Dumb Question
Old December 22nd 06, 02:24 AM posted to rec.aviation.rotorcraft
Stefan Lörchner
Default Dumb Question
Why should a ducted fan/rotor not be capable of working in autorotation?
I never heard about that and cannot find a reason.
How could it? With a duct around it, would you not have to descend straight
down? And if you did, would the rotational mass of a rotor that small in
Straight down can be a possibility. But if you can fly the thing, you
can also tilt the thrust vectors. So just tilt it so that the airflow
matches airspeed like in a heli.
diameter, and designed to work at such a high rpm, store enough energy in
free fall, to stop your descent when you applied collective to land?
That's a design issue since it is not free fall. Otherwise it wouldn't
be autorotation. The rotors/fans would of course have a windmilling
braking effect. And certainly, the inertia has to be sufficient to allow
smooth and preferably save touchdown as should be the case in every
helicopter.
Smaller and faster rotors are less effective and therefore need more
descent rate (more power). That's fact, too. Compare the sink rate in
autorotation of a Hughes 500 and a R44 (or the HV diagrams).
Old December 24th 06, 07:46 PM posted to rec.aviation.rotorcraft
Linc
Stefan Lörchner wrote:
But an interesting question is why nobody ever tried a supersonic rotor.
Maybe it's easier to fold or stop the rotor than to make it strong
enough and still efficient for sub- and supersonic speeds.
Retreating blade stall.
Linc
DUMB ROOKIE QUESTION Travis Beach Soaring 10 November 7th 06 08:28 PM
stupid question JaKoB General Aviation 2 November 9th 04 10:48 AM
Dumb Transponder Question! John P Owning 2 March 30th 04 01:26 AM
Partnership Question Harry Gordon Owning 4 August 16th 03 11:23 PM
