fudog50 wrote in
: Since the original question was about landing speeds, I assume you mean traps? Here is a topic for discussion..... The E/F "Rhino" comes in fast and heavy. The gear on Nimitz class is taking a heavy toll and is wearing out faster than the design was intended. The "Growler" will come in heavier and faster. Can the current configuration of the arresting gear handle it and not have catastrophic fatigue failure without major modification? I would simply draw your attention to several designs that could have been or were operated off Enterprise class & later carriers. A3, F4, A5 & F111. All heavier (30-40+ tons) than the Rhino or Growler. I think the rough aim point for approach speeds is something like ` 140Kts +/-. IBM |
A-3B CLEO was 49k max landing, 117kias
A-3B non-CLEO was 47k, 117kias Later A-3B's with Cambered Leading Edge wing, noted by slats inboard of the engines. After 1965 most A-3's were versions: tankers, ECM, photo-recon, or the overweight EKA-3B (or ERA-3B?) which couldn't operate from a carrier. But that was after my time (Forrestal was 5 years old, had a starboard side mirror, God's gift to the fleet with a 600psi steam plant, and the Whale was a strategic bomber.) Joel McEachen VAH-5 Ian MacLure wrote: fudog50 wrote in : Since the original question was about landing speeds, I assume you mean traps? Here is a topic for discussion..... The E/F "Rhino" comes in fast and heavy. The gear on Nimitz class is taking a heavy toll and is wearing out faster than the design was intended. The "Growler" will come in heavier and faster. Can the current configuration of the arresting gear handle it and not have catastrophic fatigue failure without major modification? I would simply draw your attention to several designs that could have been or were operated off Enterprise class & later carriers. A3, F4, A5 & F111. All heavier (30-40+ tons) than the Rhino or Growler. I think the rough aim point for approach speeds is something like ` 140Kts +/-. IBM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | December 2nd 04 07:00 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
