I once amazed myself by bouncing a Flybaby about 8 or so feet in the
air, which I thought wasn't possible with just tires for shock absorption .. I've worked on three Fly Babies, two from the eighties and one from the seventies. Their glue joints were sturdy, and one of them had had some awful rough landings which broke the 4130 landing gear and ruined some of the welded steel fuselage attach fittings. Best I could tell the glue in all three was resorcinol. Pete Bowers is an honored immortal for designing such a great little wooden airplane that can flare 20 feet off the deck and still remain intact. Somewhere in Ron Wanttaja's literature I read of a Fly Baby cartwheeling and the wings did not collapse. Fuselage was damaged but the pilot lived to tell the story. |
On Thu, 07 Dec 2006 18:55:08 -0500, "J.Kahn" wrote:
I've worked on three Fly Babies, two from the eighties and one from the seventies. Their glue joints were sturdy, and one of them had had some awful rough landings which broke the 4130 landing gear and ruined some of the welded steel fuselage attach fittings. Best I could tell the glue in all three was resorcinol. Pete Bowers is an honored immortal for designing such a great little wooden airplane that can flare 20 feet off the deck and still remain intact. Somewhere in Ron Wanttaja's literature I read of a Fly Baby cartwheeling and the wings did not collapse. Fuselage was damaged but the pilot lived to tell the story. I once amazed myself by bouncing a Flybaby about 8 or so feet in the air, which I thought wasn't possible with just tires for shock absorption I pegged a 4-G g-meter on a landing once. No damage, and that was on a gear leg that had been improperly repaired from a crash 15 years earlier. Ron Wanttaja |
![]() "Ron Wanttaja" wrote in message ... On Thu, 07 Dec 2006 18:55:08 -0500, "J.Kahn" wrote: I've worked on three Fly Babies, two from the eighties and one from the seventies. Their glue joints were sturdy, and one of them had had some awful rough landings which broke the 4130 landing gear and ruined some of the welded steel fuselage attach fittings. Best I could tell the glue in all three was resorcinol. Pete Bowers is an honored immortal for designing such a great little wooden airplane that can flare 20 feet off the deck and still remain intact. Somewhere in Ron Wanttaja's literature I read of a Fly Baby cartwheeling and the wings did not collapse. Fuselage was damaged but the pilot lived to tell the story. I once amazed myself by bouncing a Flybaby about 8 or so feet in the air, which I thought wasn't possible with just tires for shock absorption I pegged a 4-G g-meter on a landing once. No damage, and that was on a gear leg that had been improperly repaired from a crash 15 years earlier. Ron Wanttaja I've seen 2G's on landing, but never more than that. Of course, the RV's gear probably has more spring to it than the Flybaby's tires, so my 2 G arrival may not have any more energy than your 4, but 4??? Ouch. That's a nice way to chip a tooth or something. KB |
On Thu, 7 Dec 2006 22:44:47 -0500, "Kyle Boatright"
wrote: I pegged a 4-G g-meter on a landing once. No damage, and that was on a gear leg that had been improperly repaired from a crash 15 years earlier. I've seen 2G's on landing, but never more than that. Of course, the RV's gear probably has more spring to it than the Flybaby's tires, so my 2 G arrival may not have any more energy than your 4, but 4??? Ouch. That's a nice way to chip a tooth or something. My back hurt for a couple of days. I posted the story to RAH back then; reproduced: http://www.bowersflybaby.com/stories/humility.HTM I've got a couple of photos of the G-meter, been meaning to dig 'em up, scan them in, and add one to the web page.... Ron Wanttaja |
![]() I've seen 2G's on landing, but never more than that. Of course, the RV's gear probably has more spring to it than the Flybaby's tires, so my 2 G arrival may not have any more energy than your 4, but 4??? Ouch. That's a nice way to chip a tooth or something. 4Gs? That's just a good tight turn and you don't even need a G-Suit. KB Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
