#21
Ron Wanttaja writes:
It's a moot point, since I usually keep the elevators full down for the initial part of the takeoff roll. What are the advantages and disadvantages of this? Clearly, it keeps the aircraft from leaving the ground, but other than that, what are the pros and cons? Does it put stress on the nose gear? -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote: Ron Wanttaja writes: It's a moot point, since I usually keep the elevators full down for the initial part of the takeoff roll. What are the advantages and disadvantages of this? Lack of tailwheel training, laziness, etc. -Robert, CFII |
T o d d P a t t i s t wrote: I use full down elevator in my Champ during takeoff. It has a tailwheel, and the purpose is to get the tail up quickly and get the nose down to normal flying attitude. The rudder is effective, so I'm not very worried about yawing in a crosswind gust. I don't want to get launched into the air with a high angle of attack at low speed. The Champ accelerates faster when it's in a normal flying attitude with the tail up. The Champ takes off perfectly fine with the stick neutral on takeoff. In fact, the three point take off can actually be shorter than tailwheel up takeoffs. |
T o d d P a t t i s t wrote: john smith wrote: The Champ takes off perfectly fine with the stick neutral on takeoff. I find with a passenger in the back that stick forward gets me up on the wheels, while neutral leaves the tail down for far longer. Most of my time is Chief rather than Camp (although I do have about 20 hrs of Champ). By myself the plane takes off from the grass quiet well from the 3 pt. With a pax I find I need to bring the tail up about a foot to gain speed necessary to get off the grass. BTW: In some tailwheel planes, moving the stick full forward disconnects the tailwheel steering and allows castering, not a good idea on takeoff roll. -Robert, CFII |
On Thu, 09 Nov 2006 18:36:36 +0100, Mxsmanic wrote:
Ron Wanttaja writes: It's a moot point, since I usually keep the elevators full down for the initial part of the takeoff roll. What are the advantages and disadvantages of this? Clearly, it keeps the aircraft from leaving the ground, but other than that, what are the pros and cons? Does it put stress on the nose gear? Taildragger aircraft; no nose gear. Due to poor forward visibility, I like to get the tail off the ground as early as possible. Here's a video of the takeoff, shot from an aft-mounted camera on the axle: http://www.bowersflybaby.com/takeoff-tail.mpg Once the tailwheel is off the ground, you can see it turn left and right as I keep the plane tracking (sorta) straight using the rudder (to which the tailwheel is connected via springs). You can make out the elevator position, too. Ron Wanttaja |
| Thread Tools | |
| Display Modes | |
| Return from AirVenture | john smith | Piloting | 7 | August 3rd 06 06:35 PM |
| Fly-By-Wire Flight Controls | Charles Talleyrand | Piloting | 52 | December 28th 05 11:27 PM |
| Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 06:14 AM |
| for mr. pethukov ( Bush May Announce Return To Moon At Kitty Hawk) | captain! | Military Aviation | 6 | October 30th 03 06:11 PM |
| Real World Specs for FS 2004 | Paul H. | Simulators | 16 | August 18th 03 10:25 AM |
