Mxsmanic wrote:
You can find the answer in FAR 91.121(a)(iii). Found it, thanks. I'm surprised that just setting it at the airport would suffice--one could conceivably fly for hundreds of miles VFR, and the altimeter could change significantly along the way. That Reg does not apply to flight within 3,000 above the surface. You have to look at two other Regs to conclude that. Therefore, under 3,000, an adjustable altimeter is not required per 91.205. FARs don't apply to you; stay away. F-- |
"TxSrv" wrote in message
. .. Mxsmanic wrote: You can find the answer in FAR 91.121(a)(iii). Found it, thanks. I'm surprised that just setting it at the airport would suffice--one could conceivably fly for hundreds of miles VFR, and the altimeter could change significantly along the way. That Reg does not apply to flight within 3,000 above the surface. You have to look at two other Regs to conclude that. The requirement stated in 91.121a1iii does not include any exception for flights under 3000' AGL. If you have an adjustable altimeter, you have to set it according to 91.121, regardless of your altitude. Therefore, under 3,000, an adjustable altimeter is not required per 91.205. According to 91.205, an adjustable altimeter is only required for IFR (regardless of altitude). --Gary |
![]() "TxSrv" wrote in message . .. That Reg does not apply to flight within 3,000 above the surface. You have to look at two other Regs to conclude that. Therefore, under 3,000, an adjustable altimeter is not required per 91.205. FARs don't apply to you; stay away. An altimeter adjustable for barometric pressure is not required for VFR flight at any altitude. If you're operating at any altitude below 18,000 feet and you're equipped with a radio and you have an altimeter adjustable for barometric pressure you must set it to the current reported altimeter setting of an appropriate available station, VFR and IFR. |
But it would be kind of weird to be above 10K where a Mode-C transponder is
required, but not have a radio or altimeter... "Steven P. McNicoll" wrote in message nk.net... "TxSrv" wrote in message . .. That Reg does not apply to flight within 3,000 above the surface. You have to look at two other Regs to conclude that. Therefore, under 3,000, an adjustable altimeter is not required per 91.205. FARs don't apply to you; stay away. An altimeter adjustable for barometric pressure is not required for VFR flight at any altitude. If you're operating at any altitude below 18,000 feet and you're equipped with a radio and you have an altimeter adjustable for barometric pressure you must set it to the current reported altimeter setting of an appropriate available station, VFR and IFR. |
VFR, it doesn't really matter, does it?
-- ------------------------------- Travis Lake N3094P PWK "Mxsmanic" wrote in message ... Jim Logajan writes: You can find the answer in FAR 91.121(a)(iii). Found it, thanks. I'm surprised that just setting it at the airport would suffice--one could conceivably fly for hundreds of miles VFR, and the altimeter could change significantly along the way. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Not below 3000 AGL, it does above that.
"Travis Marlatte" wrote in message et... | VFR, it doesn't really matter, does it? | | -- | ------------------------------- | Travis | Lake N3094P | PWK | "Mxsmanic" wrote in message | ... | Jim Logajan writes: | | You can find the answer in FAR 91.121(a)(iii). | | Found it, thanks. I'm surprised that just setting it at the airport | would suffice--one could conceivably fly for hundreds of miles VFR, | and the altimeter could change significantly along the way. | | -- | Transpose mxsmanic and gmail to reach me by e-mail. | | |
"Jim Macklin" wrote in message
... Not below 3000 AGL, it does above that. "Travis Marlatte" wrote in message et... | VFR, it doesn't really matter, does it? | You seem to be suggesting that when flying VFR above 3000', we have an obligation to fly specific altitudes within some tolerence and, therefore, need to have an accurate means of determining our altitude. That is certainly not the case. Prudent, yes. Required, no. ------------------------------- Travis Lake N3094P PWK |
Travis Marlatte schrieb:
VFR, it doesn't really matter, does it? I've always thought that airspace boundaries are to be respected by VFR traffic, too. Stefan |
"Stefan" wrote in message
. .. Travis Marlatte schrieb: VFR, it doesn't really matter, does it? I've always thought that airspace boundaries are to be respected by VFR traffic, too. Stefan I agree that there are many reasons why I need to know my pressure compensated altitude to avoid busting airspace or illegally flying to close to person or property. The discussion was about the life-saving necessity of an accurate altitude instrument. MX was claiming that GPS is inaccurate enough to kill you. I presume that that can only happen in one of two ways 1) I fly into the ground believing my inaccurate intrument or 2) I fly at an altitude different than the regulated VFR cruise altitudes and run into another plane. I think both are highly unlikely in VFR conditions no matter how inaccurate the instrument. ------------------------------- Travis Lake N3094P PWK |
My filter failed and this message popped up... Not an issue of any
importance in itself and fixed again with two mouse clicks... However, seeing the list of you tripping over yourselves to answer his trolling have me howling with laughter... denny Mxsmanic wrote: Since it is possible to fly without voice radio equipment, and given that (if I understand correctly) pilots are supposed to have their altimeters set correctly to a reference located not more than 100 miles from their position, how does an aircraft without a radio keep its altimeter properly set as it travels? -- Transpose mxsmanic and gmail to reach me by e-mail. |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
I Hate Radios | Ron Wanttaja | Home Built | 9 | June 6th 05 05:39 PM |
(sorta OT) Free Ham Radio Course | RST Engineering | Piloting | 43 | January 24th 05 08:05 PM |
1944 Aerial War Comes to Life in Radio Play | Otis Willie | Military Aviation | 0 | March 25th 04 10:57 PM |
Ham Radio In The Airplane | Cy Galley | Owning | 23 | July 8th 03 03:30 AM |
