Morgans wrote:
And stop following that MX, from the sim group, where ever he goes. huh? |
![]() "Chris W" wrote in message ... The previous post on this topic got me wondering. Just how different would the two engines need to be? I'm no expert, but it seems to me cam shaft(s), magnetos, and prop are the parts that would be different from one side to the other. I almost forgot, reverse the polarity on the starter motor. What am I missing? Not speaking to the other items, but electric motors seldom run as well in both directions. It has to do with the timing, or how far ahead of the rotation that the magnetic fields, or windings are switched. -- Jim in NC |
With two stroke engines it is easy. I did this once. All I needed to
do was exchange the field wires in the starter to turn it backwards, and modify the advance mechanism in the distributor so the spark was advanced in the new direction. It ran fine. This was to enable a motorcycle engine to be used in a go kart, where the engine was mounted backwards, behind the rear wheels. It was a twin Yamaha and the go kart would pop wheelies like crazy. tom Chris W wrote: The previous post on this topic got me wondering. Just how different would the two engines need to be? I'm no expert, but it seems to me cam shaft(s), magnetos, and prop are the parts that would be different from one side to the other. I almost forgot, reverse the polarity on the starter motor. What am I missing? -- Chris W KE5GIX "Protect your digital freedom and privacy, eliminate DRM, learn more at http://www.defectivebydesign.org/what_is_drm" Gift Giving Made Easy Get the gifts you want & give the gifts they want One stop wish list for any gift, from anywhere, for any occasion! http://thewishzone.com |
The previous post on this topic got me wondering. Just how different would the two engines need to be? I'm no expert, but it seems to me cam shaft(s), magnetos, and prop are the parts that would be different from one side to the other. I almost forgot, reverse the polarity on the starter motor. What am I missing? Prop governor and oil pump drive gears if not on camshaft. Floating crankshaft balance weights may be slightly different if those are used. D. |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Gyrocopter Speed | Mark | Rotorcraft | 36 | August 16th 05 11:28 PM |
Towing | Roger Fowler | Soaring | 6 | August 11th 05 04:25 AM |
What if the germans... | Charles Gray | Military Aviation | 119 | January 26th 04 11:20 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
