vor head needed
Old November 15th 06, 06:17 PM posted to rec.aviation.owning
RST Engineering
Default vor head needed
I found one of them. Let me describe the rear of the instrument to you and
see if it matches what you took out of your aircraft.
There are two adjustment controls on the rear. The top center one is
labeled LOC and the bottom right one is labeled VOR.
In the lower left corner there is what we call a "cannon" plug, about 1.25"
diameter and with 14 male pins inside the plug housing.
That what you've got?
Now, as I said, this one was working 20 years ago when I took it out to
replace it with the RST navcom(s). If it is DOA when you get it, start
thinking that perhaps it is the radio that drives the heads rather than the
heads themselves. What radio is driving the head?
If the radio is good, and this one doesn't work, I'll look around for the
other head.
"RST Engineering" wrote in message
I've got two old VOA-4 heads sitting SOMEWHERE
Old November 15th 06, 10:46 PM posted to rec.aviation.owning
Blanche
Yup.
The TKM is driving the VOR head. And your diagnosis is right on the mark.
I'll be out at the airport tomorrow to check on the radio nav itself.
It may be bad connections/wiring. The instrument shop (yes, I broke down
and took the VOR head over there today) claims that the narcos are
practically bullet proof, and the odds are 90% in my favor that if the
radio works, there's probably bad wiring or connectors.
other head.
Wait until I see what's happening with the one I've got here.
tanks!
Thrust Needed For Self Launching... tinman2006 Soaring 9 March 14th 06 12:38 AM
Thrust Needed For Self Launching... tinman2006 Soaring 0 March 12th 06 10:08 PM
GAO: Electronic Warfa Comprehensive Strategy Needed for Suppressing Enemy Mike Naval Aviation 0 December 27th 05 06:23 PM
NY Go Kart Endurance Racing - Arrive & Drive - No Experience Needed OVRPNY Owning 1 May 19th 05 04:56 PM
builder assistance needed AINut Home Built 0 April 8th 05 07:05 AM
