When do controls return to neutral?
Old November 9th 06, 06:36 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default When do controls return to neutral?
Ron Wanttaja writes:
It's a moot point, since I usually keep the elevators full down for the initial
part of the takeoff roll.
What are the advantages and disadvantages of this? Clearly, it keeps
the aircraft from leaving the ground, but other than that, what are
the pros and cons? Does it put stress on the nose gear?
Old November 9th 06, 07:06 PM posted to rec.aviation.piloting,rec.aviation.student
Robert M. Gary
Lack of tailwheel training, laziness, etc.
-Robert, CFII
Old November 9th 06, 10:07 PM posted to rec.aviation.piloting,rec.aviation.student
john smith
T o d d P a t t i s t wrote:
I use full down elevator in my Champ during takeoff. It has
a tailwheel, and the purpose is to get the tail up quickly
and get the nose down to normal flying attitude. The rudder
is effective, so I'm not very worried about yawing in a
crosswind gust. I don't want to get launched into the air
with a high angle of attack at low speed. The Champ
accelerates faster when it's in a normal flying attitude
with the tail up.
The Champ takes off perfectly fine with the stick neutral on takeoff.
In fact, the three point take off can actually be shorter than tailwheel
up takeoffs.
Old November 10th 06, 12:49 AM posted to rec.aviation.piloting,rec.aviation.student
Robert M. Gary
I find with a passenger in the back that stick forward gets
me up on the wheels, while neutral leaves the tail down for
far longer.
Most of my time is Chief rather than Camp (although I do have about 20
hrs of Champ). By myself the plane takes off from the grass quiet well
from the 3 pt. With a pax I find I need to bring the tail up about a
foot to gain speed necessary to get off the grass.
BTW: In some tailwheel planes, moving the stick full forward
disconnects the tailwheel steering and allows castering, not a good
idea on takeoff roll.
-Robert, CFII
Old November 10th 06, 03:42 AM posted to rec.aviation.piloting,rec.aviation.student
Taildragger aircraft; no nose gear.
Due to poor forward visibility, I like to get the tail off the ground as early
as possible. Here's a video of the takeoff, shot from an aft-mounted camera on
the axle:
http://www.bowersflybaby.com/takeoff-tail.mpg
Once the tailwheel is off the ground, you can see it turn left and right as I
keep the plane tracking (sorta) straight using the rudder (to which the
tailwheel is connected via springs). You can make out the elevator position,
too.
Return from AirVenture john smith Piloting 7 August 3rd 06 06:35 PM
Fly-By-Wire Flight Controls Charles Talleyrand Piloting 52 December 28th 05 11:27 PM
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 06:14 AM
for mr. pethukov ( Bush May Announce Return To Moon At Kitty Hawk) captain! Military Aviation 6 October 30th 03 06:11 PM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 10:25 AM
