So...about that plane on the treadmill...
Old December 12th 06, 01:19 AM posted to rec.aviation.piloting
Ray
Default So...about that plane on the treadmill...
Looks like airplane treadmill problem, regularly a spark for flame wars
on R.A.P., has made it into the mainstream.
http://pogue.blogs.nytimes.com/
Let the arguing begin!
- Ray
Old December 12th 06, 01:34 AM posted to rec.aviation.piloting
Peter Duniho
"Ray" wrote in message
Looks like airplane treadmill problem, regularly a spark for flame wars on
And handled with every bit as much intelligence and consideration as we've
seen here. Which is to say, there's no shortage of people convinced that
the airplane won't take off, even though it will.
Why? Haven't you had enough by now?
Old December 12th 06, 01:45 AM posted to rec.aviation.piloting
FLAV8R
"Ray" wrote in message ...
- Ray
That would depend on what has the greater resistance,
the air in front of the plane or the belt on the treadmill.
If it was harder for the plane to push through the air in
front of it then the plane would merely roll stationary
on the treadmill.
If the resistance of the treadmill rollers was greater
than the air in front of the plane then the plane would
push forward thereby achieving lift through air flow
passage over the wings.
You can equate it to an airboat in a river.
Will the river push the airboat down stream or
will the propulsion of the engine move it forward?
Just my two cents worth....
David
Greer, SC
Old December 12th 06, 01:50 AM posted to rec.aviation.piloting
Peter Duniho
"FLAV8R" wrote in message
No, it would not depend on that at all. Both of those effects are creating
a resistance in the same direction, and thus are additive. Which one is
greater is irrelevant. The only relevant question is whether they combined
exceed the thrust from the engines.
They don't even come close to doing that, and so the engines can easily push
the airplane forward to a high enough speed for flight.
It's similar, yes. Except that the drag due to friction from the treadmill
is miniscule, whereas hydrodynamic drag is significant.
Pete
Old December 12th 06, 02:09 AM posted to rec.aviation.piloting
Peter Dohm
creating
combined
push
treadmill
Pete
As pictured, the runway is much to short, which is just as well since the
uprights of the treadmill would impinge on the wings. bfg
Actually, I agree that the drag from the treadmill is trivial. Therefore,
if sufficient distance was provided to accellerate to an appropriate
airspeed, the only problem would be the maximum speed rating of the tires.
Peter
Old December 12th 06, 02:23 AM posted to rec.aviation.piloting
BucFan
- Ray
It is a trick question. The obvious assumption being that the plane will
not move, therefore no airflow over the wings. The plane, however WILL move
down the runway. The propeller or the jets will pull or push on the air and
move the plane. The wheels are not providing the moving force, the reaction
of the thrust mechanism against the air is.
One of two things would happen before the plane took off though, the
bearings in the planes wheels would burn up or the motor driving the
treadmill would burn up. The control system is in an infinite feedback
loop. The plane would move due to the forces described above and the
treadmill would try to speed up, so the wheels would move faster, then the
treadmill would move faster etc etc etc......
Old December 12th 06, 02:27 AM posted to rec.aviation.piloting
Morgans[_2_]
It is truly amazing how many clueless people have commented on the problem. MX
should go hang out there. He would look like a rocket scientist.
Jim in NC
Old December 12th 06, 02:32 AM posted to rec.aviation.piloting
muff528
It seems that the "non-believers" think that the treadmill is somehow
holding the airplane back.
The way that the problem is posed on the blog states that the treadmill
matches the wheel speed of
the airplane. ("The conveyer belt is designed to exactly match the speed of
the wheels, moving in the
opposite direction.") If friction is taken into consideration then one of
four conditions can exist.
1. no thrust (or not enough thrust to overcome frictional forces) ...
neither the plane nor the conveyor are moving.
2. minimal thrust... the wheels and conveyor are moving but the conveyor
drags the plane backwards.
3. just enough thrust to match friction forces... the airplane remains
motionless relative to the earth but the wheels
and conveyor are moving a little faster.
4. more than enough thrust.... the airplane accelerates until it can take
off. The conveyor also accelerates to match
the wheel's speed until lift off when the wheels rotate to a stop and
the conveyor, somehow sensing this, also
comes to a standstill.
The treadmill's speed is dependent on the wheel's speed, not the other way
around.
Old December 12th 06, 02:35 AM posted to rec.aviation.piloting
Darkwing
- Ray
This looks like a job for the MythBusters!!!
DW
Old December 12th 06, 02:42 AM posted to rec.aviation.piloting
Darkwing
Nope the plane won't take off.
DW
VQ-1's P4M-1Q crash off China - 1956 Mike Naval Aviation 0 May 6th 06 11:13 PM
Passenger crash-lands plane after pilot suffers heart attack R.L. Piloting 7 May 7th 05 11:17 PM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 May 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 April 1st 04 08:27 AM
