Anyone flown atn LPV yet?
Old December 16th 06, 04:29 PM posted to rec.aviation.ifr
Ron Natalie
Default Anyone flown atn LPV yet?
Ron Rosenfeld wrote:
On Fri, 15 Dec 2006 06:56:17 -0800, Sam Spade wrote:
Subject line says it all.
If so, what was your impression?
Not yet. But I have flown an LNAV with advisory vertical guidance. The
needles were extremely stable -- more so than an ILS with my equipment.
Pretty easy to fly.
Ditto...I even coupled the autopilot... real nice.
Old December 16th 06, 04:52 PM posted to rec.aviation.ifr
John R. Copeland
"Ron Rosenfeld" wrote in message ...
Pretty easy to fly.
Yes, the approaches are a pleasure to fly, but the step change in course
width can cause a coupled approach to give a small disturbance, for me.
If the needle isn't exactly centered at the point of switching,
my autopilot hunts for a few moments, until it stabilizes again.
It's a small amount, and not an operational problem, but it makes the GPS
approaches slightly less smooth than an ILS, which doesn't have that bump.
My autopilot is a Collins AP-107.
Who sees any similar effect with other autopilots?
Old December 17th 06, 02:12 AM posted to rec.aviation.ifr
Sam Spade
Is this a GNS 480 that is giving the step changes? Do you see these
small incremental changes on your CDI or HSI?
Old December 17th 06, 10:19 AM posted to rec.aviation.ifr
Ron Rosenfeld
On Sat, 16 Dec 2006 11:52:57 -0500, "John R. Copeland"
Pretty easy to fly.
I've not noted a "step change" in my CNX80. The changes in sensitivity are
supposed to be gradual, and at the FAF I believe the "scaling" goes to
angular, to mimic an ILS. But maybe I've just missed it.
Old December 17th 06, 02:59 PM posted to rec.aviation.ifr
Sam Spade
As I understand it, it first ramps down to 0.3 from 1.0 starting at 2
miles from the LPV FAF, then it does a continuous angular "ramp down"
from the FAF to the runway so it will be ILS-like close in. Have you
noted that doing small incremental "stepping" on an LPV IAP during final
approach?
Old December 17th 06, 11:04 PM posted to rec.aviation.ifr
John R. Copeland
"Sam Spade" wrote in message ...
approach?
You say LPV course widths ramp down gradually over some miles?
Should LNAV/VNAV approaches do the same?
Around the FAF, it's usually too busy a time to collect every detail.
If it's not a step change in course width, it seems at least pretty quick.
Quick enough to disturb my autopilot a small amount, it seems.
But the reason I asked was to learn if other CNX80 users see a similar effect.
So far, the answer seems to be "no".
The effect I see is small, though, so it could be ignored easily.
If the blame turns out to be on my autopilot, I could send it back
to Collins to get it re-calibrated.
Old December 22nd 06, 02:06 AM posted to rec.aviation.ifr
Ron Rosenfeld
approach?
Well, I'm hand-flying most of the approaches, and the CDI is generally
centered prior to the FAF, so I wouldn't note a sudden change in
sensitivity on the final segment.
I do, of course, note the change going from enroute to terminal mode, and
from terminal to approach mode if I have any CDI deflection.
Haven't flown in a long while... Flyingmonk Piloting 33 April 5th 06 06:30 AM
Total cross country distance flown Bill Daniels Soaring 9 November 4th 05 11:53 AM
If there are any pilots here that have ever flown aerial surveys.... terrygeosearch Piloting 1 February 8th 05 06:45 PM
If there are any pilots here that have ever flown aerial surveys.... terrygeosearch General Aviation 0 February 2nd 05 04:11 AM
Most aircraft types flown by 1 pilot? Chad Irby Military Aviation 10 January 7th 04 03:47 AM
