![]() Ron Lee wrote: DR wrote: On my 12 channel boat GPS I see a HDOP of ~1m these days. HDOP is unitless. Good point. I'm sorry that I was being so loose. But you could descibe the 1 sigma dilutuion of precision in terms of distance at your position and time -right? I was actually amazed to see that my Ryatheon GPS put my boat right in the center of the correct dock -implying 2m accuracy (or better)! Cheers MC |
DR wrote:
On my 12 channel boat GPS I see a HDOP of ~1m these days. HDOP is unitless. Good point. I'm sorry that I was being so loose. But you could descibe the 1 sigma dilutuion of precision in terms of distance at your position and time -right? I was actually amazed to see that my Ryatheon GPS put my boat right in the center of the correct dock -implying 2m accuracy (or better)! Cheers MC I have to think about it. Position accuracy is given by this generic equation: DOP x UERE x 2 = position accuracy (2 sigma or 95%) where UERE is the combination of the space and user equipment error sources. Ron Lee |
"Mxsmanic" wrote in message
... No, it is not. It's especially dangerous for RVSM flight, but it's so inaccurate that it should never be used for anything, except as a last resort (if the altimeters disintegrate, or whatever). It was posed as a possible means to adjust a pressure altimeter with no radio. I'd say that it is better than nothing, in that case. Since you can't be NORDO in the IFR system, separation is the responsibility of the pilot's eyes anyway. ------------------------------- Travis Lake N3094P PWK |
"Travis Marlatte" wrote in
t: Since you can't be NORDO in the IFR system, separation is the responsibility of the pilot's eyes anyway. Maybe you should say you cannot be INTENTIONALLY NORDO (squawking 7600). It would be pretty hard to maintian visual separation in the clag should the radios go belly up. Allen |
You can't begin an IFR flight as NORDO, but you certainly
can complete the flight that way. "Travis Marlatte" wrote in message t... | "Mxsmanic" wrote in message | ... | | No, it is not. It's especially dangerous for RVSM flight, but it's so | inaccurate that it should never be used for anything, except as a last | resort (if the altimeters disintegrate, or whatever). | | | It was posed as a possible means to adjust a pressure altimeter with no | radio. I'd say that it is better than nothing, in that case. Since you can't | be NORDO in the IFR system, separation is the responsibility of the pilot's | eyes anyway. | | ------------------------------- | Travis | Lake N3094P | PWK | | |
![]() "Mxsmanic" wrote in message ... No, it is not. It's especially dangerous for RVSM flight, but it's so inaccurate that it should never be used for anything, Your complete misunderstanding of the GPS system is showing. I have two GPS's in the plane, one panel mount and one portable. It is rare that either one is ever off by more than 100 feet in altitude. Using GPS for your altitude for VFR flight would be perfectly fine. |
Newps writes:
Your complete misunderstanding of the GPS system is showing. I have two GPS's in the plane, one panel mount and one portable. It is rare that either one is ever off by more than 100 feet in altitude. Using GPS for your altitude for VFR flight would be perfectly fine. I can see the NTSB report now: "Pilot failed to understand limitations of GPS navigation." But as long as I'm not flying with you, I don't care. Do what you want. -- Transpose mxsmanic and gmail to reach me by e-mail. |
I recently experimented with flying a GPS approach using the GPS
reported altitude as the "altimeter"... First, I flew the GPS approach track making notes as to the altimeter reading versus the GPS reported altitude on two GPS units in the cockpit... Now, knowing the average local offset between the GPS datum circle and the local ground altitude as reported by the local barometric pressure altimeter the official pair of altimeters in the pilots lounge... I wound up with 79 feet as my averaged offset between the GPS datum plane and the local altimeter... Notice I am emphasizing the word 'local' here... Your findings will differ with your area and with what they are doing down inside that Colorado mountain at any given instant...... A local WAAS transmitter and a WAAS receiver in my plane would, of course, narrow that altitude difference... Also note the altitude delta I found is almost within allowable altimeter error... Anyway, the second trip around I concentrated on flying the altimeter and IVSI on the Garmins instead of the altimeter - jeez, are they twitchy; according to them I never did establish level flight, they always showed either climb or descent, albeit usually at a rate of ~10 or 20 fpm... Trying to fly for real with an altitude instrument this twitchy would be exhausting.. The descent phase on the various legs of the approach was interesting but doable... So, my little experiment shows that one can do a GPS approach - after a fashion - using the GPS altitude reporting... Knowing in advance what the local differential between the GPS and the cold hard ground would be nice... I intend to next fool around with using the GPS IVSI for flying an ILS in place of the glide slope... I have done this with the barometric IVSI and had the radar guys watch me... Two times out of three they said they could not see any divergence... The one time they did see it I was definitely off the glide slope as I got sloppy on speed control and wound up too fast... Fun stuff to do as opposed to droning around in circles... denny Newps wrote: "Mxsmanic" wrote in message ... No, it is not. It's especially dangerous for RVSM flight, but it's so inaccurate that it should never be used for anything, Your complete misunderstanding of the GPS system is showing. I have two GPS's in the plane, one panel mount and one portable. It is rare that either one is ever off by more than 100 feet in altitude. Using GPS for your altitude for VFR flight would be perfectly fine. |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
I Hate Radios | Ron Wanttaja | Home Built | 9 | June 6th 05 05:39 PM |
(sorta OT) Free Ham Radio Course | RST Engineering | Piloting | 43 | January 24th 05 08:05 PM |
1944 Aerial War Comes to Life in Radio Play | Otis Willie | Military Aviation | 0 | March 25th 04 10:57 PM |
Ham Radio In The Airplane | Cy Galley | Owning | 23 | July 8th 03 03:30 AM |
