Ron Rosenfeld wrote:
On Sun, 17 Dec 2006 06:59:39 -0800, Sam Spade wrote: Well, I'm hand-flying most of the approaches, and the CDI is generally centered prior to the FAF, so I wouldn't note a sudden change in sensitivity on the final segment. I do, of course, note the change going from enroute to terminal mode, and from terminal to approach mode if I have any CDI deflection. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) I am playing with the new Garmin 400/500W trainer and the needle movement is very smooth. I also verified the great difference between when the scaling becomes localizer-like with VTF and own-nav. I flew the LPV into KIXD Runway 36. Using VTF, I did an intercept 8 miles prior to JIKLA (the FAF). The CDI scaling was already well below 1 mile. Then I did an intercept at the same position with ANQUIM (the IF) to JIKLA as the active leg. The needle came off the peg at 1 mile crosstrack error. The 530W also has a nice feature, not present in th 530. When there is a course change at a waypoint it shows a broken magenta line, which is the flyby course that will be flown if on autopilot. Positive course gudiance in holds and procedure turns using highly accurate roll-steering is great, too. (For FD or autopilot, those too need to have roll steering to get the most out of these curved flight paths.) |
On Fri, 22 Dec 2006 09:10:02 -0800, Sam Spade wrote:
Ron Rosenfeld wrote: On Sun, 17 Dec 2006 06:59:39 -0800, Sam Spade wrote: Well, I'm hand-flying most of the approaches, and the CDI is generally centered prior to the FAF, so I wouldn't note a sudden change in sensitivity on the final segment. I do, of course, note the change going from enroute to terminal mode, and from terminal to approach mode if I have any CDI deflection. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) I am playing with the new Garmin 400/500W trainer and the needle movement is very smooth. I also verified the great difference between when the scaling becomes localizer-like with VTF and own-nav. I flew the LPV into KIXD Runway 36. Using VTF, I did an intercept 8 miles prior to JIKLA (the FAF). The CDI scaling was already well below 1 mile. Then I did an intercept at the same position with ANQUIM (the IF) to JIKLA as the active leg. The needle came off the peg at 1 mile crosstrack error. The 530W also has a nice feature, not present in th 530. When there is a course change at a waypoint it shows a broken magenta line, which is the flyby course that will be flown if on autopilot. Positive course gudiance in holds and procedure turns using highly accurate roll-steering is great, too. (For FD or autopilot, those too need to have roll steering to get the most out of these curved flight paths.) I have no experience with anything other than the 480, so can't comment. I also do not have a roll-steering a/p. The 480 does show a solid curved magenta line for course changes at waypoints representing the expected flight path. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
![]() "Sam Spade" wrote in message ... The 530W also has a nice feature, not present in th 530. ......snip... Positive course gudiance in holds and procedure turns using highly accurate roll-steering is great, too. (For FD or autopilot, those too need to have roll steering to get the most out of these curved flight paths.) According to the GNS430W manual, the unit does not provide positive course guidance in holds except on the inbound leg, which is not a change from the 430, and does not provide positive course guidance on a PT except on the outbound and inbound portions (not during the reversal itself), which is also not a change from the 430. Regarding roll steering, it says "For roll steering autopilots: roll steering is terminated when approach mode is selected on the autopilot and is available once the missed approach is initiated." I don't really understand this statement. I didn't read the 530W manual. Is it different? |
Haven't flown in a long while... | Flyingmonk | Piloting | 33 | April 5th 06 06:30 AM |
Total cross country distance flown | Bill Daniels | Soaring | 9 | November 4th 05 11:53 AM |
If there are any pilots here that have ever flown aerial surveys.... | terrygeosearch | Piloting | 1 | February 8th 05 06:45 PM |
If there are any pilots here that have ever flown aerial surveys.... | terrygeosearch | General Aviation | 0 | February 2nd 05 04:11 AM |
Most aircraft types flown by 1 pilot? | Chad Irby | Military Aviation | 10 | January 7th 04 03:47 AM |
