Sam Spade writes:
That won't work with the GNS400/500 series. Direct-To with any type of fix will put a magenta route line on the map (and potentially other instruments that pull information from the GPS). -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() "Mxsmanic" wrote in message ... Sam Spade writes: That won't work with the GNS400/500 series. Direct-To with any type of fix will put a magenta route line on the map (and potentially other instruments that pull information from the GPS). -- Transpose mxsmanic and gmail to reach me by e-mail. The point, though, was to have the magenta line along the final approach course, not on the direct path between the present position and the fix. |
Stan Prevost writes:
The point, though, was to have the magenta line along the final approach course, not on the direct path between the present position and the fix. On the GNS530, you can insert a waypoint into your currently active flight plan. If you put it after the current fix, it will be inserted in your current route from your last waypoint. I don't have it in front of me so I don't recall the exact sequence, but you can put stuff in and take it out on the fly. Approaches are different, though, since changing them seems to mutate them into regular routes. I don't use approaches and the like too much on the GPS, since it's harder to get it working than to fly it by hand (or by autopilot). -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
.. Approaches are different, though, since changing them seems to mutate them into regular routes. I don't use approaches and the like too much on the GPS, since it's harder to get it working than to fly it by hand (or by autopilot). You can do changes to the IAP flight plan sequence prior to the FAF and the approach mode will still activate as well as the missed approach. The limiting factor is an unacceptably large angle of intercept to the FAF as established by Garmin. |
Mxsmanic wrote:
Sam Spade writes: That won't work with the GNS400/500 series. Direct-To with any type of fix will put a magenta route line on the map (and potentially other instruments that pull information from the GPS). That is not the point. Direct-to on a GNS400/500 will not yield the unpublished extension of the final approach course unless you happen to be in the correct position when you activate direct-to. Sure, you will have a magenta line but it probably won't have a magnetic course of 002, as per the example IAP. |
![]() "Sam Spade" wrote in message ... That is not the point. Direct-to on a GNS400/500 will not yield the unpublished extension of the final approach course unless you happen to be in the correct position when you activate direct-to. Sure, you will have a magenta line but it probably won't have a magnetic course of 002, as per the example IAP. On the GNS430, Direct-To provides an opportunity to set the course to/from the waypoint. Press Direct To, enter the waypoint, press Enter, move the cursor to the course field, set the course, then press Enter again. |
Stan Prevost wrote:
"Sam Spade" wrote in message ... That is not the point. Direct-to on a GNS400/500 will not yield the unpublished extension of the final approach course unless you happen to be in the correct position when you activate direct-to. Sure, you will have a magenta line but it probably won't have a magnetic course of 002, as per the example IAP. On the GNS430, Direct-To provides an opportunity to set the course to/from the waypoint. Press Direct To, enter the waypoint, press Enter, move the cursor to the course field, set the course, then press Enter again. I'll take your word for it. That seems more complicated, though, than using OBS mode. |
Stan Prevost wrote:
On the GNS430, Direct-To provides an opportunity to set the course to/from the waypoint. Press Direct To, enter the waypoint, press Enter, move the cursor to the course field, set the course, then press Enter again. I just tried that on the 530 trainer and it works the same way. On relection that might be a better way to go in this hypothetical than using OBS mode. |
![]() "Sam Spade" wrote in message news ![]() Stan Prevost wrote: On the GNS430, Direct-To provides an opportunity to set the course to/from the waypoint. Press Direct To, enter the waypoint, press Enter, move the cursor to the course field, set the course, then press Enter again. I just tried that on the 530 trainer and it works the same way. On relection that might be a better way to go in this hypothetical than using OBS mode. Now I remember why I thought OBS was not the best mode. It isn't because it won't paint the magenta line, because it does; I was off-track on that. It is because it doesn't autosequence waypoints in OBS mode. Setting the course in Direct-To does continue autosequencing. |
Contact Approach -- WX reporting | [email protected] | Instrument Flight Rules | 64 | December 22nd 06 01:43 PM |
RNAV Operations in FS2004 | Rookie | Instrument Flight Rules | 2 | November 29th 06 11:51 PM |
RNAV approaches | Kevin Chandler | Instrument Flight Rules | 3 | September 18th 03 06:00 PM |
RNAV approaches | Kevin Chandler | Piloting | 3 | September 18th 03 06:00 PM |
Slam dunk into Janesville | Steven P. McNicoll | Piloting | 0 | July 31st 03 01:08 AM |
