Philippe Vessaire wrote:
it is the 3 cylinder base derivated from the 4 cylinder Thielert. For airplane convertion, you need a stronger PSRU with a 3 cylinder engine versus 4 ones. I'm not sure you will have a lighter engine assembly. The Mercedes-Benz A-Class 1.7 liter turbodiesel used as the core of the Thielert Centurion is all light alloy, the 1.5 liter used in the Smart ForFour and the Mitsubishi Colt has a light alloy head and a cast iron block. Kumaros It's all Greek to me |
kumaros wrote:
In my opinion, the Toyota and the PSA group light alloy diesels are the way to go. Toyota: timing chain Peugeot: timing belt Mo The cast alloy bloc of PSA engine is not "well born". As a former PSA engineer, I eared about some bloc failures on test bed. The 2l engine is realy a better bloc but too heavy and powerful for two seater planes. I prefer the Toyota engine in the 90-100HP range. -- Pub: http://www.slowfood.fr/france Philippe Vessaire Ò¿Ó¬ |
![]() "Philippe Vessaire" wrote in message ... kumaros wrote: In my opinion, the Toyota and the PSA group light alloy diesels are the way to go. Toyota: timing chain Peugeot: timing belt Mo The cast alloy bloc of PSA engine is not "well born". As a former PSA engineer, I eared about some bloc failures on test bed. The 2l engine is realy a better bloc but too heavy and powerful for two seater planes. I prefer the Toyota engine in the 90-100HP range. Ah. And had you been a former toyota designer, no doubt you would prefer PSA...? |
karel wrote:
I prefer the Toyota engine in the 90-100HP range. Ah. And had you been a former toyota designer, no doubt you would prefer PSA...? No realy, I think the 2l and 2l2 PSA are better than the 2l and 2l2 Toyota but it is in the 140-180HP range. Each design is different and the 2l is very heavy vs the PSA one. For the 1l4, it is the opposite. And for 2007, Subaru will built a 2l5 flat four diesel.... -- Pub: http://www.slowfood.fr/france Philippe Vessaire Ò¿Ó¬ |
![]() "Philippe Vessaire" wrote in message ... And for 2007, Subaru will built a 2l5 flat four diesel.... That sounds very interesting! Any pointers /web links? Indications of cooling (liquid/air) ? Turbo? (I should think yes) TIA (et mes meilleurs voeux!) KA |
karel wrote:
And for 2007, Subaru will built a 2l5 flat four diesel.... That sounds very interesting! Any pointers /web links? Indications of cooling (liquid/air) ? liquid Turbo? (I should think yes) yes TIA (et mes meilleurs voeux!) je mitoute... (me too) A+ -- Pub: http://www.slowfood.fr/france Philippe Vessaire Ò¿Ó¬ |
![]() "karel" wrote in message ... "Philippe Vessaire" wrote in message ... And for 2007, Subaru will built a 2l5 flat four diesel.... That sounds very interesting! Any pointers /web links? Indications of cooling (liquid/air) ? Turbo? (I should think yes) Voici ce que me revelait une petite recherche: ( copied from http://blogs.edmunds.com/.ee8fe18 , hope this is ok copyrightwise ) : copy Subaru is working on a boxer diesel for the European market for 2007. The engine reportedly will be offered in the Legacy, and probably will be offered in the Forester too. Rumors have it as a 2.2L engine, and most likely also turbocharged. I would also expect to see Subaru using an ally block and head, like many modern car diesels. My guess is that Subaru also has a larger version for the Euro-Tribeca. if you add a pair of cylinders to the 2.2 H-4, you end up with a 3.3 H-6, which would be perfect for the larger Tribeca. /copy Those who master the Teuton language may consult http://www.kfzbetrieb.de/news/kb_beitrag_1806484.html which has even less factual info, and is almost 2 years old. |
karel wrote:
Ah. And had you been a former toyota designer, no doubt you would prefer PSA...? As an ATPL, I was not angry to leave PSA. -- Pub: http://www.slowfood.fr/france Philippe Vessaire Ò¿Ó¬ |
2-stroke diesel is the (near) future? | Max Kallio | Home Built | 134 | July 18th 05 12:39 AM |
2-stroke diesel is the (near) future? | Max Kallio | Rotorcraft | 123 | July 18th 05 12:39 AM |
Smart CDI diesel engine | Hans Zwakenberg | Home Built | 14 | January 9th 05 12:32 PM |
turbo stc? | The Weiss Family | Owning | 21 | October 3rd 04 10:35 PM |
