karl gruber wrote:
Ron, You know well that they've been moving the centers for DECADES. Nice to see your name on Avsig. Karl "Curator" N185KG The centers were moved in the early 1960s to get them away from possible nuclear attacks on major cities. |
![]() Jim Macklin wrote: The FAA and ATC exist to serve the military. That's funny. The military couldn't care less about the FAA. |
So? The FAA has specific duties to provide services to the
military in time of war. If it was only ATC for the civil market, the government would leave the area to the airlines, as it was prior to WWII and GA didn't fly IFR under control, just using the big sky principle. "Newps" wrote in message ... | | | Jim Macklin wrote: | The FAA and ATC exist to serve the military. | | | | That's funny. The military couldn't care less about the FAA. |
![]() Jim Macklin wrote: So? The FAA has specific duties to provide services to the military in time of war. The FAA's duties don't change in times of war. They would have told me. If it was only ATC for the civil market, the government would leave the area to the airlines, The feds did that to start with and the airlines had a midair. And here we are. |
Newps wrote:
Jim Macklin wrote: The FAA and ATC exist to serve the military. That's funny. The military couldn't care less about the FAA. Since you enjoy funny stories about the FAA ;-) here is one for you: A few years ago when El Toro Marine Air Station closed, John Wayne (Orange, County, CA KSNA) lost the eastern half of its Class C airspace. The airspace was bifurcated like that because of a giant screw up years ago. Some regional FAA grunt thought El Toro would be there forever, so they did it that way. The entire area was needed for John Wayne Airport; not so for El Toro. So, in the rucus that ensued to get the Class C back the way it was meant to be there were more than a couple of conference calls. The airspace lady in the Western Pacific Region made the following outrageous statement on a phone call with union reps, airline managers, ATC managers, and ATA folks, "The FAA is subserviant to the military. The FAA does not own any airspace. All airspace in the United States is owned by the military." |
![]() Sam Spade wrote: "The FAA is subserviant to the military. The FAA does not own any airspace. All airspace in the United States is owned by the military." That's not true either. That flies in the face of civilian control of the military. The military doesn't demand anything in a national emergency. They do what they're told, as it should be. |
Newps wrote:
Sam Spade wrote: "The FAA is subserviant to the military. The FAA does not own any airspace. All airspace in the United States is owned by the military." That's not true either. That flies in the face of civilian control of the military. The military doesn't demand anything in a national emergency. They do what they're told, as it should be. I was passing it on to you because it is absurb; as in you will find this humorous. Gee wiz, I guess you didn't find it funndy. |
Jim Macklin wrote:
The FAA and ATC exist to serve the military. The airlines are a justification on the budget. GA is forced to use ATC because in the past 50-60 years the FAA expanded the scope of controlled airspace to be everywhere. 25 years ago there were large areas that were uncontrolled below 14.500 feet. Your not the only one to make the argument that the FAA exists to serve the military. The last time that was factually correct was during World War II. It is all about the airlines. As to controlled airspace, what adverse impact does lowering Class E airspace below 14,500 (known at one time as the Continental Control Area) have on GA? What imposition does Class E impose upon the VFR pilot, other than to have the transponder turned on? As to IFR operations, light aircraft would be precluded from using the system without Class E airspace below 14,500. I started flying IFR in 1956. We didn't even have to have a radio to go into most towered airports then. But, the folks I flew for in the early days didn't think that was very smart so we had radios. Airways were far more limited then and direct routing off airways was usually impossible because of the lack of controlled airspace beyond the limits of the airways. We have a lot more flexible system today for IFR operations because of large areas of Class E airspace. Class B and C airspace comprises a very small percentage of the total airspace in the country. Those classes were not established to enhance IFR operations; rather, they were enacted to mitigate collision risk. Most of the world had some type of restrictive terminal control areas before the FAA went there. |
You can fly under IFR rules in uncontrolled airspace Class
G. "Sam Spade" wrote in message ... | Jim Macklin wrote: | The FAA and ATC exist to serve the military. The airlines | are a justification on the budget. GA is forced to use ATC | because in the past 50-60 years the FAA expanded the scope | of controlled airspace to be everywhere. 25 years ago there | were large areas that were uncontrolled below 14.500 feet. | | | Your not the only one to make the argument that the FAA exists to serve | the military. The last time that was factually correct was during World | War II. | | It is all about the airlines. | | As to controlled airspace, what adverse impact does lowering Class E | airspace below 14,500 (known at one time as the Continental Control | Area) have on GA? What imposition does Class E impose upon the VFR | pilot, other than to have the transponder turned on? | | As to IFR operations, light aircraft would be precluded from using the | system without Class E airspace below 14,500. | | I started flying IFR in 1956. We didn't even have to have a radio to go | into most towered airports then. But, the folks I flew for in the early | days didn't think that was very smart so we had radios. | | Airways were far more limited then and direct routing off airways was | usually impossible because of the lack of controlled airspace beyond the | limits of the airways. We have a lot more flexible system today for IFR | operations because of large areas of Class E airspace. | | Class B and C airspace comprises a very small percentage of the total | airspace in the country. Those classes were not established to enhance | IFR operations; rather, they were enacted to mitigate collision risk. | Most of the world had some type of restrictive terminal control areas | before the FAA went there. |
![]() Jim Macklin wrote: You can fly under IFR rules in uncontrolled airspace Class G. Sure, but nobody does because it is too impractical. |
RUTHLESSLY KILL TERRORIST PSYCHOPATHS BUSH, CHENEY, RUMSFELD, Robert Mueller, Keith Alexander, Mathew Hayden and John Negroponte | AmerGovtPsychopathsExposer | Home Built | 17 | November 20th 06 12:01 AM |
RUTHLESSLY KILL TERRORIST PSYCHOPATHS BUSH, CHENEY, RUMSFELD, Robert Mueller, Keith Alexander, Mathew Hayden and John Negroponte | AmerGovtPsychopathsExposer | Owning | 0 | November 17th 06 11:41 PM |
Using free online approach plates | mvgossman | Instrument Flight Rules | 22 | November 1st 06 12:24 AM |
legal to use home-printed IFR plates? | Marty Ross | Instrument Flight Rules | 29 | January 4th 06 05:25 PM |
Approach Plates on PDA (PIREP) | Stan Prevost | Instrument Flight Rules | 10 | December 18th 04 04:21 AM |
