IFR Cancellation Question
Old December 8th 06, 09:54 PM posted to rec.aviation.ifr
Roy Smith
Default IFR Cancellation Question
A Lieberma wrote:
They would if the tower had no radar.
Ok, makes sense on the radar services being terminated, but the IFR
clearance still applies for airspace seperation?
IFR would be then cancelled once wheels touch ground???
At a towered airport without radar, you are still IFR until your wheels
touch the ground (assuming you don't cancel on your own). IFR separation
doesn't require radar contact. It doesn't even require radio contact.
Both of those just make it possible to apply more efficient methods of
achieving the required separation.
Old December 8th 06, 10:00 PM posted to rec.aviation.ifr
Jose[_1_]
If your wheels touch the ground on a Cat IIIc missed approach though,
you ought to still be IFR. That would be one pretty pickle.
Jose
"There are 3 secrets to the perfect landing. Unfortunately, nobody knows
what they are." - (mike).
Old December 8th 06, 10:08 PM posted to rec.aviation.ifr
Roy Smith
Jose
If you're flying a Cat IIIc approach, the tower probably can't see you,
your wheels, or the runway, so it works out.
Old December 10th 06, 05:10 PM posted to rec.aviation.ifr
Steven P. McNicoll[_2_]
In conditions requiring a Cat IIIc approach the tower can't see your
wheels touch the ground.
Old December 8th 06, 10:01 PM posted to rec.aviation.ifr
Mark Hansen
So I wonder if the confusion came when ATC told Allen to Squawk VFR?
This just means that you're no longer in radar contact, and not that
you're no longer IFR, right?
Or, are you supposed to maintain your transponder code until changed
by ATC or you cancel IFR - even if radar service is terminated?
I think the only thing that was missing in Allen's case was the
clearance to fly the visual approach.
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old December 8th 06, 11:35 PM posted to rec.aviation.ifr
Newps
No, that measn the controller thought you were VFR.
If you are terminated you still stay on your code unless you are now
going to be VFR.
Old December 9th 06, 01:37 AM posted to rec.aviation.ifr
A Lieberma
Mark Hansen wrote in
Mark,
My experiences operating in areas of no radar coverage (NOT what happened
here in my original post) is that you maintain your transponder code and
work with "reporting points" as required under IFR enroute rules.
I was in Charlie airspace when I was told to squawk VFR in my original
post, thus my confusion
For no radar coverage, you maintain your transponder code. I had asked
when this happened to me the first time and Center advised me to retain
the code and when I come out of the non radar environment, he would pick
me up. I'd rather sound dumb on the radio then do something dumb :-))
EXACTLY right! AND the IFR cancellation received, squawk VFR" buzz words
I learn to know and love.
Those rank up there with "cleared to land" at a controlled airport :-)
Allen
Old December 9th 06, 03:20 PM posted to rec.aviation.ifr
Ron Natalie
Well in the ADIZ you darn well better keep squawking that discrete
code to the ground even if you cancel IFR (ATC will usually warn
you about this...violations are a pain in the butt for them too).
It's pretty standard everywhere else. I've never been told to
squawk VFR while IFR even without radar service.
Old December 10th 06, 05:13 PM posted to rec.aviation.ifr
No, the loss of radar contact of an IFR aircraft doesn't call for a
code change, it calls for advising the aircraft that radar contact was
lost.
Old December 9th 06, 03:18 PM posted to rec.aviation.ifr
Ron Natalie
It doesn't even require a tower. Just a control zo-er um surface area
of controlled airspace.
Lyc. O-360 cylinder question JB Owning 13 November 27th 04 09:32 PM
Handheld battery question RobsSanta General Aviation 8 September 19th 04 03:07 PM
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 05:07 AM
Question Charles S Home Built 4 April 5th 04 09:10 PM
Partnership Question Harry Gordon Owning 4 August 16th 03 11:23 PM
