![]() "Judah" wrote in message . .. tony roberts wrote in news:indiacharlieecho- 15CF69.22341329122006@shawnews: I haven't seen it myself, but I was told that there was a "MythBusters" episode where the guys demonstrated that certain cell phones interfere with the ILS, causing the needle to deflect at least 50' to one side of the runway. I did see it. First, you have MUST keep in mind that the experiment, while planned and controlled, was NOT realistic and the results were inconclusive. With that said, the receivers were cobbled together from off-the-shelf from used avionics components. The system, under "normal" operation, with a "normal" cell-phone did nothing to the glide slope or OBS. It was only when the cobbled-up ILS was subjected to boosted energy on the cell-phone frequency that some deviation occurred. Note that the experiment ended up with a BUSTED! conclusion and caveats from Jamie that the Mythbusters proved nothing. |
"N2310D" wrote in news:%XEbh.17633$Uz.2268@trnddc05:
I did see it. First, you have MUST keep in mind that the experiment, while planned and controlled, was NOT realistic and the results were inconclusive. With that said, the receivers were cobbled together from off-the-shelf from used avionics components. The system, under "normal" operation, with a "normal" cell-phone did nothing to the glide slope or OBS. It was only when the cobbled-up ILS was subjected to boosted energy on the cell-phone frequency that some deviation occurred. Note that the experiment ended up with a BUSTED! conclusion and caveats from Jamie that the Mythbusters proved nothing. Like I said, I hadn't seen the details. I will say this - I used to have a Nextel phone with the walkie-talkie. That thing interfered with everything from Computer Monitors to Doctor's Office PA Systems. I have a Verizon phone now that is pretty benign, but I never left that Nextel on when I was IFR - it wasn't worth the risk... At the same time, the Nextel interfered with stuff that was at most 3' away from me. In the pilot's seat, I could see a potential risk. I can't imagine if I was sitting in the 1st row of a 737, let alone the 17th row, anything I'm carrying will interfere with the GPS in the cockpit past the galley, the toilet, the entry doors, and the piece of cardboard with the metal bar they call a cabin door... I'm still pretty convinced that this is at best a case of overprotection by the FAA to prevent risk from an unknown (who knows what frequencies the phone companies will start offerring service on?) and more likely a case of maintaining an outdated rule because it allows Flight Attendents to do their briefing without having to talk over a plane full of people on their cell phones... Not much different than the "Seatbacks Upright" thing. Do you really think it is a critical safety hazard that if the crew needs to evacuate the passengers, the average person won't be able to navigate their way past the 2" tilt of the seat in front of them. It rights itself when you push it up... |
![]() tony roberts wrote: It is an FCC rule because cellphone tower are designed to pick up a limited number of calls and at altitude the towers are over-loaded. I don't understand this. Consider that many new headsets actually have a cellphone interface. and consider that here in Canada it is not illegal, and I use mine lots - plugged right into my headset. I don't understand how it could be legal here if it really did overload towers. So what is the REAL reason? Hmmmm . . . the plot thickens ![]() I have heard that the real reason is that the towers are overloaded - - with handovers. The call has to be handed from tower to tower as the user moves. The system was designed to cope with walkers, people in cars, but not jets at 600mph. I have no idea if the above is really true but it does make some sort of sense to me. On a related but unrelated topic - One of the mysteries of life is that you can be in say London, turn off a mobile phone, put it in a bag and go to Sydney. When you get there you turn the phone on and if a few seconds later your boss in Moscow calls you the call can be successfully routed and your phone rings. |
Ok I am flying my plane at 12,000 feet and the phone might talk to
several towers, thats frowned upon. Now, I hike about 2 miles and climb the Grand Teton mountian to almost 14,000 feet, use my phone and it's ok. I am getting confused again. G Jim Macklin wrote: It is an FCC rule because cellphone tower are designed to pick up a limited number of calls and at altitude the towers are over-loaded. "pittss1c" wrote in message ... |I know there are regs against cellphone usage in aircraft. | I was wondering... has anyone ever known someone to get busted? | If so... what happened to them? | | Mike |
oups.com... Ok I am flying my plane at 12,000 feet and the phone might talk to several towers, thats frowned upon. Now, I hike about 2 miles and climb the Grand Teton mountian to almost 14,000 feet, use my phone and it's ok. I am getting confused again. G Well, a) you probably won't get very good phone reception at 12,000' AGL, and b) cells are designed taking the terrain into account. Assuming you get cell reception at the peak of Grand Teton Mt, it's because the cellular network was designed with that location in mind, and specifically does not have too many towers serving that location. |
Jim Macklin wrote:
It is an FCC rule because cellphone tower are designed to pick up a limited number of calls and at altitude the towers are over-loaded. Well the issue is that in analog cellular there are a finite amount of talk channels and they use spatial diversity and adaptively reducing power to reuse the channels in a metropolitan area. A plane at altitude even at minimum power is heard equally well over a wide number of base stations. Of course, it's more involved now with digital modulations. |
Attn: Jim Weir - Cellphone adapter? | Jackal24 | Home Built | 3 | August 23rd 05 01:46 PM |
headset - cellphone adapters | Helen Woods | Piloting | 4 | March 28th 05 06:29 AM |
Cellphone via headset ? | Christian | Piloting | 42 | November 11th 04 08:41 PM |
Cellphone weather | Cub Driver | Piloting | 0 | August 4th 04 10:38 AM |
