Is it possible to switch from VFR to IFR and back?
Old November 25th 06, 01:26 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Is it possible to switch from VFR to IFR and back?
Christopher Brian Colohan writes:
That is probably because the book is designed as supplement to IFR
training, and not as a substitute for it.
A promotional book isn't a very good supplement to any kind of
training.
The FAA publishes other books that are very informative. If it can
produce such books for VFR, which lends itself far less to book
learning, it can certainly do so for IFR. I just haven't been able to
find the right book, I think.
Old November 24th 06, 07:20 PM posted to rec.aviation.piloting,rec.aviation.student
Newps
Roger (K8RI) wrote:
On Fri, 24 Nov 2006 08:14:35 +0100, Greg Farris
says...
If I am instrument rated and my aircraft is fully equipped for
instrument flight, and I start out a flight with a VFR flight plan,
and it gets foggy enough that I'm below minimums, is there a way to
switch to IFR in flight, or do I have to have filed IFR from the
beginning? If it's possible in flight, how does it work? Is it
possible to later switch back again?
I'm surprised this was not covered in the instrument training.
Now that's funny.
Old November 24th 06, 10:18 PM posted to rec.aviation.piloting,rec.aviation.student
Andrew Gideon
On Fri, 24 Nov 2006 20:32:24 +0100, Greg Farris wrote:
Tough to make a joke around here!!
I got it: "...weather conditions are required to revert to VMC."
Personally, I use the weather pull down on the Reality Menu.
- Andrew
Old November 24th 06, 08:26 PM posted to rec.aviation.piloting,rec.aviation.student
Blanche
IMC - instrument meteorological conditions
IFR - instrument flight rules
IR - instrument rating
Weather is IMC
A pilot is Instrument Rated (IR)
FAA rules of flight are either IFR or VFR
Old November 24th 06, 08:31 PM posted to rec.aviation.piloting,rec.aviation.student
Jim Macklin
You be and are subject to both IFR and VFR when flying in
VMC [not Vmc] and you are expected to do both at the same
time in many cases.
"Blanche" wrote in message
| Weather is IMC
Old November 25th 06, 12:48 AM posted to rec.aviation.piloting,rec.aviation.student
Blanche
time in many cases.
| Weather is IMC
True. I was merely pointing out definitions and usage of the
acronyms.
Old November 25th 06, 02:12 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Roger (K8RI) writes:
It is, but the weather can be beautiful VMC and you can still "air
file" IFR. *Sometimes* IFR makes it easier through some areas and
*sometimes* going VFR can save a lot of aggrivation.
It seems--at least in simulation--that instrument flight in VFR can be
handy for flights that are of non-trivial length. You can look at the
scenery more, and relax a bit when scanning instruments. And you can
spend more time looking for traffic.
I find that some flight are just plain easier to file the whole thing
IFR, particularly out here in the open country where you can ask,
expect, and receive a direct clearance.
But once you are IFR, you can't just turn to sightsee in an area that
interests you without ATC approval, right?
Old November 25th 06, 03:45 AM posted to rec.aviation.piloting,rec.aviation.student
Morgans[_2_]
And this is something you need to tell us here, ....Why? Why do you think we
care? This is a group for student PILOTS, not simulator game pretend pilots.
Looking at scenery on a game is far from reality. You need help, man.
Why do you care on a simulator game? Are you afraid you are going to get a call
from the simulated air traffic controller, and get a simulated suspension, or
fine?
Get a grip on reality. Seek help. Start by putting your computer away, and
participate in the real world.
Jim in NC
Old November 24th 06, 08:36 AM posted to rec.aviation.piloting,rec.aviation.student
Thomas Borchert
Mxsmanic,
s there a way to
Yes. Press CTRL+ALT+SHIFT+I for that.
Thomas Borchert (EDDH)
