teach
the procedures that could have saved his plane and the
passengers.
Lidle had a fast airplane and a CFI. But it appears they
simply flew into box without any proper planning. Slow
flight and steep turns, evaluation of the wind, knowing the
East River procedures would have saved his life. Using the
radio to get a clearance would have too. What will never be
known, were they looking at the GPS track or out the damn
windows at the river and shore line?
You can practice the East River turn anywhere, pick a road
or river and practice a 180° turn within the confines of the
allotted space. You can even learn when an airspace
violation is better than dying.
James H. Macklin
ATP,CFI,A&P
"Andrew Sarangan" wrote in message
higher
factors when
for safety,
the car for
faster and
travel, they
accept that
risks in flying
apply to
| you.
accident rate is:
| (see
need to assume an
If we assume an
fatal and
Applying the
accidents becomes
police-reported
43,443
miles traveled is
million miles.
billion miles gives
miles traveled.
likely to be
General Aviation
accident in order
do have an
result, whether
less
the fatality
at 150 mph,
accident rate.
places like
commonplace, might
were fatal
paid to making
been done in this
improvement.
| RK Henry
Old November 1st 06, 12:04 PM posted to rec.aviation.ifr
Jim Macklin
"Jim Macklin" wrote
in message ...
| eliminate many accidents.
had
not
teach
| passengers.
be
| James H. Macklin
| ATP,CFI,A&P
| higher
| factors when
walking
| for safety,
| the car for
| faster and
airline
| travel, they
| accept that
| risks in flying
don't
| apply to
|| you.
| accident rate is:
|| (see
aviation
| need to assume an
aircraft.
| If we assume an
| fatal and
| Applying the
| accidents becomes
| police-reported
| 43,443
| miles traveled is
| million miles.
| billion miles gives
| miles traveled.
| likely to be
| General Aviation
| accident in order
| do have an
| result, whether
| less
| the fatality
| at 150 mph,
| accident rate.
| places like
| commonplace, might
| were fatal
| paid to making
| been done in this
| improvement.
|| RK Henry
Old November 1st 06, 12:41 PM posted to rec.aviation.ifr
B A R R Y[_2_]
allotted space.
Anybody remember "S-Turns" from the PP-ASEL PTS?
Linked 180's...
Old November 1st 06, 04:46 PM posted to rec.aviation.ifr
Newps
Not that fast, he had the SR20.
Old November 1st 06, 07:07 PM posted to rec.aviation.ifr
Jim Macklin
The point is that turn radius is directly related to speed.
It is possible to fly a 300 King Air at a slower speed than
Lidle was flying his SR20 and thus make the turn. Putting
aside the fact that the NTSB investigation is barely begun,
certain facts are known. Airplanes have flown the East
River for many years. Basic flight skills should have
allowed the flight to be completed safely. It was pilot
error, the question is why did the pilots make the error?
"Newps" wrote in message
request for fighter pilot statistic gatt Piloting 64 December 21st 05 10:55 PM
Very disturbing article about air safety JJ Instrument Flight Rules 10 July 22nd 04 08:56 AM
