Instrument Check Ride - What navigation equipment can I use ?
Old November 30th 06, 02:43 PM posted to rec.aviation.ifr
Sam Spade
Default Instrument Check Ride - What navigation equipment can I use ?
Jim Carter wrote:
It amuses me that so much of what was done 30 years ago, with less
accurate technical toys is today seen as macho and Herculean. Single nav
radio holds? Full ADF approach? Cross country without a moving map or
GPS? Single-engine, night IFR? There are way too many opinions about the
lack of safety of these practices by people who have little or no
experience with them.
I started flying IFR in 1958. I started instructing IFR the next year.
I went with a major airline in early 1964 and continued a lot of light
aircraft flying for the next 12 years.
Prior to 1965, or so, I never flew a light aircraft with an autopilot.
The first really good light aircraft autopilot I used extensively was a
Bendix (or Motorola) M4C in an Aerostar 600.
I mention my air carrier experience because it was an autopilot world at
crusie in my earlier years. The autopilots were not good enough for
climb out or descent (it was easier to hand fly in those phases of
flight). The later generation autoflight systems were excellent for all
phases of flight.
So, my point? When it was a VOR/DME/ILS world it was quite manageable
for a competent pilot to fly a stable light aircraft without an
autopilot. In fact, like the early airline jets the early light
aircraft autopilots were basically wing levelers with some heading
control (sometimes).
But, now we are evolving into a space-based navigation system with the
complexities of nav databases and, in the case of panel mount light
aircraft in particular, difficult (from a total human-factors systems
management standpoint) to input and manage nav data.
During the past 10 years, or so, light aircraft autopilots have improved
greatly. The use of such a current generation autopilot makes the
management of the complex space-based navigation system, especially as
it is implemented in light aircraft, much more manageable and, thus,
much more safe.
In VMC, without the autopilot, the single pilot on an IFR flight plan
using RNAV cannot maintain an adequate traffic watch. In IMC trying to
juggle all the balls is asking for loss of situational awareness.
An autopilot may be on someone's personal list of minimum equipment for
IFR, but that doesn't mean it should be a mandate for all of us.
It should be mandated for single-pilot normal IFR operations in today's
environment. That doesn't mean the pilot should let his hand-flying and
partial panal skills deteriorate. Speaking of partial panel, that did
not apply in jet transport operations and it does not apply to a G-1000
equipped light aircraft.
So, we are in transition in a very fundamental sense.
Old November 30th 06, 06:24 PM posted to rec.aviation.ifr
: It should be mandated for single-pilot normal IFR operations in today's
: environment. That doesn't mean the pilot should let his hand-flying and
: partial panal skills deteriorate. Speaking of partial panel, that did
: not apply in jet transport operations and it does not apply to a G-1000
: equipped light aircraft.
: So, we are in transition in a very fundamental sense.
"Bzzzt!!!" As anyone who flies Part 91 realizes WRT the FAR's, what's safe is
not necessary legal, and what's legal is not necessarily safe. Regulations do not a
safe pilot make.
Is it a good idea to have an autopilot for single-pilot, night IMC in a
single?
Yes.
Should it be *required* for non-commercial operations?
Not just no, but hell no.
... same reason it's legal to depart below takeoff minimums if part 91. It's
not necessarily a good idea, but shouldn't be regulatorily mandated.
-Cory
* Cory Papenfuss, Ph.D., PPSEL-IA *
* Electrical Engineering *
Old November 30th 06, 01:09 AM posted to rec.aviation.ifr
Matt Whiting
Mxsmanic wrote:
Jim Carter writes:
Demonstrating that a student can fly a typically one-hour check
ride by hand is not a macho task. There will typically not be more than
one or two holds, three or four approaches, and some partial panel
unusual attitudes. Although a typical instrument flight won't involve
all of these elements in a one-hour period, this scenario is still very
real world.
One could argue that any IFR flight without an operational autopilot
is an emergency, in which case the only type of IFR flight that one
would need to verify without autopilot would be landing at the nearest
airport. Although it apparently is not done this way in most
jurisdictions now, I can see the logic in doing so. Essentially it
would amount to little more than increasing the number of functional
instruments required for IFR flight.
Sure, ignorant people make all sorts of stupid arguments.
Matt
Old November 30th 06, 09:44 PM posted to rec.aviation.ifr
Thomas Borchert
Jim,
A
check ride should test the student's ability to handle emergency
situations.
Using an autopilot might be a good way to handle an emergency.
Thomas Borchert (EDDH)
Old December 1st 06, 12:57 PM posted to rec.aviation.ifr
Ron Natalie
Thomas Borchert wrote:
Jim,
A
situations.
The examiner even suggested I could use the autopilot to
fly my partial panel approach.
Accuracy of GPS in Garmin 430/530 Will Instrument Flight Rules 110 May 29th 06 04:58 PM
Instrument Rating Checkride PASSED (Very Long) Alan Pendley Instrument Flight Rules 24 December 16th 04 02:16 PM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 12:14 PM
CFI logging instrument time Barry Instrument Flight Rules 21 November 11th 03 12:23 AM
Use of hand-held GPS on FAA check ride Barry Instrument Flight Rules 1 August 9th 03 09:25 PM
