![]() mhorowit wrote: jls wrote: Where are you using it? The leading edge of the ailerons is thin alluminum sheet. I put a lot of effort into physically removing corrosion on the left aileron and if the right was in the same shape, I was thinking it would be easier to simply make new parts. Someone pointed out that alodining chemicals could be brushed on (rather than having to build tanks) and cost was very reasonable, so I think I'll stick with my original approach. The sheetmetal will be covered by fabric. You don't need tanks for alodining. You brush it on, let it sit awhile, then wash it off. Use phosphoric acid solution first, then wash off, then chromic acid solution. Then wash off, leaving a little tannish, bluish color behind on the aluminum surface. You can use a little scotchbrite to get off the oxide powder before using phosphoric acid. I have restored several sets of ailerons on Taylorcrafts from the 40's and the aluminum in most cases is restorable. After you've alodined you can prime with Polyfiber's proprietary primer which won't dissolve when you glue on the fabric to the leading edge. By the way... There is a metal prep that is used for cleaning prior to alodining. It is a phosphoric solution. Is that also used for chemically removing corrosion, or simply preping the surface for the chromic coating? - Mike The phosphoric acid prepares for chromic acid coating,as well as removing some corrosion. Use scotchbrite if the corrosion is thick and powdery. |
Corrosion at Aluminum/Steel Junction | Front Office | Home Built | 17 | June 26th 06 01:12 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 02:46 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 05:23 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 03:52 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