![]() "Ron Wanttaja" wrote I pegged a 4-G g-meter on a landing once. No damage, and that was on a gear leg that had been improperly repaired from a crash 15 years earlier. Thanks, Ron, for a partial confirmation of my concept. See if you 'all can follow my reasoning, here. A plane is commonly certified for -3 G's. That means all of the weight of the plane is supported by the wing. Good engineering would place ultimate failure at at least 1.5 times the 3 G's. That means the wing would hold 4.5 G's. That means the wing was holding all of the weight of the plane. What would the wing weigh, compared to the whole plane? Perhaps 1/4th of the weight? If the wing were to fail from a landing, overflexing the wing, it would take a landing of 4 times the 4.5 G's, or 18 G's. Now, I give that it is unlikely to fail a wing from a hard landing, but people do fail wings from crashes. (that is a landing, right? g) Wayne Hadley thinks his crash was about 27 G's One has to think the gear absorbed at least 1/2 of the force, right? So it follows that I would want my gear to stand up to at least 10'G's before it folded flat, or ripped loose from the fuselage or wing. So, if my gear were to stand up to drop test at 10 G's, and it had a 12" travel, how high would the plane have to be dropped from, to achieve that force? -- Jim in NC |
![]() So, just to turn the corner a little, If a person was to consider buying a project that is wood glued with epoxy but, started over 20 years ago, should that person consider the project with 20 year old epoxy connections or should he run the other way? Lou |
On 14 Dec 2006 09:33:48 -0800, "Lou" wrote:
So, just to turn the corner a little, If a person was to consider buying a project that is wood glued with epoxy but, started over 20 years ago, should that person consider the project with 20 year old epoxy connections or should he run the other way? Lou My Jungster II all wood construction is twenty years old this year. It is stuck together with epoxy (T-88) and seems to be pretty sturdy yet. It has been continuously hangered. It has been flown into the hot south west and the damp middle west (Oshkosh) and lives in California's central valley. Ed Sullivan |
Earlier, Lou wrote:
So, just to turn the corner a little, If a person was to consider buying a project that is wood glued with epoxy but, started over 20 years ago, should that person consider the project with 20 year old epoxy connections or should he run the other way? Plenty of 30-year-old composite sailplanes are glued together with epoxy. Not only that, but about half of their structure (by weight) _is_ epoxy. No sign of them spontaneously falling apart in the air. So, I'd say that age itself isn't a factor. More important is how its been stored or used, and the quality of the construction. Thanks, Bob K. http://www.hpaircraft.com/hp-24 |
![]() Lou wrote: should that person consider the project with 20 year old epoxy connections or should he run the other way? -------------------------------------------------------------------------- Dear Lou, The question of durability involved boiling sample coupons then trying to peel them apart. Based on musical instruments assembled with low-tech hide glue, when properly sealed, the moisture content of the wood -- and the strength of the joints -- can remain stable for a hundred years or more. By comparison, when not subjected to an outside agency such as heat, mold or moisture, the joints produced by virtually all modern-day adhesives are relatively ageless. When purchasing someone else's project a detailed inspection by more than one pair of eyes is always the wiser course. We now have more than seventy years of experience with epoxies as an aircraft glue. There is no inherent fault in using epoxy versus some other adhesive. What changes is the inspection criteria and that information is best supplied by someone familiar with the particular adhesive used in the project. -R.S.Hoover |
resorcinol = Carpenter's glue | [email protected] | Home Built | 13 | June 12th 05 11:01 PM |
Removable glue | Lou | Home Built | 2 | April 14th 05 06:57 AM |
Glue question | [email protected] | Owning | 1 | December 6th 04 03:25 PM |
Drywall Gussets | Veeduber | Home Built | 5 | October 27th 03 09:03 PM |
Qn: Casein Glue recognition | Vassilios Mazis | Soaring | 0 | August 20th 03 10:00 PM |
