Soooo, what is the best plane to build around a corvair engine?
Old November 5th 06, 12:23 AM posted to rec.aviation.homebuilt
Peter Dohm
Default Soooo, what is the best plane to build around a corvair engine?
Not to avoid your question, but ...
There is a lot to like about the Corvair engine(s), and also some things not
to like. I really like the idea of the 6 cylinder smoothness. However,
like the VW, you are usually starting with a very old engine. From time to
time, I have heard rumors that heads and crankcases are still made for
Corvair engines; but I have never been able to locate a source, and for me
that is sufficient discouragement. In addition, the engines were not
originally developed to turn a propeller cantelevered on the end of the
crankshaft--although there may be "workarounds" similar to the drive Steve
Wittman used or his Formula-Vee racer or to the outwardly similar "rear
drive" for the WV derived Great Plains engines. And, if you choose that
route, you might also need to design a bed-mount...
Anyway, the some of the real Corvair affectionados probably congregate
around William Wynne's web site: http://www.flycorvair.com/ and there
appears to be some discussion of airframes. There were a number of designs
back when the Corvairs were still fairly common (as cars), but the only one
that I personally recall is the KR-2. Plans are still sold, but it is only
a 2 seater if all the occupants light and of small stature. So, like all of
the homebuilts, either find one to sit in or else build a cabin mock-up
including seats and cushions before you build anything else!
I hope this helps.
Peter
Old November 5th 06, 02:55 AM posted to rec.aviation.homebuilt
Dan Settle
Basic rules.
1. horse goes in front of the cart.
2. Airframe first, engine second
Builders will consider several engines while construcitng the airframe.
Before committing to an airframe come up with the mission statement.
"Lou" wrote in message
Well?
Old November 6th 06, 02:54 AM posted to rec.aviation.homebuilt
Lou
On Nov 4, 8:55 pm, "Dan Settle" wrote:
Basic rules.
I
I agree, these are basic rules. Sometimes it's good to think outside
the box. Here we have a good engine that doesn't cost
an are and a leg, so why not design a plane around it rather than
design the engine to fit the plane?
Lou
Old November 5th 06, 05:03 PM posted to rec.aviation.homebuilt
jls
Lou wrote:
Well?
Since that engine is a natural-born assbuster, the slowest thing you
can build.
Pietenpol, maybe?
Old November 6th 06, 09:49 AM posted to rec.aviation.homebuilt
Stealth Pilot
On 5 Nov 2006 09:03:52 -0800, "jls" wrote:
Lou wrote:
Well?
can build.
they are like vw conversions. up to a particular stress level the
conversion preforms admirably.
however push them past the stress level and you discover why the
continental o-200 looks distinctively different. it was designed for
the stress levels.
lou needs to research the engine conversion's history. I'm sure that
william wynne can point him to a successful style of use that the
engine can handle.
Stealth Pilot
Old November 7th 06, 02:31 PM posted to rec.aviation.homebuilt
Gig 601XL Builder
Well?
Have you visited William Wynne's sit www.flycorvair.com? The Zenith 601XL is
what I'm going to have dragged around by a Corvair engine.
Old November 8th 06, 01:01 AM posted to rec.aviation.homebuilt
clare at snyder.on.ca
On Tue, 7 Nov 2006 08:31:25 -0600, "Gig 601XL Builder"
Well?
How about a Pegazair 100? (high wing taildragger STOL)
Posted via a free Usenet account from http://www.teranews.com
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 12:51 AM
V-8 powered Seabee Corky Scott Home Built 212 October 2nd 04 11:45 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
Conspiracy Theorists (amusing) Grantland Military Aviation 1 October 2nd 03 12:17 AM
